07-16-2013, 10:50 AM | #23 | |
Rep 402
I agree, I am a little defensive if you take just this post into consideration, however the issue with this poster goes beyond this thread. These are trolling jabs to provoke a response. I will take your advice and not take the bait in the future.
I appreciate your post, my contention is that the controls of the care do a great job of eliminating negitive charactoristics for both AWD and RWD. Kevin Quote:
07-16-2013, 11:03 AM | #24 | |
Rep 293
07-16-2013, 11:10 AM | #25 |
Rep 1,730
07-16-2013, 11:23 AM | #26 |
Rep 3,619
Guys you can come up with all sorts of logical explanations you want, the reality is the 335i xdrive DOES NOT understeer. The experts have already said the RWD 335i and the S4 understeer. I would challenge you to look for any expert who says the xdrive F30 understeers. If anything MT said the xdrive oversteers.
Let it rest.
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
07-16-2013, 11:48 AM | #27 | |
Rep 1,730
07-16-2013, 11:55 AM | #28 | |
Rep 3,619
MT does not observe understeer, BMW states that with xdrive they made an attempt to ensure the car does not exhibit any understeer. Each source seems to be corroborating the other. That's where I stand. Why would MT/CD/RT lie about any of this stuff? It just gets boring seeing the same arguments being made to support the thesis that F30 xdrive's understeers when per the experts this is not the case.
07-16-2013, 12:06 PM | #29 |
Rep 1,730
Quote me where Motor trend says the car doesn't understeer. All I see is
Kong noted that the BMW "feels ready to oversteer." I also see in the suspension section Oddly, the BMW features the laziest handling here. Adding all that AWD hardware sure didn't help the 335ix out. Its ride was the softest of the group. If the first quote is your support that "the reality is the 335i xdrive DOES NOT understeer" then I'll tap out of this argument now. |
07-16-2013, 12:19 PM | #30 | ||
Rep 3,619
Yes the handling is lazy, the ATS has the best handling of the bunch I don't see any reference to understeer, do you?
07-16-2013, 12:25 PM | #31 | |
Rep 1,730
http://en.wikipedia.org/wiki/Understeer_and_oversteer Where do you see anything to the tune of "We at MT have concluded that the 335ix does not exhibit understeer" The lack of evidence to support a claim one way or another does not imply the claim is true/false. |
07-16-2013, 12:29 PM | #32 | |
Rep 3,619
07-16-2013, 01:38 PM | #33 |
Rep 9,708
Interesting.........it is well understood that the lighter engined 328i exhibits less under-steer than it's heavier engined 335i brother........
........yet there is amazement that 95kg's of mainly front mounted AWD equipment should make an F30 exhibit more under-steer. |
07-16-2013, 01:58 PM | #34 | |
Rep 7,047
Stability control can easily help correct any over steer that a driver may induce when the system is on. If the system is off, well then, the driver did it for a reason and must then WANT some neutral handling or a bit of power over steer. Electronic assistance should allow makers of performance oriented cars to tune without the need to PUT IN under steer, imo. |
07-16-2013, 02:05 PM | #35 | |
Rep 7,047
Of the bat my money is on the RWD. Why? Because historically BMW's AWD has not done as well as the RWD spec. X drive offers advantage off the line, but for handling not so much. I do have an open mind though and would love to see if BMW did achieve better handling out of the new 3 using X drive. If they did, then their whole RWD handling supremacy goes out the proverbial tailpipe. |
07-16-2013, 02:32 PM | #36 | |
Rep 1,730
On the other end of the spectrum is the corvette, which someone told me (albeit in jest) was the most "unsafe" car on the road based on how easily the car can break out and fishtail. In that case TSC probably has quite a large work load |
07-16-2013, 02:35 PM | #37 | |
Rep 9,708
07-16-2013, 03:26 PM | #38 |
Rep 293
You said
"I don't think you'd argue that the engine generates more than enough torque on the F30 RWD to spin the wheels on a sharp turn in a low gear. So by deductive reasoning, xdrive will move drive torque to the front wheels in the same situation, which by definition will make the car understeer more if you are at the limits of the tires." Sorry saying you contradicted yourself was the wrong description I should have said your argument makes no sense. The electronics detect the slip from both ends and balance it out in a fraction of a second. The car isn't going to oversteer for a bit then understeer for a bit like some old tractor with very worn steering so saying that rear tyre slip causes understeer is not a valid statement IMO. |
07-16-2013, 03:40 PM | #39 | |
Rep 293
07-16-2013, 03:49 PM | #40 | |
Rep 1,730
Your interpretation that the "fraction of a second controller balances out the car during oversteer or understeer" sounds like marketing dribble to me. There is no conceivable scenario where an AWD car can induce oversteer relative to the RWD car, like Elk said, go look at the friction circle. |
07-16-2013, 03:55 PM | #41 |
Rep 293
Playing devils advocate a bit can I ask another question. If the extra weight of the Xdrive system promotes understeer does that mean that in the 330/ 335 with that big lump of engine in the front surely they must understeer like crazy compared to the 320D xdrive.
07-16-2013, 04:03 PM | #42 | |
Rep 9,708
I have driven just about every F30 engine combo and you can definitely feel the difference in handling between the 4 pot and 6 pot engines. Night and day is how I would describe it. I haven't driven an xDrive, but 100kg in the front half of the car IS absolutely going to make a difference to the handling. True it will be something you get a feel for straight away and become 'normal', but it will be present. |
07-16-2013, 04:04 PM | #43 | |
Rep 9,708
07-16-2013, 04:06 PM | #44 | |
Rep 293
