04-16-2020, 02:03 PM | #419 |
Berloss
Rep 15
I did not code for testing. I tough if the display supply with correct voltage the screen show “no signal”.
The cafd I already prepared with The parameters but before I update the car I want to check if the display works. |
04-16-2020, 02:22 PM | #420 | |
Rep 256
It's a nbt Evo touchscreen (the f series didn't have touch until 2017/2018 I believe) I don't know why that part # isn't showing on real oem but I found it for sale https://ru.opuradio.com/bmw-lg-cid-1...ion-p2236.html |
04-16-2020, 02:29 PM | #421 |
E36fiend
286
Rep 637
Drives: 2014 435i xDrive
I'm not sure what the specific conditions are for the "no signal" vs black screen issue, but I would try implementing these parameters. There are a couple others you need to do for the touch capabilities but I can't recall off the top of my head.
04-16-2020, 02:39 PM | #422 | |
E36fiend
286
Rep 637
04-16-2020, 03:44 PM | #423 | |
Berloss
Rep 15
But the g30 or the f2017-2018 Touch screens should have been compatible with my NBT EVO 11/2026 after coding. I have already read about someone who upgrade to the g30 screen. The g30 housing ist definitely different to the f15. I prefer the f15 with the slim silver finish. I got the information it’s really a NBT Evo screen. So the voltage of 12v must be Match between hu and screen. Maybe the video cable is different coded for the touchscreens? Tomorrow I will test the cafd coding and hope for positive results (fingers crossed) |
04-16-2020, 03:56 PM | #424 |
Berloss
Rep 15
Okay I have found the g30 display how to.
https://f30.bimmerpost.com/forums/sh...9#post24714079 Obviously I have to code the display first, like described in the how to retrofit. |
04-16-2020, 06:16 PM | #425 | |
Rep 462
You can search this part number on google image and you will be able to see its identical. I used this exact screen on my car, it's nbt Evo with touchscreen. The reason for no display is the coding, you need to set it to the correct screen resolution for it to display anything. I've experienced the same on my car as well. Just follow the coding instructions provided above you will be good.
Instagram:catpupu_f80 |
04-17-2020, 02:36 PM | #426 | |
Rep 380
I have 2016 f30 with nbt evo id4++. Any help to fix this. |
04-17-2020, 02:56 PM | #427 | |
E36fiend
286
Rep 637
Try these parameters: CID_APIX_Mode = apix1 CID_COLOR_DEPTH = 24 CID_COM_MODE = spi CID_DISPLAY_RES = 1280_480 CID_DISPLAY_SIZE = 10_25 CID_RESOLUTION = 1280_480 (might also be CID_DISPLAY_RES) DISPLAY_SIZE_RESOLUTION = 10.25_1280x480 |
04-17-2020, 03:17 PM | #428 | |
Rep 256
04-17-2020, 03:19 PM | #429 | ||
Rep 380
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
04-17-2020, 03:20 PM | #430 |
Rep 256
04-17-2020, 03:21 PM | #431 |
E36fiend
286
Rep 637
04-17-2020, 03:34 PM | #432 | |
Rep 380
CID_DISPLAY_RES = 1280_480 and display Resolution to 1280 by480 still says same no signal
04-17-2020, 04:10 PM | #433 | |
Rep 380
rse_apix_mode rse_color_depth rse_display_size etc ?
04-17-2020, 06:35 PM | #434 |
E36fiend
286
Rep 637
04-17-2020, 06:42 PM | #435 |
Rep 380
ok.
I did reset the values back to the original for 8.8 with APIX1 - 8.8 is working fine 10.25 is showing a blank screen but the audio is working fine. Then I coded the options you mentioned still a blank screen with audio working fine. with APIX2 - 8.8 is showing NO SIGNAL and 10.25 is showing also showing NO SIGNAL but the audio is working fine. |
04-18-2020, 12:54 AM | #436 |
Berloss
Rep 15
Did you have clear the error memory after installation? Other option would be, press volume button of hu until it reboots.
04-18-2020, 11:08 AM | #437 |
Rep 380
I just got a confirmation from a coding professional that the combo i am trying might not work.
The screen i bought is NBT and my headunit is NBT Evo and this combo might not work. I want to sell the screen. If anyone is interested PM me. Thanks. |
04-18-2020, 12:08 PM | #438 | |
Berloss
Rep 15
Your HU dose supply 12v and the NBT display need 8.4v. Install the regulator between the two wires (yellow/red and brown) adjust the regulator to 8.4v and follow the coding to apix1, well done the display will work with nbt Evo;-) A nbt Evo display is equipped with touch. |
04-18-2020, 01:48 PM | #439 | ||
Rep 380
But i am worried about how would it stand over the long run. Won't there be any other issues?
04-18-2020, 02:25 PM | #440 |
E36fiend
286
Rep 637
Using a voltage converter shouldn't have any long term negative effects, provided it's a quality unit and connected securely. Personally I'd just get the right screen for your head unit.
