07-07-2022, 01:20 PM | #46 | |
Rep 1,650
Runner340369.50 |
03-12-2023, 01:36 PM | #47 |
Rep 98
Drives: BMW 335i xDrive
I just installed front Hawk 5.0 pads HB765B.664 and they did not have the weights (although they still have the ears that hold them). I was honestly a bit taken back when I got them out of the package. I purchased from FCP and they only had a photo of the box when I ordered, however after looking at them on other sites including Hawk’s the product photos show no weights. I installed them as supplied (photos attached) and performed the bedding process last night without issue or noise. Have not had a chance to drive the car again since performing the bedding process.
03-17-2023, 08:17 AM | #48 |
Rep 16
@slowF30 How did those Hawk pads hold up for you? I'm thinking of putting on a 2018 F36 with MSport brakes...I just bought the OEM pads but worried about brake dust. My installer said if I don't want squealing I should go EOM. Are the Hawks quiet?
03-20-2023, 07:02 PM | #49 | |
Rep 54
I am currently running the 5.0 pad on the front of my 340mm non m sport 340i I am running a riveted Zimmerman Dimpled and slotted rotor from FCP, pads do not have the weights and I got those from Amazon The pads do make some noise on low speed braking,(going into or backing out of parking is when it’s most noticed) not often but it deff happens more then it did with my stock pad The dust is not anywhere near as bad as OEM but it’s there, in my bronze ARC 8 I do notice On my plastidipped black 400m winter tire set up I do not notice However in the rain they deff need to be pumped a time or three before they actually grab the rotor |
03-21-2023, 07:07 AM | #50 | |
Rep 5,410
If you have to pump brakes in rain it is because water is between pad and rotor. It has absolutely nothing to do with the brand of brake pad. For better brake performance in rain, switch to full crossdrilled rotors. The holes prevent water from trapping between rotor and pad. BMW installs full crossdrilled rotors on M2/M3/M4. |
03-21-2023, 04:18 PM | #51 | |
Rep 23
"Sacrificial coating is a type of metal coating which will undergo oxidation more than the metal surface that it protects. The best example of this type of coating is zinc-coated steel or galvanized steel. More active sacrificial coating dissolves, depending on the anodic reaction. The electrons released by dissolved zinc or coating atoms will flow to that part of metal that is protected, turning it into a cathode, thus preventing corrosion of the metal." |
03-24-2023, 08:27 PM | #52 |
Rep 98
For what it’s worth…I’ve put 1,000 miles on my new Hawk 5.0 pads over the past 2 weeks and have zero squealing or noise. Like I shared in my previous post, my Hawk pads did not include weights, and I also chose not to apply any pad grease. I’m running regular (flat face) Zimmerman rotors that are a little over a year old. My driving has been a good mix of short local trips to triple digit highway speeds, as well as both wet and dry conditions. I’m very happy with the pads so far, good feel and no noise, so I appreciate the recommendations from others here on the forums.
03-26-2023, 12:03 PM | #53 | |
Rep 21
03-27-2023, 04:21 AM | #54 | |
Rep 5,410
M Performance calipers are identical (except for their red, orange or yellow color) to Blue M Sport calipers that are Blue Front 370mm and Rear 345mm. Rotors are different because MP brakes come with dimpled & slotted rotors. Now those rotors definitely make noise which is really apparent when driving next to a highway center barrier that reflects the sound back to the driver |
03-27-2023, 11:42 AM | #55 | |
Rep 21
From what I’ve heard, the clack (it literally makes a sound like: CLACK) is the pads shifting slightly because they don’t fit 100% perfect. Some say it is because the backing material is too thin and the fit isn’t right, so they slide, others say the retaining pin slot on the pads is too wide for the pin. Good to know yours don’t clack. But now I wonder how to fix it. |
03-27-2023, 07:14 PM | #56 | |
Rep 5,410
03-29-2023, 09:00 AM | #58 |
Rep 131
With the viscosity of that paste I'd think it nearly impossible for them to slide around fast enough to make noise, if properly applied. I followed the manual for application and they've been silent for the last 7k miles. The pads shouldn't have no clearance between them and the stationary parts like the guide pins and the guide surfaces on the caliper, there will always be a little bit of play as intended.
03-29-2023, 09:10 AM | #59 | |
Rep 21
I agree that enough paste should prevent the noise. |
08-19-2023, 12:16 PM | #60 | |
Rep 1,199
A little click is normal for the front 4 pots. The pads can't be a perfect slip fit or they'll get jammed up so the slight clearance allows them to shift in the caliper. 100% normal. As for these HPS 5.0 Pads, I'm not very satisfied with them right now. They started squealing pretty badly. When I removed the fronts to clean and lubricate again, the inboard pad backing was worn through to the metal so that's what's squealing. I applied more ceramic paste but that didn't solve the problem. Not sure why this happened as I had no such problems with these 4 pots and Ferodo DS2500 on my E82. These pads also just feel pretty weak. Really requires a lot more braking force than I'd like to get to the limit of the tires. The bite just isn't there either. And I don't mean it's not equivalent to the stock high bite pads, but it's probably weaker than a ceramic Akebono which have notoriously weak bite. Some of the drive feel/performance may be partly my shit Conti run flat tire's fault. Just ordered PS4S so we'll see if that makes things feel any different under hard braking (not talking about pedal feel). If a bedding session doesn't solve the squealing then I'm pad slapping something else on these rotors. Here is a picture after about 10,000 miles of city and highway driving around the South Bay in LA:
08-21-2023, 01:00 PM | #61 | |
Rep 1,372
We had a Porsche 918 show up to an HPDE and while I can't remember the colour I do remember the G37 that ping-ponged off two walls then slammed into the second wall he hit, going backwards, when it's genius owner wondered if cheapo tires would be okay on a damp track. Turns out, they're not. Everyone at the track says "Take it easy out there" and no one ever does. Get the gear you need because you sure as hell can't rely on 'taking it easy' when behind the wheel of a 300 hp+ machine. So Hawk 5.0, as Hawk says, not for the track. HP+ are fine at the track I drive at which has a lot of fast turns (except for one, the aforementioned 'brake or die' turn). If you're hitting a more technical track, I'd go for something more aggressive.
johnung4552.50 |
09-11-2023, 12:53 PM | #62 |
Rep 2,664
I hate these pads. I removed, regreased, followed BMW's instructions. Rinse, repeat 5 or 6 times already. These pads squeal and don't ever stop squealing. I removed them for the last time and temporarily replaced them with a set of Autozone Duralast Gold pads for all four corners. Guess what? ZERO noise.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
09-11-2023, 09:09 PM | #63 | |
Rep 1,199
Yeah they suck. See my post above. Bought brembo ceramic that are many times better and actually cost significantly less. Will never buy hawk again.
09-14-2023, 05:42 PM | #65 |
Rep 1,372
That's pretty serious. Did you contact Hawk? But if the material separated from the backing plate, wouldn't you have metal on metal? The backing plate is held into the caliper with the pins but the braking material is affixed to the plate using lots of little teeth on the plate which dig into the braking material. I'd imagine if just one pad had such a failure you'd notice right away.
01-31-2024, 02:10 PM | #66 |
Rep 67
I know this is an older post, but I wonder if Hawk HPS are better than HPS 5.0, even though the temperature ranges look better on the 5.0?
I've used Hawk HPS on the street for years on my Subaru and my Solstice and really liked them. I've tracked my Subaru and used several track pads (Carbotech XP8/10/12). (And as noted, I'd never take a purely street pad on a track...at least step up one level (e.g. HP+ minimum, etc.)) I called Hawk before putting them on my Solstice GXP and they said if you are more performance oriented and are used to tracking, etc., on the street they suggested HPS (older) vs the newer HPS 5.0, perhaps mostly for feel. Surprises me 5.0 are having some troubling reviews. I've like the stock pads on my BMW so far...I wonder if I should just stick with those. Or I may just get the older HPS and not the 5.0. |
