02-24-2022, 08:50 PM | #529 |
Rep 156
Not sure why everyone complains about stage 2+ on 93. The stock turbo can only go so far no matter what fuel, but my car definitely feels like a different animal on stage 2+ from 0-100. I’ve never dynoed or dragy tested my car, but I can 100% feel the torque increase. It’s been way more violent down low. I have fbo with Dorch stage 1 for anyone wondering.
02-25-2022, 12:10 PM | #530 |
Tom2TerrE
Rep 108
HPFP advice
Any help here is appreciated Tonight i will bring my car to my mechanic for a HPFP upgrade. I would like to know what should i do. Not the best way to do but no too much choices here. Bringing my car with stock HPFP with a map/tune for the new HPFP. Or bringing my car with stock HPFP and stock map/tune, when install done will have an upgraded HPFP with a stock map/tune. So Stock HPFP on wrong tune or upgraded HPFP on wrong tune? It’s not an ideal situation but i’m stock with it. Only few kilometres to do, max 20km. What should i do for less possible damage Thanks for your time and knowledge |
02-25-2022, 12:45 PM | #531 |
Rep 3,986
As far as I know the answer depends heavily on the type of your new HPFP!
02-25-2022, 02:13 PM | #532 | |
Tom2TerrE
Rep 108
I posted in new thread, i wanted to delete it but didn’t find where to do so. I think my best option would be to flash my map offline with Bootmod3. One option that i didn’t think off, Dumy me Thanks |
02-27-2022, 05:22 PM | #534 |
Rep 420
Pure800?
M140IX. Turbo Pure 800 Cast.
03-11-2022, 09:21 AM | #536 |
Rep 1,328
I have a 2016 340Xi.
All things are leaning towards my HPFP beginning to fail. I am looking for recommendations on which HPFP I should go with and from where? The dealership quoted me a steep price. Thanks!
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
03-15-2022, 03:14 PM | #537 |
Rep 122
Yes you should be fine
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
03-16-2022, 12:24 AM | #539 |
Rep 1,454
Depends what your power goals and budget are. Dorch stage 2 future proofs you. TU is a nice, cheap, plug and play option.
2022 CT4-V Blackwing 6-speed
03-16-2022, 11:18 AM | #540 |
Tom2TerrE
Rep 108
03-16-2022, 02:26 PM | #541 | |
Rep 1,514
03-16-2022, 07:37 PM | #542 |
Rep 1,454
I haven't had the cover on for awhile and I removed the foam insulation since it's a tight fit with the Dorch. It is a tad bit noisier in the cabin, but none of my passengers have mentioned anything. I can hear the injectors/HPFP/general engine noise more pronounced but it's no big deal.
03-18-2022, 05:58 PM | #543 |
Novice
316
Rep 700
whats the max power you can run on e30 with DAW turbo and TU pump? they are relatively the same size no? I got the race thrust assembly so im not sure if that has to do with anything. Struggling to reach 23 psi. Slower than OTS stage 2+ e30 map bm3
03-18-2022, 10:20 PM | #544 | |
Rep 1,454
Sell the TU lol.
03-18-2022, 10:46 PM | #545 | |
Novice
316
Rep 700
03-18-2022, 11:03 PM | #546 | ||
Rep 1,454
03-19-2022, 02:39 AM | #547 |
Novice
316
Rep 700
I'm already running 13 degrees timing while being boost limited to around 20 psi with really clean logs. It's a matter of time when to buy the dorch when you're ready. it will be ok to run tu pump for now. i thought it would be able to support more fueling but in reality its only good for stage 2+.
03-19-2022, 02:52 AM | #548 | |
Rep 1,454
03-19-2022, 12:29 PM | #549 |
Novice
316
Rep 700
Unfortunately I only have access to crudy California 91 (( so I really couldnt do 93. But I could do e20 but gas prices are insane at the moment so its not bad to have a bit more ethanol. For sure getting the dorch asap
03-25-2022, 01:32 PM | #550 | |
Cheapskate
4521
Rep 5,003
Stage 2+ targets around 18-19psi last time i had it so I can't see 20-23psi on a DAW being slower than that. |
