07-14-2018, 08:24 AM | #551 |
Rep 132
Thanks, I will report the issue to Louie.
Blank Screen: - black screen, without text, no white lines - Android is still running, I hear music and navigation voice restart by shutdown car Last edited by wacky007; 07-14-2018 at 10:19 AM.. |
07-14-2018, 11:52 AM | #552 | |
Rep 118
BTW these are the apps and services allowed to run in background, everything else will be killed: musicPkgLst = {"com.android.music", "cn.kuwo.kwmusiccar", "cn.kuwo.player", "com.kugou.android", "com.kugou.playerHD", "com.sds.android.ttpod", "com.tencent.qqmusic", "com.tencent.qqmusicpad", "com.duomi.android", "com.mxtech.videoplayer.pro", "com.maxmpz.audioplayer", "com.jetappfactory.jetaudioplus"}; sysApkLst = {"com.estrongs.android.pop", "com.unisound", "com.szchoiceway", "com.choiceway", EventUtils.PHONEAPP_MODE_PACKAGE_NAME, "com.baidu.baidumaps", "com.alensw.PicFolder", "com.android.settings", "com.mxnavi", "com.autonavi", "com.cld", "com.baidu.BaiduMap", "cld.navi", "com.android.systemui", "com.tencent.mobileqq", "com.tencent.mm", "com.uc.browser.hd", "com.kingwaytek", "com.papago.M11General", "com.loco", "com.sygic.aura", "com.anwensoft.cardvr", "com.navngo.igo.javaclient", "com.tencent.map", "com.mapbar.android", "com.uu.uunavi", "com.mapbar", "com.zxwtxz.sdkdemo", "ru.yandex.yandexnavi", "com.navitel", "com.nng.igo", "com.navngo.igo", "com.mng.igo", "com.garmin", "com.skt.tmap", "com.txznet.txz", "com.aispeech.aios", "com.nng.igoprimoisr2013march24.javaclient", "com.aispeech.aios.bridge", "com.mireo.dontpanic.android.incyclone", "com.example.administrator.eqsetapplication", "com.here.app.maps", "com.waze"}; |
07-14-2018, 01:59 PM | #553 | ||
Rep 201
07-14-2018, 02:57 PM | #554 |
Rep 606
07-14-2018, 03:25 PM | #555 |
Rep 102
07-14-2018, 04:36 PM | #556 |
Rep 2
I have a problem with no sound, from the android side.
i have try to increase the aux volume in oem but nothing is happening, the only thing i can hear is a high frequency noice if i speed in waze or something, Have any one have any simular problem? I have double check that the optic cabel is plugged in, Can the combo box cause this? is there a way of fixing this? |
07-15-2018, 05:14 AM | #557 |
Rep 118
07-15-2018, 06:03 AM | #558 | |
Rep 606
Have you checked the audio setup in the ugode factory menu? There are several setting for audio (like hk or alpine) and also output volume of the ugode and aux.input that can be muted... |
07-16-2018, 03:44 PM | #559 | |
Rep 2
i will try different sources like hk or apline. the aux input is muted in the oem or at the lowest and it is not possible increase. Im thinking of hand in the car to bmw to fix the aux thing, |
07-17-2018, 03:35 AM | #560 | |
Rep 606
that way it stays alive since it is according to one of the names on the list... Just a thought? |
07-17-2018, 04:00 AM | #561 |
Rep 102
I have updated the latest android software that DRuw shared with us and I have the same waze issue.
After the unit boot time of aprox 40 seconds, the music player starts playing the mp3 files from the usb. So far no issues. I start waze and now the music intermittently stops as the processor can't handle the load. Anyway, after 30 seconds the music is OK but waze doesn't have audio (voice guidance) I have to restart Waze and the second time, everything is OK... I have disabled many apps from google, nothing helps. The only option left is to uninstall Spotify? Please feedback if you have the same issue |
07-17-2018, 04:36 AM | #562 | |
Rep 8
07-17-2018, 04:42 AM | #563 |
Rep 102
Ugode.
Update: forgot to mention that while Waze voice is not working, the performance is rubbish, struggling to find the route, freezing, etc. After restart it's working very well. It's annoying because each time I start the unit, I hace to restart Waze Last edited by florinbrv; 07-17-2018 at 05:02 AM.. |
07-17-2018, 05:21 AM | #564 | |
Rep 118
I have hacked things in rooted devices, but its not the case with this unit. |
07-17-2018, 10:47 PM | #566 |
Rep 606
07-18-2018, 01:49 AM | #567 |
Rep 210
FYI: yesterday I managed to connect GPS splitter cable (https://www.aliexpress.com/item/Fakr...852595449.html) in order to use BMW GPS antenna in ugode and it didnt work (I got wrong altitude, very long time to connect to satellites and very unstable satellite connections). BMW Navigation works fine with the GPS splitter cable.
Anyone with similar experience? |
07-18-2018, 07:47 AM | #569 |
Rep 689
Here's one Louie sent me:
https://mab.to/6hez2RDvdlM I downloaded it last night and will install when I get home from work today. This morning, when leaving for work I noticed my doors were already unlocked, which was unusual, and of course I got the no signal screen when I started it up. Hopefully the new software works for me like it has for DRuw. |
07-18-2018, 08:58 AM | #570 |
Rep 606
I received other software totdat as well, which should.improve google map performance.
This is the link: https://mab.to/ItM0o0sFn Dont know when I can try it since im on holiday since this morning for 2 weeks.... Louie said it also includes a new MCU file. Cant wait to try Unit is performing ok during my 600km drive today. 250 to go in a few minutes and this far only some waze hangups solved with restarting waze. |
07-18-2018, 09:06 AM | #571 | |
Rep 689
07-18-2018, 11:06 AM | #572 |
Rep 606
If its good for you and you dont have the current software to reinstall, dont update i would say.
"Never change a winning team" I like to mess with the system a bit and currently have 4 software versions at least |
