02-10-2017, 08:55 AM | #661 | |
Rep 4
I appreciate the offer to help. I'll export that tune and shoot it your way to take a look if you don't mind. |
02-10-2017, 09:00 AM | #662 | |
Rep 2,013
We ship our amp with a tune that was created to give you the optimal sound quality with stock speakers. It does not mean the amp will be louder than the stock one, but it will definitely sound better. If you want to make it louder change dip switches 2 and 4 to ON. If this is still not enough simply use the software to change the tune. The simplest way to do it is just increase the gain on all or selected channels. Keep in mind that you can damage your speakers if they give them too much power. You can also try tunes from other forum members: http://f30.bimmerpost.com/forums/sho....php?t=1182351 |
02-10-2017, 09:05 AM | #663 | |
Rep 4
The name of the tune that came loaded is M1-26012017-1302. Is that the correct one for a 428 with base HiFi? |
Hyperlink9.00 |
02-11-2017, 07:38 AM | #664 | |
Rep 33
02-12-2017, 03:43 AM | #665 |
Rep 100
I have the bimmertech amp, and every change I make with gains, is definitely hearable. Sometimes not 1db, but certainly 2db difference. I did left the sound curves untouched.
02-13-2017, 01:53 PM | #666 | |
Rep 1,615
Also, the DIP switches mentioned above were ON when I received my AMP as well. Maybe I got a used/returned one or they might have decided to change it. |
Hyperlink9.00 |
02-18-2017, 11:04 AM | #667 |
Rep 158
I am on the fence on this and trying to find out the general consensus of if this is worth it or not? Everything with my audio is stock. The older I get the more picky I get with cost and ROI.
02-22-2017, 06:08 PM | #668 |
Rep 832
I know quite a few of you have been waiting for this tune. F30 Bavsound speakers with Ghost woofers.
https://drive.google.com/open?id=0B9...XFaWDZ5akZkV0k |
02-24-2017, 01:57 PM | #669 | |
Rep 4
Had I been able to listen to the amp ahead of time, would I still have purchased it? Probably not for the price. While it's most definitely an upgrade over the stock amp (not even a debate), I'm not sure that it's quite as incredible as it's made out to be. The clean headroom isn't nearly what I expected, and I still get some really muddy/woofy sounds on some songs. All of that said, I'm probably 70% happy with it, but I'm going to keep experimenting with the tune and see if I can find something that gets me closer to 100% satisfied. |
jeffc83722.00 |
02-28-2017, 10:41 PM | #670 | |
Rep 70
03-02-2017, 12:15 AM | #671 |
Rep 6
I have the bsw w/ ghost woofers and I've been using the 'BimmerTech_F30 BSW Jenhert underseat subs' tune for a year now. I like it much more than this new tune. I used it with V3 and found it strange that this one doesn't resemble the other bimmertech f30 tunes at all.
03-03-2017, 01:38 PM | #672 | |
Rep 1,615
EDIT: Scratch that; I don't have the ghost subs so it's useless |
03-03-2017, 01:39 PM | #673 | |
Rep 1,615
04-29-2017, 08:10 PM | #674 | ||
Rep 87
04-30-2017, 09:04 PM | #675 |
Rep 142
Right now I'm running with the Bimmertech amp and Morel speakers and tweeters and stock subs. The sound has been amazing but the bass has been lacking so I'm looking into buying a set of earthquakes sws-8x/i. I'm just not sure if I should be buying the 2 ohm or 4 ohm set? Does it matter with this amp?
05-01-2017, 06:04 AM | #676 | |
Rep 2,036
http://f30.bimmerpost.com/forums/sho....php?t=1070841
05-01-2017, 06:18 AM | #677 | ||
Rep 142
05-01-2017, 06:44 AM | #678 | |
Rep 2,036
05-01-2017, 07:21 AM | #679 | ||
Rep 142
05-01-2017, 02:29 PM | #681 | |
Rep 142
06-27-2017, 01:18 PM | #682 |
Rep 4
I Installed my Bimmertech amp last night and was somewhat happy with the results. I have OEM Hifi Speakers and subs. The loudness is increased as well as the clarity at higher volumes. The bass kicks harder which is very important to me. I was cruising around testing the sound and I got a burn-type smell in the car. I turned the volume down right away and the smell went away. Is this from too much power being put into the subs/speakers? I have not changed the tune at all I simply installed the new amp and went for a drive. Hope somebody here can help.
This is quite disappointing since I am looking for more bass from my subs. If they are producing a smell with the preloaded HiFi tune, I'm afraid they wont be able to handle more gain if I use the dsp for more bass. Thanks for any help guys! |
audiotec fischer, bimmertech premium sound system, bmw amp upgrade, bmw hifi |
