06-11-2017, 05:37 PM | #463 | |
Rep 1,422
06-11-2017, 05:54 PM | #464 |
Rep 25
For those that flashed the ots maps, did your sports display values increased? Mine did not change after the stage 1 flash. It's still showing 320/320. Car is a 335i 6sp.
06-12-2017, 07:47 PM | #466 |
Rep 1,115
Drives: 2015 BMW M235i
06-12-2017, 10:22 PM | #467 |
Rep 1,693
06-13-2017, 12:00 AM | #469 |
@obriennathaniel_f30 on Instagram
516
Rep 1,061
Drives: 582whp/596wtq '13 335i
06-13-2017, 12:01 AM | #470 |
516
Rep 1,061
06-13-2017, 12:34 AM | #471 | ||
Rep 1,422
hardparker297.00 |
06-13-2017, 12:41 AM | #472 |
Rep 1,422
Thanks to PTF for green lighting home builds! I understand anything tech related will have to be troubleshot without the help of PTF but hem allowing us his option at all is nice!
06-13-2017, 01:45 AM | #473 |
Rep 514
completely wrong. I can change HP/torque scale to any numbers, and yes it's showing +- correct hp and torque if tuned correctly. there's absolutely nothing to do with CIC/NBT coding, hard to believe bootmod3 did not find it yet (currently there's scales up to 400hp and 560Nm on my stage1 F30 335xi, can send photo if someone has doubts).
FSociety3859.00 |
06-13-2017, 02:05 AM | #474 |
Rep 514
yes, you are right, just its not tables, but values, which should be altered to get correct hp/torque scales, still havent found these values in diesels if anyone would like to exchange info - PM.
06-13-2017, 02:43 AM | #475 | |
Rep 1,693
I think getting a backup of stock and a backup of MPPSK from the same model car should make it easier to find by looking though the differences. |
06-13-2017, 03:36 AM | #476 | |
Rep 72
06-13-2017, 05:32 AM | #477 |
Rep 514
yes, you're right again - differences can be seen in stock 35i vs mppk also it can be seen in 335i vs M135i software (hp is the same, just in M135i case torque scale is up to 480Nm, while regular 335i - 400Nm)
06-13-2017, 10:44 AM | #478 |
BMW Fanatic
333
Rep 1,075
Pretty sure this is asked, but how can I log using my laptop?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
06-13-2017, 10:52 AM | #479 | |
516
Rep 1,061
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
06-13-2017, 01:42 PM | #480 |
Rep 25
Those values can change with the tune. PTF provided me with a revised stage 1 ots map with the increased values on the sports display. Now it shows 560hp and 480 tq, which is much more than the actual output lol. I've asked for a more accurate representation of my mods.
Diskz53.00 |
06-13-2017, 03:38 PM | #481 | |
IG @bmwF9xG80
3859
Rep 7,614
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
06-13-2017, 08:36 PM | #482 | ||
Rep 1,422
FSociety3859.00 |
06-14-2017, 12:44 AM | #483 | |
Rep 514
560 imho is too much for non heavily modified 335i, 400 or 480hp is good, personally i've chosen 400.
06-14-2017, 08:56 AM | #484 | |
Rep 1,858
Drives: powered by bootmod3
Update: http://f30.bimmerpost.com/forums/sho....php?t=1393956 |
FSociety3859.00 |
