05-11-2014, 04:22 PM | #6535 |
Fee
Rep 249
Drives: F82 SO M4
05-12-2014, 07:57 AM | #6537 |
Rep 28
Do you guys know how much an HUD retrofit would cost and where can i buy it from? I saw an online retailer called elebest singapore but they haven't responded to my requests.
I would want to do my own installation and coding. |
05-12-2014, 12:26 PM | #6538 | |
Rep 130
I mean, the HUD is good, but not THAT^^ good TBH... |
05-12-2014, 02:41 PM | #6539 | |
Rep 1,574
it wasnt really confirmed that you need a new windscreen, never the less the cost to add HUD is still not worth it.
2015i Cadillac Escalade ESV
05-13-2014, 06:33 AM | #6540 |
Rep 3
Based on the f30 cheat sheet i was able to code the sports display on a f30 320D EDE 2012 (EFF_DYN_SPORT_CID)
Cheat sheet says it didn't work on the diesel versions but i was able to succesfully view the menu! Cheat sheet can be updated. |
05-13-2014, 06:58 AM | #6541 | |
Rep 3,257
Drives: 2024 M340i xdrive
05-13-2014, 02:56 PM | #6542 |
Fee
Rep 249
Drives: F82 SO M4
05-13-2014, 06:37 PM | #6543 |
Rep 61
What does the sport display do?
05-13-2014, 08:30 PM | #6544 |
Rep 42,973
05-14-2014, 06:55 AM | #6545 |
Rep 4
3.23.4 with 50.3 PSdZData
hello
i have 3.23.4 with 50.3 PSdZData but it is not working i dont know if it is token problem it shows no connections please can you send me a link? thanks in advance |
05-14-2014, 07:05 AM | #6546 |
Rep 42,973
If your Target Connection Window is empty, it means your PSdZData is not installed properly, or E-Sys is not configured properly to locate it.
05-14-2014, 07:08 AM | #6548 |
Rep 42,973
PM sent.
05-14-2014, 07:40 PM | #6549 | |
Rep 1,994
Drives: 2020 G20 320i M Sport
I think the KOMBI does have something to do with the Active Blind Spot Detection so it may be the difference in firmware that's causing the conflicts. I don't think flashing HU_CIC would do anything since I've fitted different NBT Head units into my car with various versions that never interfered with any of my existing systems.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 05-14-2014 at 07:47 PM.. |
05-15-2014, 06:52 AM | #6550 |
Rep 385
Is there a hidden menu that can be coded to show state of battery? I think mine isn't charging fully and therefore my auto start stop isn't working well.
05-15-2014, 11:39 AM | #6551 |
Now in the dark side !
68
Rep 1,134
Good for you !
Jokes aside, you should pay a visit to your stealer to see what's happening. Or go to a local car electric specialist if the dealer's too far. An analysis of the battery - charge system isn't too expensive, and if there's a fault, bring the invoice to your dealer and they should refund it.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
05-15-2014, 12:59 PM | #6552 | |
Rep 1,892
You can also get the current battery voltage through the secret instrument cluster menu. See this thread: http://www.f30post.com/forums/showpo...97&postcount=1 You just have to unlock the menu and cycle the menu to Voltage and select it. |
05-15-2014, 02:49 PM | #6553 |
Rep 58
Drives: 435i X-Drive M Sport ('13)
Hello!
I have e sys 3.23.4 and psdz version 4.7.0 I used it to code my F32 but I went to the Garage and they updated to F020-14-03-500. And I can t code it back, I keep having errors (cafd_xxx.. Not found) What do I need a new version of anything ? If yes could you send me a link ? Thanks for the insights |
05-15-2014, 03:12 PM | #6554 | |
Rep 42,973
PM sent.
05-15-2014, 06:51 PM | #6555 |
Rep 387
What is the complete set of codes to enable sailing?
I coded EGS 3000 Sagin -> Aktiv And just that didnt work.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
05-15-2014, 07:08 PM | #6556 |
Rep 1,574
i dont think you can enable sailing on all cars
