02-17-2019, 10:55 AM | #45 |
Rep 368
The amazon reviews for the 660 show numerous people who applied it and waited 24-48 hrs only to find it wasn't dry. It probably depends on your application though. , most of the reviews are great. It looks like the primer is needed for it to work on magnesium, aluminum, and some other metals. It's also recommended when the temp is cold. I intend to use it, doesnt seem like it could hurt
02-17-2019, 12:47 PM | #46 |
Rep 776
Seems like the fix could create issue for a related or unrelated TC warranty claim. Damned if you do and damned if you don't. Hopefully BMWNA/AG takes note of your findings and agrees a fix is needed.
02-17-2019, 01:51 PM | #47 | |
Rep 368
I don't think anyone with a warranty is likely to slide under the car and mess with it in the first place though. |
02-18-2019, 05:45 PM | #49 |
Rep 1,821
What had caused me to look at it was the oil, but actually I had thought about it a bit in the last few days, and I had a metallic click noise when shifting from reverse to drive, etc. Makes sense.
Even for people getting this fixed at dealer under warranty, ask them to change the flex disc to the all rubber superseding part number. This should already suppress a lot of the vibrations.
02-20-2019, 02:59 PM | #50 |
Rep 37
This thread is fantastic, lots of information.
First time poster, new to the bimmer community. I was thinking on buying a 328xd Wagon but the transfer case issue scared me a bit. If I end up getting one, I think ill have the Loctite and all rubber giubo done real soon. I guess the Bilstein B6 will have to wait... |
02-20-2019, 03:56 PM | #51 |
Rep 3,549
That's OK, they're OOS nation-wide anyways (normal and damptronic) with an "ETA" of late May (if you know anything about Bilstein you know that this "ETA" can't be trusted and will likely get pushed out again). You'll have to import them from Europe if you want them.
02-23-2019, 11:51 PM | #53 | |
Hopeless Noob
Rep 9
Off-topic questions for OP
2) I see you 'self-tuned' your '28d. How many (and which) different parameters (boost pressure, ignition pulse duration, fuel rail pressure, etc.) did you tinker with to achieve your 245hp/400lb-ft? Okay, that's all By the way, this is an amazing thread... truly an exemplary contribution to the community. |
03-09-2019, 06:46 PM | #54 | ||
Rep 22
Alan W
2014 328d SportWagon - Liquid Blue metalic over Black Dakota CPO'd 05/17 with 22K miles Driver Asst. / Driver Asst+ / Dynamic Handling / Lighting / Premium / Tech / Active Cruise / HK Audio / |
03-15-2019, 05:44 PM | #55 |
Rep 1,821
Sorry for the delay, it has been a very busy month for me.
The tuning part is not something that can easily be done at home, even by normal enthusiasts. (Heck, even some tuning companies have a difficult time getting it right.) I have some 5 years experience with tuning, plus a few very good friends, with all sorts of information. That and some 34 flashes and 20,000 miles of testing just on my personal car. I do need to put up a thread on it sometime, especially when I do an updated dyno of it. I am in a good healthcare career, so this is more of an extreme hobby, with the help of a few good friends.
04-09-2019, 10:50 AM | #56 |
Rep 15
Phenomenol work Enabled, thanks for doing this. My car has been doing the hesitation thing for 6 months now. Do you think doing the loctite and rubber bushing would buy me some time?
04-21-2019, 05:12 PM | #57 |
Rep 4
Hi everyone. My car is 61k miles. I’ve had some problems with vibrations form driveline. I was sure that this is xdrive problem, but after removing alloy guibo I found that it was totally broken. I will post a video tomorrow.
Please do remember when you make a change for rubber one you will have to adjust rear shaft. https://www.newtis.info/tisv2/a/en/f...shaft/1Loe7egW I’ve also found that flange has a bit of play. So that fix with loctite looks great. |
Enabled1428.50 |
04-21-2019, 05:33 PM | #58 | |
Rep 1,821
04-21-2019, 11:04 PM | #59 |
Rep 1,805
my 2014 F31 328d x drive is at bmw for what will now be my 3rd transfer case issue.
this is good info.. BMW needs to fix this
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
04-22-2019, 08:25 AM | #60 |
Rep 368
Interesting on the bearing adjustment procedure. So, it looks like having a bearing seal driver if the bearing needs to be seated deeper or a 2 arm puller if it needs outward adjustment is a necessity. (Or the BMW specific tools). I wonder if it's some weird size that you won't find in an off the shelf kit?
The bearing replacement procedure calls for a 4+2 mm tolerance on the center bearing protrusion. So the range would appear to be 4-6mm to avoid driveshaft damage. |
04-22-2019, 11:36 AM | #61 |
Rep 1,821
Good info on that newtis page!
I'm sure it's easy to figure out a tool to press/pull the bushing to the right position.
04-22-2019, 11:37 AM | #62 |
Rep 1,821
If possible, I would get them to put Loctite 660 on the new clean flange/shaft.
PabloK601.00 |
04-22-2019, 04:38 PM | #63 | |
Rep 4
Here is a video of my broken guibo (sorry it’s in Polish) https://share.icloud.com/photos/0Ofy...4sTfpRhTcZWnYw |
04-24-2019, 05:26 PM | #65 |
Rep 4
04-24-2019, 06:32 PM | #66 | |
Rep 37
How many miles do you have on the "loctited" transfer case ? If is holding up I will feel much better buying a used F31 d Also car after 07/2015 have all the rubber shaft coupling ? From the tracking spreadsheet looks like there are less failures of LCI models. Maybe we don't have enough data for newer models but it might be that the new rubber guibo does just enough to keep the splines in good condition. I wonder if a bmw dealer would sell a broken transfer case, I'll refurbish it myself and keep it as spare. There must be a sh**load of transfers cases that need only a new shaft and a flange... Something like the x delete to keep the TC open in RWD would not help here as the failure is on the flange that is attached to the rear driveshaft. Initially I was thinking that that would help but doesn't look like it. |
