06-24-2019, 06:14 AM | #45 | |
Rep 28
I'm a bit lost as to what else to try as I can't seem to find anyone who has had a similar issue and don't want to keep playing around and risk messing something up! |
06-24-2019, 09:02 AM | #46 | |
Rep 30
In Esys Expert Mode window >> Coding >>> Read Vehile Order (FA With 5AC) >>> SVT Actual window select read ECU (do not read VCM). |
06-24-2019, 10:26 PM | #47 | |
Rep 28
I've attached some pics of the wiring and plugs if that helps. I've also attached a pic of the ECU's that I have listed after adding option 5AC and 5AP to the FA, and then selecting read ECU. Would the FLA module show up if there was a problem with the wiring? As the only other thing I can think of is that for some reason there is an issue with the wire taps. Really appreciate all your help so far |
06-25-2019, 01:39 AM | #48 |
Rep 30
[QUOTE=XXM235i;24952952]I'm 99% sure my car has K_Can2 wiring. It looks exactly the same as what roxxor has pictured. I looked up the mirror part number on realoem and it is compatible with all F2X models so it should be correct. The mirror has 6 pins in the plug, whereas the plug in my car only has 5 pins (including the 2 I added), so not sure if that makes a difference?
I also have the FLA Mirror like you, But my F10 doesn't have K_can2 on the sunroof, so I go like the picture I attached. I am like you Mirror FLA equipped with 6 wires but 5-wire cars. I have note No. 9 wire (purple ? ) The cord is not connected to anyone. - I'm different from you, I found ECU FLA in SVT - I am having this situation not resolved yet. 1. / Everything works perfectly (I tried driving on dark roads) after VO the ECU FRM, DSC, JBBFE, SZL, FLA, KOMBI With FA 5AC. But when I turned off the engine and started the car again, HBA did not work. 2. / When I accidentally choose <Edit FDL ECU FRM> in Esys (although I do not change the value in the ECU FRM), the HBA works (the HBA button on the SZL cluster turns on and turns off the working HBA) but when Turn off the engine and start the car again, the HBA does not work either. I also ran out of ideas for this additional equipment. |
07-14-2019, 06:09 AM | #50 |
Rep 30
08-01-2019, 08:29 AM | #51 |
Rep 742
You cant re-enable HBA via the button the stalk after shutting the car off and back on?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
dncomputech0.00 |
08-07-2019, 01:08 AM | #52 | |
Rep 30
Yes, I cannot activate HBA with the HBA button on the steering wheel after the engine is turned off and the vehicle is turned on again But HBA works after selecting Edit code FRM even though no parameters have changed in FRM. In Ista + check the HBA function according to the instructions, OK does not report errors. |
08-08-2019, 08:24 PM | #53 |
Rep 30
08-19-2019, 04:02 PM | #54 |
Rep 263
If someone is interested ... as have now a new F34 with stock HBA I´m selling a complete HBA retrofit kit, which I have used for my formes F34. It is including rear view mirror with FLA camera, baseplate, socket with custom wiring, steering wheel column switch cluster with FLA switch. Check details in the classifieds section here.
@XXM235i: Are you sure your wiring is 100% OK? Normally FLA should show up in the ECU list from the beginning on as far as I remember my retrofit some time ago. The "camera based system malfunction" is no evidence that your FLA is recognized somehow. I think this failure only appeares as your FEM is coded for FLA and is awaiting the FLA, but it can´t see it at all. Only 5 cables are normal. Check your CAN connections. Such wire taps are not always reliable. I strongly doubt your wiring. Last edited by TePee; 08-19-2019 at 04:08 PM.. |
11-19-2019, 02:38 PM | #55 |
Leroy Jenkins!!
22
Rep 21
If anybody is wondering, if you have a kfas2 camera already but don't have HBA all you have to do is get the steering wheel stock with the HBA button and get it coded. I did it this last week and it works great.
11-27-2019, 05:38 PM | #56 |
Rep 500
Can you please be specific with what you coded to enable it?
2016 F80 M3 (Mineral/Full SO)
2014 X5 M Sport (Mineral/Mocha) |
02-21-2020, 09:07 PM | #57 |
Rep 79
I have an F31, already have the kamera from factory for 8TH, does this camera support high beam assist as well?
I think mine is KAFAS or something like that. VIN: F786504 Thank you |
06-15-2020, 01:18 PM | #58 |
Rep 742
If anyones intrested, I have the FLA camera and the base plate covers for sale...
https://f30.bimmerpost.com/forums/sh....php?t=1730456
06-15-2020, 01:21 PM | #59 | |
Rep 128
I can’t sell my FLA mirror and covers for £45 here in the UK! I’m guessing parts are rarer stateside. I might advertise over there lol |
06-15-2020, 01:28 PM | #60 |
Rep 742
Wow! don't tell me that! haha, i just checked on ebay and theres only 2 FLA mirrors available in the US. Rest are across Europe. Good luck on your sales!
07-17-2020, 02:27 AM | #62 | |
Rep 9
I have the same problem, no K-CAN2 wires in roof module. Did you route wires and how did you do it? Which connctors (pins) in FEM did you use? I know it passed quite a lot of time, but anyway... Thanks in advance Last edited by kd8; 07-20-2020 at 07:09 AM.. |
07-22-2020, 05:31 PM | #63 | |
Rep 2
FEM Connector A173*8B: Pin 50 is K_CAN2_H and is connected to mirror connector A60*1B pin 4. Pin 49 is K_CAN2_L and is connected to mirror connector A60*1B pin 5. |
09-03-2020, 03:16 AM | #64 | |
Rep 9
Your car is E91? Is FEM module (pins) and wiring the same for my F31? Anyway thanks, I will let you know, If I succeed. |
09-04-2020, 01:28 AM | #65 | ||
Rep 2
09-10-2020, 02:58 AM | #66 |
Rep 9
Big thanks to Denmark CELSDK
on more question, maybe you know the answer: Is it possible to retrofit LDW (lane departure warning) if you have FLA (high beam assist) camera (the one bulit in rear view mirror) and not KAFAS camera (the one behind windshield)? I already have steering wheel with vibro motor inside. I heard it can be done with KAFAS camera and module, but that is not an option as I am not willing to change my windshiled just for this retrofit. So I am asking if it can be done with FLA camera. Thank you! |
