11-19-2020, 08:48 AM | #5303 | ||
Rep 58
My MCU version is visible in the attached image (20.6.2.0) Quote:
Thanks Last edited by ckarv; 11-19-2020 at 08:58 AM.. |
11-19-2020, 09:05 AM | #5304 | |
Rep 553
- Steps - 1 With car off plug in iphone to ethernet adaptor, 2 go to iphone settings and wait for ethernet to show up in general 3 Go to bm3 4 App will turn on car It might sound strange but it works for me.
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
lemonchicken250.50 |
11-19-2020, 09:23 AM | #5305 |
Rep 2,595
Are you using the latest legacy firmware for the OBD agent? Or are you using a direct connection?
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
11-19-2020, 09:41 AM | #5306 | |
Rep 78
edit: Just confirm that link received is exactly the same that Kyokushin shared yesterday. Yesterday I tried the link shared by Kyokushin and the zip from first page, both give me error. Last edited by rimsilva; 11-19-2020 at 09:48 AM.. |
11-19-2020, 10:10 AM | #5307 | |
Rep 22
I run the v2 custom firmware with the 20.6.2 mcu on my 2015 f30 with carlinkit and have car bluetooth turned on. No issues. Both AA and carplay. Wireless and wired both work ok.
Could the issue be that your phone isn't set to use cellular data on your wifi? Could partly explain the disconnect as you switch from your home wifi to the car. That you lose internet briefly.. Also maybe you are losing cell coverage because you start car in a parking garage with low coverage on your cell? Something along those lines. Just thinking out loud. Quote:
11-19-2020, 10:34 AM | #5308 | ||
Rep 18
11-19-2020, 10:47 AM | #5309 | |
Rep 22
I have been really happy with the custom firmware over 9.2.9. I get widescreen AA, and the split screen. I also get auto load when I turn on the car and it usually (not always) plays songs where it left off. I think then I use my phone for other music outside the car, that's when I don't get auto play when I return. But the unit almost always starts up and gets me to map split screen which is nice.
I'm not much of an Apple user. But there should be a check box in settings somewhere for your wifi to "allow mobile data when connected" or something like that. I had to make sure that feature was turned on for my phone because when the car connects to the MMI's wifi it doesn't have internet, and so I needed to make sure it uses my mobile when connected. Not sure if that's what's causing you any trouble. but maybe check. I'd suggest you consider trying the custom firmware first. It's really well done and works great with Carlinkit. One of the advantages of this model is that it accepts it. The custom firmware is built off bimmertech's I believe. I know a lot of the improvements were for AA, but maybe it also helps Carplay too. I've struggled a little with AA and Sirius XM. That app on AA seems to lock up and not want to connect to my phone often. And Sirius app on my phone has lousy quality playback yet my Apple's is perfect. Carplay seems much more stable and reliable and I like the layout. I may be going back to Apple next year when my phone can be upgraded! I did test it with my work's phone and am happy with results, but my work gets mad if I use too much data for personal music streaming! LOL! Keep us posted. Quote:
11-19-2020, 11:32 AM | #5310 | |
Rep 40
11-19-2020, 11:38 AM | #5311 | ||
Rep 18
11-19-2020, 12:53 PM | #5312 | |
Rep 439
So, now my lighting to ethernet direct connection theoretically can work for my bootmod3 needs and my bimmercode needs. Unfortunately it can't connect with any of the settings the bootmod3 or bimmercode recommends. this always worked before with my unichip CarPlay mmi. I've updated to the latest firmware from Andream: box says nbt-1904-LC on a sticker Firmware information: SDK:25.0.0.5.6.0.0.0 CUST version B_V1.1.1 MCU 20.8.19.23 HW version BMW_NBT |
11-19-2020, 12:54 PM | #5313 |
Rep 439
11-19-2020, 01:57 PM | #5314 |
Rep 128
Its also in 1.1.2.
What is this slider for volume doing? Here is exact file i flashed. Please note the "GEMINI_PACK.BIN" need to be on root folder of USB drive and need to be only one file. MD5 90f62bc369193746aafe97309acd806a (generated both from file on my usb stick and from zip) i have used FAT32 formatted USB stick, 4096 allocation cluster Please check its not locked: Last edited by Kyokushin; 11-19-2020 at 02:14 PM.. |
11-19-2020, 04:00 PM | #5315 | ||
Rep 333
Can I have the rear facing camera always on? I want to be able to trigger it on demand, either the front or the back. Maybe using the trigger wire and a switch + 12v. But I want to keep the normal operation when parking. |
11-19-2020, 06:06 PM | #5316 | |
Rep 65
Widescreen AA working as well as previous version, and now the AA Autoconnect also working. I initially had the 'Burn Error' on an 8gb usb drive. I then used a 32gb USB3 thumb drive, and that worked perfectly. I cleared all the data for the Android Auto app on my phone, forgot the Bluetooth connection etc, then everything worked well after that. (Andream B MMI NBT on Mini F55 8.8") Last edited by liam77; 11-19-2020 at 06:11 PM.. Reason: Added MMI details |
11-19-2020, 06:14 PM | #5317 | |
Rep 1,217
11-19-2020, 06:34 PM | #5318 | |
Rep 65
I did notice on a recent AA app update on my phone that there was a fix for night mode, so I'll have a better look at the settings for both later: |
muniz_ri447.50 |
11-19-2020, 06:46 PM | #5319 |
Rep 11
Unknown Andream unit CIC
I've searched this thread up and down and couldn't find an answer.
I have an Andream unit for the e series cic, and was looking for an update to fix the resolution android auto aka widescreen fix. The unit is requesting an GEMINI_PACK.BIN update file but the only ones I've found are for the nbt units. Does anyone have experience with this unit? HW_Version: BMW_CICHL |
11-20-2020, 03:57 AM | #5321 |
Rep 59
So, the only difference currently between the Andream B and Carlinkit units is that the Andream B doesn't have the automatic night mode when headlights are on (with the latest official firmware B V1.1.2) and Carlinkit has it (with the v2.0 custom firmware), right?
AA Widescreen and auto load is something that now works on both units with the aforementioned firmware versions? I have the option of purchasing the Andream unit through their website for 218 euros and get it in a couple of days, or the Carlinkit for 260 euros over Amazon but it says "dispatched in 3-5 weeks & arrives Jan 15 - Feb 4"!!! So if the only difference between the two units is currently the automatic night mode, then I would go for the Andream and hope that they solve this issue someday. By the way, these Andream issues are only appearing in AA? What about Carplay? Are there any widescreen issues with Carplay? is there auto load for Carplay? and what about automatic night mode when headlights turn on for Google Maps in Carplay? |
11-20-2020, 05:06 AM | #5322 | |
Rep 78
MD5 90F62BC369193746AAFE97309ACD806A GEMINI_PACK.BIN I believe that i've used the same pen drive off my first update, but i've tried others with the same error. From support they asked to wait for a reply, let see what they will say. |
11-20-2020, 06:43 AM | #5323 | |
Rep 31
Firstly, I wanted to say the work on the custom FW deserves all the praise that it is getting and the work done by forum members is amazing. Thank you to all involved. Keep up the good work!
I am also looking for a custom firmware for my box, and thus far I haven't even found a stock firmware for version B CIC boxes of any manufacturer. One thing I do know so far is that the Software update pin is: 2863 (Like the Andream ver. A CiC box). I can get into flashing menu etc... I suspect the way forward will be JTAG or Telnet if possible. I have a question about the Forum-made CIC custom firmware: Was the CIC custom firmware created using a stock NBT box firmware or have I misunderstood the version numbers listed in post number 2? Sorry for rambling, if I am gonna spend a vast amount of time trying to work this out with a view to eventually creating a Ver.B CIC custom firmware, I may aswell get some words wisdom from experienced forum members, positive or negative! Any help is really appreciated. |
11-20-2020, 10:04 AM | #5324 | |
Rep 1,217
You may want to contact the seller of your unit for the latest updates. |
andream, android, android auto, apple, carplay, mmi, retrofit |
