08-27-2012, 12:15 AM | #617 |
Rep 1,544
08-27-2012, 12:17 AM | #618 |
Rep 1,544
08-27-2012, 02:22 AM | #619 | |
Rep 145
Drives: F30 320ed
That's correct! Live was not on my car before I coded it. No navigation fitted, just standard UK equipment including standard Bluetooth equipment. Last edited by demge01; 08-27-2012 at 03:13 AM.. |
08-27-2012, 02:28 AM | #620 | |
Rep 145
Drives: F30 320ed
Once done the tethering function starts automatically when you open Live (as long as Bluetooth is connected first) Last edited by demge01; 08-27-2012 at 03:12 AM.. |
08-27-2012, 09:49 AM | #621 |
Rep 169
08-27-2012, 10:17 AM | #622 | |
Rep 42,932
http://www.f30post.com/forums/showpo...&postcount=568
08-27-2012, 12:02 PM | #623 |
Rep 1,544
Btw, is office function already on ur system before coding? Did u see the option to use coding to enable BMW office? What is the entry to enable BMW Live?
08-27-2012, 12:15 PM | #624 | |
Rep 42,932
CONNECTED_DRIVE = aktiv / Werte=01 ONLINE_BROWSER_LIVE = aktiv / Werte=01
08-27-2012, 12:33 PM | #625 |
Rep 145
Drives: F30 320ed
I tried just the ONLINE_BROWSER_LIVE activation first and that worked.
There was no need to activate the Connected Drive. I've been further testing today and Live is fully functional - working best when I have 3G reception. I couldnt see any ref to activating Office - I'll look again. I dont have office already. |
08-27-2012, 12:57 PM | #626 |
Rep 42
Drives: 2013 335i M-Sport
Another user with a shout-out to svache and shawnsheridan! Good advice, guides and assistance along the way.
Couple of questions.... Headlight washers active or not active....on mine default was active 00, but guide shows active 01. Typo in the guide? Or do I need to go wert 01 to deactivate? Comfort access folding mirrors....guide says to also add ASP_BEIKLAPPEN. Where and what changes? Lastly, is there a way to browse the files offline so I can see where things are? Thanks.
2013 335i M Sport - Estoril Blue II / Black Leather
08-27-2012, 01:39 PM | #627 | |
Rep 42,932
As for browsing files off-line, yes. In E-Sys, the CAF-Viewer is for viewing CAFD Files, and the FDL-Editor is for viewing NCD Files. The NCD Files are your net-coded data file (NCD), which are generated automatically every time you read an ECU, so what you see in the NCD is your current coding for that ECU. Look in these locations for the files: NCD = C:\ESysData\CAF CAFD = C:\ESysData\psdzdata\swe\cafd I suggest when you read your ECU, you make note of the CAFD file name so later you know which NCD File corresponds with which ECU. For example: HU_CIC = CAFD_000000F9_006_008_207.ncd
08-27-2012, 02:15 PM | #628 |
Rep 1,544
08-27-2012, 02:39 PM | #629 | |
Rep 145
Drives: F30 320ed
EDIT: I think the reason I cant have Office is down to my iPhone 4's compatibilty with the F30. Last edited by demge01; 08-27-2012 at 04:02 PM.. |
08-27-2012, 03:15 PM | #630 | |
Rep 63
the text you refer to states "Therefore EVEN IF your vehicle is not equipped with a BMW Navigation system you can still have access to all the information you need along your journey" "EVEN IF" means whether or not. regardless of. |
08-28-2012, 06:23 PM | #632 |
Rep 42,932
Do you have 6VC Combox?
08-29-2012, 07:49 AM | #635 |
Rep 42,932
Then there must be a MULF Module, which would require the VIN change.
08-29-2012, 07:50 AM | #636 |
Rep 42,932
Who has it working in the U.S?
08-29-2012, 07:59 AM | #637 | |
Rep 69
Well, almost working...at least he has the menu for it. Probably just a phone setting he needs to get it fully working. |
08-29-2012, 09:01 AM | #638 |
Rep 145
Drives: F30 320ed
