01-18-2014, 03:32 PM | #5523 |
Rep 1,573
am i understanding this correct: You can activate sport auto transmission via coding?
can someone verify that this is true? and whats the code I need to activate it?
2015i Cadillac Escalade ESV
01-18-2014, 05:09 PM | #5524 | |
Rep 376
http://www.f30post.com/forums/showthread.php?t=920617 |
01-18-2014, 05:38 PM | #5525 |
Rep 1,573
thanks.
i did ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut ICM/IcmKod_B_S2TBA -> verbaut EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv and got a Chassis stabilization error, althought it went away when i restarted the car. I dont feel a difference in the shifts
01-18-2014, 05:50 PM | #5526 | |
Rep 376
01-19-2014, 01:57 AM | #5527 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
I have activated sport gearbox via coding only one parameter EGS/3000 Applikation -> Sportschalter -> aktiv I have no shift pads and I have no errors on EGS about shift pads absence. You can see a difference in drive with sport or manual mode by yourself. PS. Sport gearbox and Spor+ are different things. Both can be activated via coding together or separately. |
01-19-2014, 02:38 AM | #5528 |
Rep 664
Drives: 2013 BMW 335i
Can you be more detailed on this? And how do you activate launch control?
01-19-2014, 03:24 AM | #5529 | |
Rep 122
EGS 3000 SPORTSHALTER >aktiv EGS 3000 LC >aktiv You need I-step ISTA/P 2.50.4 F020-13-07-506 or newer. To start with LC you need: 1. Warm motor and transmission (run over 10 km) 2. Push DSC OFF buton or use Sport+ mode 3. Push gearshift to S/M position 4. Push brake pedal 5. Push throttle pedal to kickdown 6. You can see LC icon (checkered flag) on dashboard 7. Do not turn steering wheel 8. Release brakes no late then 3 sec expired. Throttle pedal is still pushed. You can make the next start with LC within 5 min or more. Last edited by avgor123; 01-19-2014 at 06:28 AM.. |
01-19-2014, 09:48 AM | #5530 |
Rep 1,573
so after realizing i forgot to code Sportschalter to aktiv, i can confirm I was able to successfully code SAT and it works.
I notice it more on the 1-2-3 shifts...not so much in the higher gears. never the less its cool and I see what gears I am in in DS mode
01-19-2014, 12:12 PM | #5531 |
Rep 383
Hi Everyone- I tried coding to have my mirrors fold in/out when locking/unlocking using the fob or comfortaccess locking/unlocking. Didn't work... Maybe I'm using an outdated F30 cheat sheet for my 2014...? Can anyone post what to code to confirm? I would appreciate it. Thanks.
01-19-2014, 12:27 PM | #5532 | |
Rep 1,892
FEM_BODY / 3110 / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN -> aktiv FEM_BODY / 3110 / ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN -> aktiv FEM_BODY / 3053 / KOMFORTSCHLIESSUNG_FB -> aktiv (NOTE: aktiv = 00 is correct, do not change the werte value!) FEM_BODY / 3053 / KOMFORT_SCHLIESSEN -> werte to XX (Button push delay time to fold mirrors in 100ms/unit, typically set to 03 (300ms)) |
01-19-2014, 12:52 PM | #5533 |
Supreme Being
1806
Rep 5,425
Quick question to the veteran coders.
I have completed lots of successful coding in my F30 but now want to complete a couple of my wife's F20. Question: does it have the capability to VO code Enhanced Blue Tooth? It's a 2012/08 build Currently has 6NH (BT Phone with USB interface) BMW Professional CD (entry level system?) No Nav As follows: S663A Radio BMW Professional S6AAA BMW TeleServices S6ABA Control for Teleservices S6NHA Hands-free with USB interface I don't know enough about the F20 to physically check for a COMBOX - does this make a difference with the above spec? If I can code, which model do I select on VIN connect - assuming I can used the same software/hardware as I do the for F30. Any other tips welcome, I have the coding bug! Thanks
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
01-19-2014, 01:08 PM | #5534 | |
Rep 1,985
Drives: 2020 G20 320i M Sport
I believe your wife's vehicle does have a telematics combox so it shouldn't be a problem changing it to 6NK.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-19-2014, 01:08 PM | #5535 | ||
Rep 664
01-19-2014, 01:45 PM | #5536 | |
Rep 122
http://www.f30post.com/forums/showpo...postcount=4659 Kickdown is a a method of changing gear in a car with automatic transmission, by fully depressing the accelerator. I mean you should fully depress the accelerator pedal to click the kickdown switch. |
01-19-2014, 01:54 PM | #5537 | |
Supreme Being
1806
Rep 5,425
Any idea where it's physically located in the F20?
01-19-2014, 02:50 PM | #5538 |
Rep 1,985
It should be in the boot just like on the F30 no?
01-19-2014, 03:17 PM | #5539 |
Supreme Being
1806
Rep 5,425
I thought so to, but if it is we don't have it - just the battery and fuse box (unless its hidden beneath).
I don't want to code and screw something up by not having a combox! I'll connect up the E-sys tomorrow to see what modules I have, if its CMB_Media I need to should be clear.
01-19-2014, 03:27 PM | #5540 | |
Supreme Being
1806
Rep 5,425
01-20-2014, 05:53 AM | #5542 |
Rep 41,224
PM sent.
01-20-2014, 07:43 AM | #5543 | |
Rep 9
Drives: G20 3.30i
Hi,
My I-step is F020-13-03 however i can find the related codes in esys. Even though the codes exist, are you sure that i can't use launch control with this I-step? thanks. Quote:
01-20-2014, 08:16 AM | #5544 |
Rep 122
