| 10-19-2015, 03:03 AM | #45 | |
Rep 177
This makes the new USB socket quite expensive.. In my case, I am using the USB socket mainly to charge phones. From time to time I plug a USB key with songs on it in order to transfer them, but the rest is going through Bluetooth connection. That is why I am looking for a USB charger and I would be done in term of phone connection in my car. |
| 10-19-2015, 03:31 AM | #46 | |
Rep 177
Same question here, we can try to sell it on classified ads.. |
| 10-20-2015, 09:51 PM | #47 |
Rep 1,815
I managed to find a Fakra cable manufacturer in China on aliexpress.com who will make me a custom extension cable for $30 shipped. I'll let you know how it works out.
| 10-29-2015, 05:57 PM | #48 |
Rep 5,728
Drives: G80 M3 6MT
Spoiler alert: adding a USB port works.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
Eddie Cement4.00 |
| 10-29-2015, 08:01 PM | #49 |
Rep 1,815
I got the new port...just waiting on the cable...must be coming on the slow boat. I ordered the plastic tray too. Back ordered and not in stock until tomorrow. |
| 10-29-2015, 08:45 PM | #50 |
Rep 5,728
Drives: G80 M3 6MT
I'm just getting the white HSD Fakra BMW one that most dealers have availability on and I'm going to cut off the keying so that it will fit in the blue plug... easy.
Scott, Partner
| 10-30-2015, 11:27 AM | #51 |
Rep 1,815
Yeah I almost got my flush cutters out to remove the key tabs on the remaining cable, but then I really wouldn't mind a bit more length and slack so I can mount the new port near the standard one.
Does the white BMW cable have a male on one side and the email on the other? Where are you mounting your new port? |
| 10-31-2015, 05:20 PM | #52 |
Rep 942
Did you guys see my earlier post?
There is a provision for a USB port in the glove compartment. You can get the complete cable, with socket from eBay.
2016 F80 M3
| 10-31-2015, 07:08 PM | #53 | |
![]() 954
Rep 3,089
If this doenst work, I suppose I could cut the keying features off from the connector, then plug the USB cable from the glove box into port #12 on the back the head unit. Then I can move the existing connector in port #12 to #13. That would allow me to plug my phone into the USB in center console which makes more sense.
| 11-01-2015, 02:14 AM | #54 |
Rep 942
Both the original USB, and the phone cradle replacement USB appear to have identical functionality.
Spotify, BMW apps, etc work just the same. I haven't tried doing an update through the phone cradle replacement USB. I use my iPhone for most things and can use either port, but generally use the original USB in the armrest. As far as I can tell, the main difference is that they have different icons on the display to differentiate between them; one being a USB symbol, the other the phone cradle symbol.
2016 F80 M3
| 11-01-2015, 03:21 AM | #55 |
Rep 1,815
Yeah aware that there's a third USB that you can add. This would normally be the "glovebox" port. But you have to run a cable to the head unit. That means pulling apart the dash. And that makes me a little nervous.
| 11-01-2015, 09:38 AM | #56 | |
![]() 954
Rep 3,089
I am pretty sure I can use these parts and remove the keying features: cable: 61-11-9-251-703 usb port: 84-10-9-229-294 I got these from this thread: http://f30.bimmerpost.com/forums/sho....php?t=1108386 If I can verify that the phone usb port will recognize a standard USB hard drive I will be all over this! EDIT: I have read other members who have done this saying connecting a USB HDD is no problem. Parts ordered now. Doing this mod!
| 11-15-2015, 09:44 AM | #58 |
![]() 954
Rep 3,089
Just to update this thread, I did the USB retrofit to the glovebox using the directions and parts in the thread I posted above. Everything works great! iDrive recognizes my music and movies stored on my 2TB Seagate HDD.
Here is a link to my build thread with a bit more detail on the retrofit. http://f30.bimmerpost.com/forums/sho...&postcount=466 iDrive sees my Seagate HDD (Media HDD). Notice that the HDD is identified as the phone cradle. ![]() ![]()
| 11-15-2015, 10:40 PM | #59 |
Rep 3,157
Link?
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
| 11-16-2015, 12:36 AM | #60 | |
Rep 942
2016 F80 M3
| 11-16-2015, 09:30 AM | #61 | |
![]() 954
Rep 3,089
cable: 61-11-9-251-703 usb port: 84-10-9-229-294 Here is a pic of what needs to be shaved off: ![]()
| 11-26-2015, 03:32 AM | #62 |
![]() 12
Rep 134
| 02-05-2016, 10:09 AM | #63 |
Rep 24
To the folks who were looking for an extension cable to bring the USB port into the center console storage ****...
Question: why not just put the port where the cable ends (inside), and use a (fairly short and high quality) USB extension cable to bring it out? |
| 02-05-2016, 10:11 AM | #64 |
![]() 954
Rep 3,089
The problem is that the connector at the end of the cable is not a standard USB.
| 02-05-2016, 10:25 AM | #65 | |
Rep 24
USB socket retrofit Something like this: RealOEM USB Socket part 04 #84109229294 But I'm suggesting just attaching that socket directly (no extension) and running the standard USB extension out from there. |
| 02-05-2016, 02:51 PM | #66 |
Rep 1,815
The leftover cable (after removing the cradle) has the wrong type of connector for the USB socket assembly. I had a Fakra cable custom made with the right ends. One side plugs into the leftover cable, the other plugs into the USB socket.
| Bookmarks |
