03-16-2022, 06:44 AM | #45 | |
Rep 34
wataroo4.50 |
03-16-2022, 03:37 PM | #46 |
“M”ing
53
Rep 52
Glad to see another one being installed and that postings helped
I got curious today and coded HU back to normal, and it’s louder and sounds better IMO after a good hour back to back listening. Vibe reported we shouldn’t need to code too, but, each to their own. Coding certainly isn’t hurting! Leaving it as it is now, I have the underseat subs, door speakers and some dead Matt sound deadening to install hopefully this weekend to complete this little audio overhaul. Even now, I’m not missing HK other than the fancy surround effects V happy with the result |
03-17-2022, 12:57 PM | #47 |
Rep 5
Wow thanks for the very informative posts and pictures to help with install I’ve be going back and forth in my mind about going for a full bespoke install at a cost of £1200 or if this option would be viable. As said struggled to find reviews on the vibe amp so was in limbo but thanks to you guys I’ll be ordering tonight.
03-18-2022, 10:05 AM | #48 | |
Rep 46
03-18-2022, 10:23 AM | #49 | |
“M”ing
53
Rep 52
However I have stock door speakers at the moment, having fitted the subs today (which sound great, deeper and clearer bass) and ran out of time so will do the door speakers tomorrow hopefully and will try both base and HiFI coding. Popped in a sheet of sound deadening as figured it wouldn’t hurt Question for everyone and probs me being daft, but when testing the subs it was clear that some vocals were coming through, I guess as these are mid bass and not true sub bass? What’s everyone’s crossover settings on the vibe, I left mine on full rather than HPF, could that be it? This is a great upgrade for £450 all in inc amp, speakers, subs, sound deadening and trims, v happy and looking forward to the door speakers |
03-18-2022, 10:57 AM | #50 |
Rep 16,199
They'll reproduce whatever content is fed into them. Pretty much any woofer will work to at least 1kHz. The content to the woofers should be low passed at no higher than 125Hz.
03-18-2022, 11:07 AM | #51 | |
“M”ing
53
Rep 52
If other vibe owners could confirm if they run full or HPF that would be great, just to know. Wasn’t 100% sure so left it as it came out of the box and just adjusted gain |
03-18-2022, 11:14 AM | #52 |
Rep 16,199
You wouldn't run a high pass filter on the woofers, unless it was set to perhaps 30Hz, and you also had a low pass filter set somewhere between 80 and 125Hz. By the same token the midranges need to be high passed somewhere between 80 and 125Hz.
03-18-2022, 11:20 AM | #53 | |
“M”ing
53
Rep 52
03-18-2022, 11:40 AM | #54 |
Rep 46
They told me on the website where I bought it, to set the low in front side to full and the low in rear to hpf, and then turn the volume up to 3/4 and turn up the gain knob until just before distortion.
so how about |
03-18-2022, 11:57 AM | #55 |
Rep 16,199
You never want subs and midranges working in the same frequency pass band.
If the Vibe amp lacks the ability to low pass the woofers and high pass all of the midranges, which requires a minimum of five amp channels, that's a major limitation. |
03-18-2022, 12:05 PM | #56 | |
“M”ing
53
Rep 52
Same volume and gain setup process but the HPF setting is new, might flip the switch one day and see what it’s like. I’ve just popped out in car again simply to test the new subs and it’s a substantial change just for some plug and play subs. I’m sure the door speakers will make a big improvement too tomorrow. I’ll have the whole vibe optisound upgrade then, assuming it designed to work with itself |
03-18-2022, 12:06 PM | #57 |
“M”ing
53
Rep 52
It’s a very basic amp, so I wouldn’t be surprised, but vibe are an ok brand so I’d assume they have it all tested to work with themselves
03-19-2022, 08:57 AM | #58 |
“M”ing
53
Rep 52
Vibe OPTISOUNDBMW4X installed this morning with some sound deadening and very impressed with the clarity and power, works perfectly with the amp and underseat subs, no need to adjust the HU coding.
The mids come with a “high end crossover with reference curve” whatever that means 😂 and you can see that and another capacitor of sorts mounted Had planned on removing Vapor barrier and going to town with the sound deadening but opted against and just applied around the speaker and directly behind Super happy with this package for what it cost in total. |
03-19-2022, 11:30 AM | #60 |
Rep 16,199
After looking into it that is the correct way to do it if you're only running that one amp. You'd run the front with HPF if you had the underseat woofers separately amplified, which would give a much better result.
03-21-2022, 05:31 AM | #61 |
Rep 79
Question for anyone who has added the Match Up 7DSP to a base (no amplifier) system - does the wiring harness plug into the quadlock on the back of the head unit? If so, will me having installed an MMI box (that also plugs into it and re-directs the optical cable etc.) affect this? Would hate to buy a plug and play amp only to find I then have to choose between MMI/Android Auto and an amplifier...
cheers |
03-21-2022, 05:44 AM | #62 |
Rep 171
I am in the same boat (Match Up7DSP + base audio + MMI screen, which is pretty much the same as MMI box as far as wiring goes)
And for the reason you state, I chose... not to go plug & play! As a result, I'm re-wiring everything, with the notable difference that I had previously installed a harness for another 4 channel amp (Focal Impulse 4.320). This harness ends up with a connector in the trunk (boot in London), right were the Matchup is going to fit. It inputs front IN and outputs both front mids and underseat subs. What I'm doing right now is building a custom harness from this previous harness connector to the Matchup, adding up additional wiring for the center mid and rear mids. I'll post a DIY when done. |
04-01-2022, 03:48 AM | #63 | ||
Rep 18
I prefer the above setting over what I had before. To me, vocals stand out more. There's less bass but I feel it sounds tighter. One issue I have is Carplay music volume is low compred to other sources such as FM radio. Hence I have the gains at max. I will probably play around with these settings but am happy for now. |
04-01-2022, 03:59 AM | #64 | |
Rep 171
You will find an in-depth write-up about the sound settings and coding here: https://www.diymobileaudio.com/threa...n-most.437890/ |
wataroo4.50 |
04-01-2022, 04:18 AM | #65 | ||
Rep 18
FastFrog143.50 |
04-01-2022, 05:33 AM | #66 |
Rep 333
Has anyone used Vibe Optosound under seat subwoofers and can say something about them?
I'm thinking about buying those together with pnp Powerbox65.4M I really want to upgrade my subs without breaking the bank and that combo seems promising. |
amplifier, audio, base, upgrade |
