05-13-2022, 12:02 AM | #507 |
Rep 331
Quick reference F30 fitment
rybski Do you have any pics of your car with the Black w/ 2x hyper silver 437's?
Ok, so this is the third or fourth time I've gone through this entire thread, and I LOVE how these wheels look on the F30, and am definitely going this direction thanks to all your cars here that I've seen, they all look so good! For anyone jumping to the end, and just reading this post, here are my thoughts for an F30, mildly lowered (I've got H&R sport springs), as I've been looking for: Only my opinion - Best fitment I'd recommend: 235/40/19 Front and 265/35/19 Rear Followed by: 245/35/19 Front and 265/35/19 Rear 235/35/19 Front and 265/30/19 Rear 225/40/19 Front and 255/35/19 Rear Again, these are only my opinions for anyone looking for a quick answer on what fits without rubbing on a mildly lowered F30, from what I've gathered from this amazing thread! |
05-13-2022, 10:08 AM | #508 |
Rep 103
HA, funny you should ask. I'm currently having tires mounted to the 2x hyper silver. Also installing the VAC monoball control arms. Literally dropped the car off 2 hrs ago. I'll post pics this weekend.
2016 340i M-sport 6MT Alpine White
M Perf LSD - VRSF catless DP - BMS intake - Dorch Stage 2 HPFP - BM3 Stage 2+ MultiMap - Bilstein PSS10 B16s 550i clutch upgrade - OEM 437s PC'd - M Perf BBK - Megan Racing Rear Trailing Arms - VAC Monoball Control Arms |
BMWsE92354.00 |
05-13-2022, 04:56 PM | #509 |
Rep 103
Would probably fit with that suspension, but would really poke. I wouldn't recommend it. But to each his own.
terryd5150507.00 |
05-13-2022, 05:31 PM | #510 | |
Rep 103
Something else to consider is the wear on the tires, if the alignment was off on the previous car then even if they are aligned on yours you might experience strange behavior. (Tramlining thought)
05-17-2022, 10:33 AM | #511 | |
Rep 103
Prismatic Black Base with 2 coats of hyper silver topcoat.
midxotic198.50 |
05-17-2022, 01:58 PM | #512 |
Rep 103
More pics
05-17-2022, 02:05 PM | #513 |
Rep 1,502
Drives: F36 435xd
Looks good but……
Are you running drilled rotor left and drilled/slotted rotor on the right?
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
05-17-2022, 06:16 PM | #514 |
Rep 103
Nope, 370mm BMW dimpled/slotted in front and zimmerman 340mm dimpled/slotted in the rear.
05-21-2022, 01:15 AM | #516 |
Rep 331
[QUOTE=blau3er;28885299]245/35/19 and 265/35/19 here. PS4S and lowered on H&R Sport. Zero rubbing over the last 4 years.
I just picked up my 437m's and bought new Michelin PS4s today!I went with your recommendation... I'm also on H&R sport springs 245/35/19 front 265/35/19 I'll come back and post pics next week hopefully! Just wanted to say thanks |
05-21-2022, 08:13 AM | #517 | |
Rep 638
[QUOTE=Brandons_F30;28928938]
You’ll be happy with that combo |
BMWsE92354.00 |
05-22-2022, 12:29 AM | #518 |
Rep 331
Just had my 437m's put on! H&R Sport Springs, tire size 245/35 & 265/35. Thanks to this thread for making my decision much easier!
06-16-2022, 08:43 PM | #521 | |
Rep 50
255/35/19 and 265/35/19 f30 Xdrive - only 1% diff 245/35/19 and 285/30/19 f30 Xdrive - only 0.3% diff it works need afront offset to be +29 or else no work on a 9" wheel |
midxotic198.50 |
07-04-2022, 05:11 AM | #523 |
Rep 98
Just a question for 437m and lowering.
Did anyone change the bump stops from M cars? The reason i ask is that i already have a set of genuine 437m and about to install some Eibach pro springs, my bump stops are a bit knackerd anyway so thought i woukld change them. My concern isn't about bottoming out, but instead tyre rub on the arch when people sit in the back. I have 245s on the front, and 265s on the back. Does anyone know would the M bumps stops will mean i will bottom out before tyre rub (which i would prefer) as opposed to the tyres catching on the arch before bottoming out (which i would assume to be worse) Or should i just play is safe and replace my standard bump stops |
07-12-2022, 03:40 PM | #524 | |
Rep 499
Drives: F36 440i
08-17-2022, 03:51 AM | #526 |
Rep 98
Had some 437m already but now lowered.
Eibach Pro Kit F8X bump stops. 245/35 front 265/35 back Was worried that the extended bump stops will increase suspension travel and cause rubbing- So far so good even with a more energetic drive and doens't feel any firmed IMO from stock with comfort mode on adaptive. Haven't tried with a loaded car yet though. |
08-27-2022, 04:10 AM | #527 |
Rep 10
New user, first message
Signed up just to post my 340i with 437m's The guy who sold the 437m's took took them off his M3. Currently: 245/35/19, 265/35/19 with KUMHO tyres. I am buying a set of Pilot 4S' on tuesday, new dimensions: 245/40/19, 265/35/19. Edit: I have a PSM carbon spoiler which is ready to be put on the back tomorrow Last edited by -BigMac-; 08-27-2022 at 04:18 AM.. |
08-30-2022, 09:11 PM | #528 | |
Rep 10
I’ve never lowered a car, and have slight poke on the 245/35 265/35 setup atm on stock height. Would lowering it remove some of the poke? Thanks heaps |
437m, f30, rims, wheels |
