06-22-2017, 04:37 AM | #45 | |
Rep 450
06-22-2017, 01:25 PM | #46 |
Blocked from G80/G82 for having an opinion
3517
Rep 3,754
PPI checks out, car just needs Inspection service and new rear brakes. There are some normal M3 leaks (diff seal, oil pressure valve, and leaky transmission seal). Should I be worried about the transmission seal? There was no CEL or codes for the vanos or SMG itself. All recalls are up to date. Rear subframe appears to be ok but they didn't unbolt anything.
What do you guys think? Price is really good and allows room for me to do the maintenance and some refurbishments and still stay in budget. |
06-22-2017, 02:00 PM | #47 | |
Emperor
1614
Rep 2,764
CPV leak ("oil pressure valve") is a $5 fix after which it's good forever. Transmission seal-- which one? Some are no big deal/easy fix, some are more work. All of them are cheap if you DIY. Diff seals-- weeping or leaking? Weeping is normal, can be ignored. Leaking will need to be addressed, will costs $500-1000 depending on the shop. Or $30 if you DIY :P Inspection 2 (every 50-60,000 miles) is a pretty comprehensive service-- oil, trans fluid, diff fluid, valve adjustment, fuel filter, spark plugs, engine air filter, cabin air filter. If you're paying someone to do the work, that'll be another $1000-1500. Or ~$250 if you DIY.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
06-22-2017, 07:33 PM | #48 | |
3517
Rep 3,754
06-23-2017, 06:16 AM | #49 |
Emperor
1614
Rep 2,764
CPV: http://www.m3forum.net/m3forum/showthread.php?t=358941
(use the seal, not the whole part-- it's both better (forever) and cheaper) Diff output seals (simple DIY, but it's a simple process): http://www.m3forum.net/m3forum/showthread.php?t=218070 Don't know which trans seal it is-- and I'm suspicious it's a rear main seal, anyway, because the trans seals on the e46 rarely leak. But, without knowing more, can't provide a diy. Inspection 2: Fluid swaps are just drain/refill (which the diff/trans starts overflowing out the fill hole, it's full). Valve adjustment DIY: http://www.m3forum.net/m3forum/showthread.php?t=450097 While you're doing the valve adjustment, spark plugs are just unscrew/screw in. M3Forum has a tool rental thread (e.g. for the special tools to do a valve adjustment): http://www.m3forum.net/m3forum/showthread.php?t=564377 And DIYs for almost anything on the car can be found here: http://www.m3forum.net/m3forum/forumdisplay.php?f=60
06-23-2017, 09:20 PM | #50 | |
3517
Rep 3,754
06-24-2017, 07:29 PM | #51 | |
Rep 11,765
Drives: 2018 M4 Comp Indv
MFNATIK3516.50 |
06-27-2017, 01:16 PM | #53 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Where is your E46 with pics??
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
06-27-2017, 04:56 PM | #54 |
3517
Rep 3,754
Haha, I didn't forget. It was so covered in bugs that I didn't want to post dirty car pics. Here are some before we headed home and some shots along the way. The car itself was FILTHY from not having had a pro detail for some time. I've started the cleaning and refurbishing process. Hopefully I can post a finished product that I can be proud of in a few months (it needs a new bumper and some touch up on the body panels).
GrussGott18225.00 |
06-27-2017, 05:06 PM | #55 | |
Rep 8,852
MFNATIK3516.50 |
06-27-2017, 05:16 PM | #56 |
3517
Rep 3,754
06-27-2017, 05:29 PM | #57 |
Rep 8,852
Oh, I didn't even notice that. I thought it was your attempt to show your FOUR Bimmers in the driveway.
06-28-2017, 11:37 AM | #59 |
Rep 464
Congrats! love the e46 vert f80 combo. I have the same in my garage and appreciate the practically of both vehicles for whatever you desire. I purchased a vert thinking I would never use it with the top down. That's just not the case, top gets put down almost lost every single day if the weather permits. There are some great resources out there for any diy repairs you may need. Here is a great source for anything vert related : http://forum.e46fanatics.com/forumdisplay.php?f=106
There are a lot of parts in the roof and if you have any issues or concerns, I'm sure you can find it here. It helped me out a great deal. Enjoy the new ride!!! |
MFNATIK3516.50 |
06-28-2017, 01:18 PM | #60 | |
3517
Rep 3,754
So far the family is really enjoying the top down drives. Its our defacto car to take out in the afternoon and evenings now. I will say tho, the F80 is so refined that its a night and day difference in the way they drive and all the amenities/features of the F80 make it a more like a modern luxury car when compared to the E46 M3. As a weekend pleasure vehicle, the E46 M3 vert checks off all the right boxes. Its making me think maybe I should have gotten an F83 hahaha. |
SakhirM410781.50 |
06-28-2017, 03:23 PM | #61 | |
Rep 464
Agreed on the refinement of the F80 compared the the e46. There is a 15 year and generational gap so it's expected. They have such different personalities but it is a joy to drive both and have your pick for what you want for the day; top down cruising or supercar speed with everyday practicality. I drive my e46 daily and even carry my nieces and nephew in the rear with the top down. It's pretty turbulent back there with the top down on the freeway but they love it. I'm sure the F83 is a great all around car that could cover all check boxes for both vehicles but don't go regretting your purchase already!lol |
MFNATIK3516.50 |
06-28-2017, 03:28 PM | #62 | |
3517
Rep 3,754
08-03-2017, 10:49 PM | #63 |
3517
Rep 3,754
I did not realize how true this was until I started visiting M3Forums hahaha
I just completed the full Inspection 2, refinished all 4 wheels, and did a full interior restoration (replaced steering wheel, center console, cup holder, coin holder, center trim, navigation screen, HK door handles, windscreen mounts, broken covers, all broken dash and A-pillar clips, fixed worn bolsters, and disassembled the whole interior to wash and clean it). So now it finally feels like a new car to me and I'm just enjoying afternoon and evening drives with the top down. This project has been so much fun and rewarding so far! |
08-05-2017, 05:49 PM | #64 | |
Rep 11,765
08-06-2017, 08:24 PM | #66 |
Rep 26
I had an 05 E46 M3 vert. It is one sexy looking car, that's where the highlights ended for me. I personally didn't enjoy the car. You had to really wind it out to get the power out of it. To me if you want a car for track days then it's great, if you want a street car it really disappointed me. I had the SMG and it was terrible, then came all the potential issues. The VANOS bolt issue and the subframe issues really had me worried. Then there was the $13 a liter special oil you have to use. I'm not sure if that oil is still that crazy, but it was when I had the car. All this led me to only own the car for 18 months and about 5 of those were winter and the car was left in the garage under a cover.
