03-24-2023, 04:18 PM | #595 |
Rep 33
Drives: 2019 X5 40i
Hey guys, Just got into nodding my 2019 b58 x5. Did the catless dp, intake and JB4 but just found a shop to unlock the DME so I can flash with MHD or BM3, still undecided. The 2019 x5 has the b58tu, so am I completely safe running an E30 mix? Based off the info available, I assume so, but have yet to find anyone in a g05 doing it. Any information would be great! Thanks
03-27-2023, 12:55 PM | #596 | |
Rep 294
Drives: 2018 440i xDrive Gran Coupe
05-03-2023, 09:38 PM | #597 |
Rep 12
i am currently installing a B58TU pump along with my new Cast pure 800 turbo. will i also need to add bigger injectors with this pump or will the stock ones suffice?
05-03-2023, 09:50 PM | #598 | |
Rep 247
1, the TU pump is going to bottleneck you way before the injectors 2, there aren't bigger injectors. |
05-04-2023, 09:31 AM | #600 |
Rep 1,514
Small market update:
Spool FX180 has been discontinued and replaced by the FX200. Flows a bit more fuel and they suggest running their Stage 3 LPFP. They now offer a fuel line for additional $100 if you dont want to bend and use your original. |
05-05-2023, 05:43 AM | #601 |
Rep 590
The upcoming Spool Performance FX-350 HPFP will be interesting to see. Its good to see R&D for the HPFP on this platform continue.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
05-07-2023, 09:10 PM | #602 |
Rep 12
i just installed my b58 tu pump today and it looks like its not sitting all the way flush. anyone else experience this or is it supposed to look like this? no gas leaking when you open the doors to activate electric pump but scared to start it yet
05-07-2023, 11:10 PM | #603 |
Novice
316
Rep 700
The DS2 and FX200 are already at the limits of what our stock injectors can flow. Spool and another company are R&Ding upgraded injectors for this platform. Only alternative is to go port injection right now. There is only so much fuel you can flow at redline with these injectors.
05-07-2023, 11:58 PM | #604 | |
Rep 590
current
05-08-2023, 01:35 AM | #605 |
Rep 3,987
Looks perfectly fine to me? There is a gasket there, so an even gap is normal. I assume you used the correct torque to tighten it?
05-08-2023, 06:34 AM | #606 | |
Rep 190
The gasket is take care of the gap. You can enjoy E30 map ! |
05-08-2023, 04:17 PM | #607 | |
Rep 12
yes the gap is even just wasnt sure if it was supposed to sit flush or not. thanks for the help |
06-18-2023, 10:45 PM | #608 |
Rep 35
Drives: G30
! HPFP Left out
So here's the deal. I committed to the expenses involved with common upgraded parts and software. What I forgot to include in my budget is the most expensive piece to this upgrade project. In preparation of Stage 2 on G30 540i I have gathered the following:
Tune: License from BM3 (Stage 2) Catless: VRSF Cold Intake: MST It is my understanding that the item I forgot to include in my purchases is required to run Stage 2. To what degree, if any, is there a benefit to installing the Catless and Cold Air without the fuel pump and without the Stage 2 tune? It is also my understanding that any hpfp will be a minimum of $1100 - $1600. Are there less expensive options available? It may be a difficult decision to invest another $1K for the added whp, but if absolutely necessary, I've come this far and will do it, but daaaaannng! Any thoughts, concerns, ideas, experiences would all be appreciated. Thanks you guys!
Wave upon wave of demented avengers march cheerfully out of obscurity into the dream. -pf
06-19-2023, 06:55 AM | #609 | |
Rep 556
Drives: 2019 440i XDrive GC
If you want, you can get a TU pump (from the gen2 B58) for about $500 that should be more than capable unless you plan on upgrading your turbo at some point. Stage 2 fuel pumps (from dorsch and other brands) are in the $1,000 range and typically necessary on upgraded turbo cars and cars wanted to run a high ethanol blend.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
06-29-2023, 06:34 PM | #610 |
Rep 44
Pump pressures
Guys - I was hooning around today and heating things up so I could park the car and check for leaky injectors. Monitoring HPFP target versus actual. Is this big of a delta normal? Running a recently intsalled TUPump on a GEN1 B58.
Max target pressure = 2883 psig Max actual pressure = 3066 psig Need to know if I should be concerned because that looks like a big delta to me. |
06-30-2023, 03:08 AM | #611 | |
Rep 118
08-23-2023, 12:26 PM | #613 |
Rep 96
Hey does anyone know if either the TU or dorch stage 1 would be able to run E50 on the MHD stage 2+ E40 map?
Got some crappy fuel where I am so need to run extra E. |
09-28-2023, 05:58 AM | #614 |
Rep 556
Good morning,
Currently in France (SP98 max) with an M140i Xdrive stage 2 (MHD OTS) I am equipped with MASATA decatalizer and BMC air filter. The announced power is 450 hp with this configuration (B58 GEN1) Question: Can I hope to reach (approximately) 500hp with the Stage2+ HPFP card from MHD and this pump (TU supra) please? https://www.auto-doc.fr/bosch/16608990 |
09-28-2023, 06:19 AM | #615 |
Rep 3,987
Not on RON 98 fuel. 450-460 is the max you can achieve with RON 98 on Stage 2+
You need RON 102 or Ethanol blends (E30/E40) for more than that.
F20_M135i100.50 |
10-06-2023, 08:59 AM | #616 | ||
Cheapskate
4521
Rep 5,003
