BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > PSdZData Full vs. Lite
      09-10-2017, 08:34 PM   #441
shawnsheridan
shawnsheridan's Avatar
Originally Posted by SalpacinoBMW View Post
How to i code VO code and reset? And does that mean I need the PadZdata full version?
Really?
Originally Posted by shawnsheridan View Post
Reset the modules you coded by VO Coding them (right-click ECU select CODE).
And no, VO Coding is CODING not PROGRAMMING, so PSdZdata Full is not needed.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      09-10-2017, 09:44 PM   #442
SalpacinoBMW
SalpacinoBMW's Avatar
Drives: 2012 335i Sedan
sorry i figure out what you were telling me to do, even though it is now obvious, and it did reset any coding i had but. But comfort access still wont lock my doors. Not sure if there is anything else i can try before taking to the dealer and seeing if they can fix. Another think After right clicking ECU and selecting Code, i am able to code the side markers delete but now that i try to code fold/unfold mirrors with key fob/CA it doesnt take it. It wont fold the mirrors anymore. Below are the current settings. Any clue would help. Thanks again for all your help
Module fuction Value
FEM_BODY ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN aktiv wert=01
FEM_BODY ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN AKTIV wert=01
      09-10-2017, 10:45 PM   #443
SalpacinoBMW
and just too add to that, When i go back into code ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN and ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN revert back to nicht_aktiv even when i had changed it to aktiv
      09-11-2017, 10:01 AM   #444
shawnsheridan
If you VO Code FEM_BODY back to factory coding,Comfort Access should be working.
Because you are using CODE instead of Code FDL.
      09-11-2017, 10:25 AM   #445
SalpacinoBMW
Yeah this morning it look like CA to lock the doors is working again. I am using Code FDL after i Activate FA. I will try again tonight and see if i can make it happen. Thanks
      09-12-2017, 12:26 AM   #446
SalpacinoBMW
So i was finally able to code the folding mirrors back. Looks like i was forgetting to KOMFORT_SCHLIESSEN from werte = 0F to werte = 00 . Once i did that it started working. Thanks again for all your help Shawn. Stand up guy.
      09-12-2017, 06:27 AM   #447
shawnsheridan
      09-13-2017, 12:22 PM   #448
d4ve86
Drives: F31 330d xDrive
Hi Shawn,
Been following and trying the F SERIES coding, now looking to try flashing...
Can you please send me a link to the latest psdzdata full files?
Thank you!
      09-13-2017, 01:29 PM   #449
shawnsheridan
Originally Posted by d4ve86 View Post
Hi Shawn,
Thank you!
PM sent.
      09-22-2017, 12:19 AM   #450
alexgarcia
Mexico
Drives: 2016 320i base sedan
Coding Questions from a New User
Hi ShawnSheridan
I am new to the forum and new to the coding f30´s world. I was pointed out to this thread by RSnic as I am trying to get help on coding my 2016 320i for a fog led lights upgrade I just received today, part numbers:
63 17 7 315 559
63 17 7 315 560
I have no idea other than the required software and hardware list RSnic provided me with and I am having a hard time actually finging where to buy them. I was hoping you (or anyone as I would appreciate) could help me with some of the know how to do the purchase and secondly how to do the coding.
Finally I have some idea about the actual codes as I read in posts referring to the same upgrade but since I am new to all this I cant be sure these are what I need speaking of the codes themselves:
FEM_BODY
3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front right
3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front right
3061 NSW_R_IS_LED -> aktiv : LED Foglights front right
3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3061 NSW_R_UE_SPG_SCHUTZ -> dimmed : LED Foglights front right
3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right
3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front left
3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front left
3061 NSW_L_IS_LED -> aktiv : LED Foglights front left
3061 NSW_L_UE_SPG_SCHUTZ -> dimmed : LED Foglights front left
3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left
3062 MAPPING_abbiegel_L_output -> nsw_l : Foglight when turning
3062 Mapping_abbiegel_R_output -> nsw_r : Foglight when turning
3073 KL_ENABLE_RE -> KL_Ein : Foglight when turning
3066 KL_ENABLE_LI -> KL_Ein : Foglight when turning
3073 C_CLC_ENA -> enable : Foglight when turning
3073 C_BLC_ENA -> enable : Foglight when turning
3063 Mapping Nevelschw L Part of WL soft-on nicht_aktiv : Foglight left as welcome
3063 Mapping Nevelschw R Part of WL soft-on nicht_aktiv : Foglight right as welcome
      09-22-2017, 06:38 AM   #451
shawnsheridan
Originally Posted by alexgarcia View Post
Hi ShawnSheridan
63 17 7 315 559
63 17 7 315 560
Codes look correct. PM sent.
      09-30-2017, 12:06 PM   #452
speed608
Malawi
28
Drives: F30 320d
Originally Posted by jsouth View Post
shawnsheridan, please PM the link to Lite. Thank you.
can you please assist with the link for latest psdz data lite .
      09-30-2017, 12:24 PM   #453
shawnsheridan
PM sent.
      09-30-2017, 12:35 PM   #454
speed608
Malawi
28
Drives: F30 320d
PM sent.
Thank you Shawn
      11-11-2017, 05:49 AM   #455
eko_001
Drives: G30
can you please assist with the link for latest psdz data full.
Thx..
      11-11-2017, 08:25 AM   #456
shawnsheridan
Thx..
PM sent.
      11-14-2017, 09:41 PM   #457
kcsmithcyril
kcsmithcyril's Avatar
Malaysia
Drives: F30 320i
Thx..
PM sent.
Hi Shawn,
My aircon ventilation blow direction is not following the setting I selected, when engine started, there is air blow out from the leg but mine setting is blowing on top, wondering is coding can help me resolve this problem ? if yes, which coding line for this setup ? I cannot locate in cheat sheet.
Mine is F30 320i 2014 Dec.
Thanks in advance for the help.
Kenny Chan
      11-14-2017, 10:40 PM   #458
shawnsheridan
Originally Posted by k3nnychan View Post
Hi Shawn,
Kenny Chan
Sorry, I do not know of any Coding to alter this.
      11-14-2017, 10:42 PM   #459
kcsmithcyril
Malaysia
Drives: F30 320i
Hi Shawn,
Kenny Chan
Hi Shawn,
Thanks for the prompt reply, seem like need to visit dealer, haha.
Good day !
Kenny Chan
      11-14-2017, 11:01 PM   #460
shawnsheridan
Hi Shawn,
Good day !
Kenny Chan
Good luck.
      11-17-2017, 12:58 PM   #461
Chri996
Drives: 2014 F31 320d xDrive
Wink
Hi!
can you please assist with the link for latest psdz data full?
Thank you!
      11-17-2017, 02:39 PM   #462
shawnsheridan
Originally Posted by Chri996 View Post
Hi!
Thank you!
PM sent.
