08-26-2020, 06:23 PM | #4423 |
Rep 7
When songs play on carplay, there is a 1-2 second delay after the song starts where there is no sound. Is this something that I have to just deal with or is there a solution? I believe it's just a lag from BT to the module, but it happens for every song.
08-26-2020, 08:56 PM | #4425 |
Rep 2
Hello Friends,
So i ordered Carlinkit box from aliexpress and i'm having issue with this box, wonder if anyone experience this problem before ? ( my car is 2015 x5 ) so i install the box into my head unit and everything work expect the climate control dash doesn't want to light up and work. i have narrowed the problem down to either the box take up so much power for the climate control system or my car have problem with electricity by unplugged the box and reconnect all the original wire and the climate control dash work normal. Have anyone experience this before please let me know if i'm on the right track and maybe a way to fix this issue. Thank you. |
08-27-2020, 12:03 AM | #4426 | |
Rep 289
08-27-2020, 12:06 AM | #4427 | |
Rep 289
Also, in any case if it doesnt work dont expect help from the seller, unless you like to take pictures and sending it into black holes. |
Kyokushin48.50 |
08-27-2020, 05:10 AM | #4429 |
Rep 4
Hi guys, I have Andream unit with latest custom software v2 and bimmertech MCU installed, but I still have some problems with AA launch. The phone is paired correctly to the unit and to the car for phone calls, but every time when I open my car the unit ask me on the phone for a new pairing of devices? Is there a way to fix that?
Thanks |
08-27-2020, 06:39 AM | #4430 |
Rep 3
Hi,
i need help. I install yesterday the new Andream NewUI/B-Version in my i3 (from 09/2014) with the long power cable. The Carplay works great, but i have a big problem, the Display flickers / flashes in daylight. In the evening it works without problems. Software is actual installed: 1.0.4 and MCU 20.4.2.14 Have anyone a idea? Thanks |
08-27-2020, 09:38 AM | #4431 | |
Rep 1,217
08-27-2020, 11:51 AM | #4434 |
Rep 129
I looking for something like this:
https://pl.aliexpress.com/item/4000188899756.html but for one USB for green connector, one for MMI, and without aux |
08-27-2020, 12:46 PM | #4435 | |
Rep 4
Andream unit's 12V pins (red/black) on LVDS output can't deliver enough current for CID when at full brightness. I directly connected the two pins (red/black) from HU out to CID in. No need to route the 12V over the Andream MMI. Last edited by knipz; 08-28-2020 at 10:14 AM.. |
skittletop5.00 rokcom0.00 |
08-27-2020, 01:02 PM | #4436 | |
Rep 10
My OEM 10.25" widescreen (i3 2015) doesn't have the best quality when using AA on the MMI, it's okay, but I do notice some noise in the signal. If there's an easy way to clean it up, I'd be really interested in the fix. Thanks. |
08-27-2020, 02:37 PM | #4437 |
Rep 688
So I noticed my steering wheel controls stopped working on the latest OEM MCU update for andream. I then moved backwards on releases to see which would restore my controls. I had to go back to the originally installed 19.12.12 to get the steering wheel controls to work again.
Additionally, I attempted to load the software update immediately after the one that came with it (attempted v2.0.2.7.gpe.b, installed version is v2.0.2.6.gpe.b) and in each MCU version, it wouldn't update the software. It would just reset the MMI every time. Is my unit somehow "locked" to the MCU and software it came with?
2014 Carbon Black 535i M Sport - Bootmod3 / M Performance Exhaust / Carbon Graphite Vorsteiner V-FF 103 / KW V2
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
08-27-2020, 03:10 PM | #4438 |
Rep 1
HUD not working
Hi, after installation andream box version B_V1.0.2
my hud display show just speed info but radio list, contact list and bmw nav not working, and check control not show OK but screen is clear without grean ,,OK,, i think can-bus work not properly ? (steering wheel button works normaly )) what should I do ? has anyone met it? thank you |
08-27-2020, 03:39 PM | #4439 | |
Rep 289
Important for step 2: If your original quadlock has a green 2-pin optical cable, you need to transfer that over to the new quadlock plug or otherwise you will not have any sound. If your quadlock does not have this cable, don't worry, in that case you don't have to do anything. Quadlock and 2-pin cable: |
08-27-2020, 03:42 PM | #4440 | |
Rep 843
No idea why you can't update your unit, either it doesn't like your usb stick (not all work) or your unit might be faulty. You could try the force update method but I would recommend if you do that then start with 2.0.2.7 |
08-27-2020, 03:44 PM | #4441 | ||
Rep 688
08-27-2020, 04:40 PM | #4442 | ||
Rep 7
08-27-2020, 04:44 PM | #4443 | |
Rep 21
andream, android, android auto, apple, carplay, mmi, retrofit |
