01-06-2014, 01:20 AM | #45 |
Rep 41,224
No. You can try any other FDL for test purposes. As I wrote, I suspect it is a coding issue and not an FDL setting issue, so I think for whatever reason, you can't code anything in REM.
01-06-2014, 01:23 AM | #46 |
Rep 41,224
Then so should the other 2.
01-06-2014, 01:59 AM | #47 |
Rep 25
I have deleted most of my posting form tonight being that it was really all my mistake. Thank you to shawnsheridan for helping me figure it out.... no more coding late at night...
Bottom line... awesome tutorial and it works great. Last edited by eyalgoldman; 01-06-2014 at 02:26 AM.. |
01-06-2014, 02:24 AM | #48 |
Rep 41,224
Glad it is working.
tmdals0213214.50 |
01-16-2014, 03:46 PM | #49 |
Rep 114
I have this switch and I want to code rear fog light by second button.
Wll this code work? Mapping_Nebelschlussl_L_output = nsl_l Mapping_Nebelschlussl_L_Function = nebelschlusslicht Mapping_Nebelschlussl_R_output = nsl_r Mapping_Nebelschlussl_R_Function = nebelschlusslicht |
01-16-2014, 04:34 PM | #50 |
Rep 41,224
They should, and they are in REM module not FEM_BODY.
02-15-2014, 06:33 PM | #54 |
1ST CLASS AWMSPORT
74
Rep 789
Drives: 13' 328 MSPORT
Easy, takes about 10min...just make sure the tabs are smooth after, before you start putting back together.
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon: JB4,DP,H&R sports,rear diff,! |
01-09-2015, 01:50 AM | #55 |
Rep 131
04-10-2015, 03:23 PM | #57 |
Rep 615
That is weird that coding needs to take place in order for this mod to work. on my X3 LCI 2015 i just added the switch and it worked. no coding was required.
08-04-2015, 09:53 AM | #58 |
Rep 464
Great write-up! I missed not having rear fog lights.
I just installed the Euro light switch and discovered, to my surprise, when I pushed the front fog light button, the Adaptive LED headlights changed behaviour. The main beams shifted the aim to the right. It was hard to see whether the light distribution changed since I discovered this "feature" during the day. Will test more tonight. Note I have enabled the VLD and NGHB headlight functions and I do not have any fog lights in the lower grill. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
08-15-2015, 10:03 AM | #60 |
Rep 23
Just wanted to say thank you for this write-up! Instructions were easy to follow and it worked perfectly. In and out in under 10 minutes.
I can live without the white symbol
2013 ActiveHybrid 3 M-Sport - Black Sapphire Metallic - 19" 403M - CWP, DHP, PP, DAP, TP
09-13-2015, 04:31 PM | #61 |
Don't care
117
Rep 224
For those that have retrofitted the Euro light switch operating unit (ECS Tuning) you will have to add "NSL" to LCE_BEL_LIN_VAR as well as the coding mentioned earlier in this thread. For instance, I have an F32 without front fog lights with adaptive LED's. I had to code FEM_BODY to clear the fault memory in Rheingold:
FEM BODY 3064 => LCE_BEL_LIN_VAR => BEL_FLC_NSL (default was BEL_FLC) The fault never created a CEL, but it was present (wrong light operating unit wrong variant installed fault code D90D16) when I ran Rheingold. Last edited by TMD29; 09-13-2015 at 04:41 PM.. |
QuarterMileJoe9.00 Oksamit78294.50 |
09-13-2015, 05:49 PM | #62 | |
Rep 1,076
09-13-2015, 06:31 PM | #63 | |
Don't care
117
Rep 224
If you have Adaptive Xenon Headlights and fog light front and rear you would select variable BEL_FLC_NSW_NSL from the options. I believe there are eight different options in there to select from. Last edited by TMD29; 09-13-2015 at 06:41 PM.. |
09-13-2015, 06:48 PM | #64 | ||
Rep 1,076
09-13-2015, 07:22 PM | #65 | |
Don't care
117
Rep 224
http://www.bimmerfest.com/forums/sho...d.php?t=827223 |
09-14-2015, 10:23 AM | #66 | |
Rep 1,076
I downloaded Rheingold and saw that I had that error message and I coded what you mentioned but the error did not go away. Wonder what else could be going on. |
