08-01-2017, 06:09 PM | #45 |
Rep 4
Did you use your fingers to bend the tabs? I tried but mine are pretty tuff to bend with just my fingers. Any suggestions with such little room to work with?
Thx |
08-01-2017, 08:59 PM | #46 |
Rep 16,671
My LED thread shows what I did to make the low beam bulb clips accessible.
http://f30.bimmerpost.com/forums/sho....php?t=1377259 |
08-21-2017, 09:48 PM | #47 |
Rep 31
I know its an old thread but i have a question since i just failed at trying to do this. Idk if BMW changed the bulb connectors for the LCI as I have a 2016. The issue I ran into is the connector the actual bulb itself is plugged into. It looks different and for some reason i cant disconnect the bulb to put the new one in. I pulled on it pretty hard to the point i thought i was gonna break something but it wouldnt budge. Any tips ?
09-19-2017, 11:21 PM | #48 | |
Rep 14
09-20-2017, 11:50 PM | #49 |
Rep 366
Hey guys,
What's the consensus on what's a good LED kit for a 2012 F30 (i.e. bright and safe for night driving)? Cheers.
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
09-21-2017, 07:01 AM | #50 |
Rep 16,671
chuckles01187.00 |
01-19-2018, 08:40 PM | #51 | |
Rep 59
01-19-2018, 09:21 PM | #52 |
Rep 16,671
7. Before installing the new bulb, bend the brackets back to original position and the new bulb will fit tightly and lock in when installed
01-20-2018, 01:02 PM | #53 | |
Rep 59
01-20-2018, 03:30 PM | #54 |
Rep 16,671
At the risk of repeating myself:
My LED thread shows what I did to make the low beam bulb clips accessible. http://f30.bimmerpost.com/forums/sho....php?t=1377259 |
01-20-2018, 03:39 PM | #55 | |
Rep 2,351
PAGE NOT FOUND Sorry You seem to be lost. Unfortunatly the page you are looking for cannot be found. A classic 404 error. We wish you luck on your quest for the missing page. You will be automatically forwarded to our homepage soon.
01-20-2018, 05:43 PM | #56 |
Rep 16,671
I copied it from a few posts back, where it does work. Try this:
02-25-2018, 07:47 AM | #57 |
Rep 133
Hey all-
Thank the OP and everyone for the great thread. This was very helpful since you have to do the whole thing blind. I wouldn't recommend trying to do this yourself if you have big hands.. it's a tight fit in there. I see a lot of feedback on the Phillips, and it's my experience that the brighter bulbs die annually. Given the difficulty and expense of replacing the builds i tried something new.. Optilux H71070307 by HELLA XB Series H7 Xenon White Halogen Bulb Set, 12V, 100W https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Here are the results: OEM: https://photos.app.goo.gl/7CXPqKAnoi995det1 New: https://photos.app.goo.gl/dopI0pCD2PQYiJqj1 I would say better color and a 25% light output improvement. Better but not great. |
10-26-2018, 12:38 PM | #59 |
Rep 1
Thread helped me (a girl) replace headlights
I'm your typical 38 y/o female around cars...
I followed this thread, read all of the tips and shortcuts, and I was able to replace both of my low beams in under 10 mins on my own. Just wanted to share that this thread saved me over $200 at the dealership to change these on my own. Got the bulbs on Amazon for $30... so approx $170 saved is fantastic! https://photos.app.goo.gl/D1SFj6U9nFpSjYkt7 Philips H7 CrystalVision Ultra Upgraded Bright White Headlight Bulb -Stephanie |
10-26-2018, 02:04 PM | #60 | |
Rep 5,463
Drives: F30
10-26-2018, 04:59 PM | #61 |
Rep 16,671
If you're satisfied all well and good, but those are no brighter than stock, the just appear whiter due to the blue tinting of the envelope. An LED bulb has whiter color than stock and will be on average three times as bright as halogen.
06-20-2019, 08:01 PM | #63 |
Rep 1
So I tried doing all the above steps. I managed to replace the old bulb. Placed the brackets to their original positions. I may have been slightly aggressive in doing the same.
Now the new bulb doesn't fit tightly at all and as a result is wiggling in the socket. Any suggestions? |
06-20-2019, 08:41 PM | #64 |
Rep 2,351
Make sure that the bulb is fully & properly seated in the socket. Replace the bracket/holder and push against the three tabs to lock it in place.
12-04-2020, 09:51 PM | #66 |
Rep 16,671
You need to jack the car, remove the wheel, then remove the fender liner, otherwise it's a struggle. Even after doing all that the low beams are next to impossible to work on. That's why I cut the tops off my lamp housings as shown in my bulb replacement thread.
