04-12-2022, 09:17 AM | #419 | |
Rep 2,450
Drives: E63 645Ci
As for the Fakra Z connectors, the Z stands for universal coding that fits all other types, including C. |
04-17-2022, 11:13 AM | #424 |
Rep 2,450
Drives: E63 645Ci
04-18-2022, 02:01 AM | #425 |
Rep 145
Hi i just bought 10.25 android screen.
And it seems like i couldn't get coding the i-drive to be on full screen. It always half screen. I'v already adjust the screen settings on the android screen. Tried with bimmercode and the resolution is great but half screen is showing. Tried in the past to code 8.8 screen and it's same result. Tried with esys also (great member from the forum tried to help me). Is there any other issue in my HU that doesn't let me to make the coding perfect? Do i need to look for other coding line also? Please help me i don't know what to do. |
04-18-2022, 05:23 AM | #426 | |
Rep 24
Drives: 2012 F10 535i (N55 engine)
04-18-2022, 07:26 AM | #427 |
Rep 47
Got 4G Supported BAND from Avin.
They have SD662 units with North America bands in stock now. North America GSM: 850 / 900 / 1900 EVDO: BC0 WCDMA: B2, B4, B5, B8 TD-SCDMA: B34, B39 FDD-LTE: B2, B4, B5, B7, B8 TDD-LTE: B38, B41 International GSM: 850 / 900 / 1800 EVDO: BC0 WCDMA: B1, B5, B8 TD-SCDMA: B34, B39 FDD-LTE: B1, B3, B5, B7, B8 TDD-LTE: B38, B39, B40, B41 |
ooati6.50 |
04-19-2022, 09:30 AM | #428 |
Rep 17
Drives: w e90 320d
M600_OS_v2.0.3-ota.zip
Guys I've been supplied an update for my android 11 unit supplied by Avin:- Ksw-R-M600_OS_v2.0.3-ota.zip. I'm not aware of the details in change log but If anyone would like a copy it can be found here.
https://drive.google.com/file/d/13Jp...w?usp=drivesdk If this is not allowed admin please delete and accept my apologies.
Uk
04-21-2022, 09:03 AM | #431 |
Rep 47
I've received 12.3" unit from AVIN. But, brightness and contrasst seems lower then my older 10" android 9 unit. Especially contrast is low, colors are wased out. Screen looks like old TFT. Are they all like that?
04-21-2022, 09:46 AM | #432 |
Rep 2,450
Drives: E63 645Ci
Check if you still have this matte, thick, blue antiglare screen protector on. It's meant to imitate OEM antiglare coating, but it's only a poorly made screen protector.
04-21-2022, 12:22 PM | #433 |
Rep 47
That "antiglare" screen protector I removed right away. Still, had to kick the brightness up to 100%. Screen is kind of usable, but to my surprise noticeably worse then my old unit.
04-23-2022, 06:54 AM | #434 |
Rep 4
do you recommend removing it? i still have mine on - especially for direct sun it seems like it is the better option?
04-23-2022, 08:07 AM | #435 |
Rep 2,450
Drives: E63 645Ci
I don't give many recommendations these days anyways. Last thing I'm going to tell you is how you feel about your screen protector, whether you like it or not is up to you. All I said it's a fake antiglare and not how OEM screens are made. It's a screen protector and as any other screen protector that is not 100% clear there are going to be some distortions.
04-23-2022, 11:25 AM | #436 |
Rep 677
Hey guys,
i installed a 12.3" android 11 662 mekede unit in my e90 back in december. I had no nav before so i had to cut a hole in the dash. I also installed the included cheap external mic and ran it to the top left corner of the windshield since i had heard the built in mic was awful. Everything works fine and i have been happy with it except for one issue. The phone calls..sometimes they work fine, other times the person cant hear me on the other end. It isn't a low volume issue like many people have complained about with the built in mic. When mine doesn't work, the mic is dead and doesn't pic up any sound at all. I did a test on a day where it wasn't working. I called another phone, picked it up, and tapped on the mekede external mic and heard nothing. So its as if the mic was disabled completely. I also did a test on a day where it worked fine, called another phone and tapped on the mekede external mic and i could clearly hear the taps. So i know the unit detects and uses the external mic. Its just that some days, its as if it just disables the mic completely. Has anyone else had that issue? Even though i feel like this is a software glitch, i haven't really seen others mention it. So im tempted to disconnect the external mic for a while to see what happens. |
04-23-2022, 12:57 PM | #437 |
Rep 32
after i have installed ota 2.0, HU dont accept any update files ))
so maybe now they must be in spesiell folder or may be some bug after last update ( do somebody know some other method to install ota? Last edited by 7ambrion; 04-23-2022 at 03:25 PM.. |
04-23-2022, 07:12 PM | #438 | |
Rep 4
04-25-2022, 04:01 AM | #439 |
Rep 19
Hi,
I installed a 12.3'' SD662 monitor from navifly. After its installation, BMW iDrive often reboots when I turn on the ignition or start the engine. It happens like 80% of startups. My screen typically goes like this: 1. iDrive navigation map (thing on the screen last time I stopped the system) appears for a few seconds 2. the screen goes blank and says "No Signal" 3. iDrive startup screen follows saying "BMW connected drive" 4. then, screen returns to the first point and gets ready for use. After this reboot, the system runs stable and has no problem. Does anybody experience this and know any fix? I suspect the power supply may be insufficient for the iDrive system at startup, which causes the reboot. I tried the followings but the reboot persisted. - changing battery type to 80Ah or 105Ah (originally, this was set 90Ah) - dropped screen brightness in Android setting (this may save some electricity?) My battery shows around 12.5V, so I think battery itself is healthy. Is there any coding option to change the power threshold to trigger iDrive reboot? Any other help is also appreciated. |
04-25-2022, 05:09 AM | #440 | |
Rep 2,450
Drives: E63 645Ci
Your issue is with CAN bus and Android itself. Either the MCU is doing something stupid, a cable on your adapter harness is pinched or something is not connected correctly. |
ReMiii4021.50 |
