01-22-2018, 02:07 AM | #419 |
Rep 1
Hello, I am a complete newby to BMW / BMW coding
Thank you for support in this forum. Yesterday i have retrofitted Cruise Control on my F20, an also coded it. Of course the first time i had forgot to turn on the engine, and my car went to sleep mode durring the flash process so i flashed my ECU with corupt data, but saved afterwards with this trick : http://f30.bimmerpost.com/forums/sho....php?t=1090133 and then i was able to add the SA: 544 and code the FEM, ICM and KOMBI in order to have Cruise Control. But durring the coding process i have received a lot of DTC's that where shown in the Instrument Cluster and in the Radio Professional. (which dissapeared after an ignition change) Now i would like to see what DTC's are on my car and delete them. well actually....just delete them --> will it work with E-SYS (without any risks)? (like described in post #50? Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Scroll to the bottom and double-click "... Clear all DTCs ...") Or do i need the "EDIABAS/tool32" ? and if I need it .... could you please also send me a PM ? even if you don't have time to send it to me, i would like to Thank you for you work on this forum ! |
01-22-2018, 06:54 AM | #420 | |
Rep 42,932
02-05-2018, 11:13 AM | #421 |
Rep 177
Hey shawnsheridan ,
I'm also trying to clear the airbag error and Low Beam malfunctions for LED headlights that were installed on my buddy's F30. Can this be done on e-sys or, as the previous comments, I'd like to request the latest tool32. p.s. - I'm working on e-sys via a VM as specified on the ******* site. Not sure if there are different instructions needed for this. Thanks in advance! David
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?" |
02-05-2018, 11:26 AM | #422 | |
Rep 42,932
02-06-2018, 02:25 PM | #423 |
Rep 82
02-06-2018, 04:00 PM | #424 |
Rep 42,932
PM sent.
02-14-2018, 09:07 AM | #426 |
Rep 42,932
I replied to your same PM.
Johnny2501065.50 |
02-20-2018, 07:47 AM | #428 |
Rep 42,932
PM sent.
02-20-2018, 10:19 AM | #430 |
Rep 42,932
None I have ever seen.
02-20-2018, 11:06 AM | #432 |
Rep 42,932
Trial and Error, Google, Phone a Friend, etc.
02-20-2018, 01:27 PM | #434 |
Rep 42,932
Tool32 is powerful. I'd be careful. If you are just doing read (Lessen) functions, you should be fine.
03-14-2018, 07:47 AM | #435 |
Rep 35
shawnsheridan Same for me please I could use the link for Tool32 to clear errors pls.
03-14-2018, 08:32 AM | #436 |
Rep 42,932
PM sent.
03-22-2018, 06:55 AM | #438 |
Rep 42,932
PM sent.
03-22-2018, 06:58 AM | #439 |
Rep 77
I try run lesen_provisioning_data but:
apiJob("NBT","lesen_provisioning_data","","") Satz : 0 OBJECT = nbt SAETZE = 1 JOBNAME = lesen_provisioning_data VARIANTE = NBT JOBSTATUS = UBATTCURRENT = -1 UBATTHISTORY = -1 IGNITIONCURRENT = -1 IGNITIONHISTORY = -1 Satz : 1 RET_STATUS = 255 FF ÿ JOB_STATUS = ERROR_ARG_TYPE any suggestion how to solve this? |
03-22-2018, 07:05 AM | #440 | |
Rep 42,932
Be sure to run Tool32.exe with Admin Rights too.
