12-15-2014, 04:39 AM | #7745 |
Rep 42,932
PM sent.
12-15-2014, 07:51 PM | #7746 |
Rep 159
12-16-2014, 10:40 AM | #7747 | |
Rep 508
Drives: 2021 F97 X3MC LCI - Marina Bay Blue Metallic
Gone: 2019 G16 840i GC - Frozen Bluestone Metallic Gone: 2018 F80 M3C - Sakhir II Orange Metallic Gone: 2015 F80 M3 - Mineral Grey Metallic |
12-16-2014, 09:06 PM | #7749 |
Rep 42,932
PM sent.
12-16-2014, 09:18 PM | #7750 |
Rep 1,113
I just tried to code the mperformance logo and instead got X550d to display. Also tried choosing M4 in Esys and now I have the Zinoro logo.
Although unsuccessful with that, I was able to code the led headlights to euro spec, and set AC to off when AUTO is pushed. Also tried to enable weatherband in the radio but that didnt work either.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 12-16-2014 at 09:24 PM.. |
12-16-2014, 11:00 PM | #7751 |
Rep 10
So after the first run at coding my car, everything seemed to work great, with the exception of my dealer coded option to remember last Auto Start/Stop setting. I decided to connect to the car again and select the option to "default off" (without switching the other option "remember last" back to default). Coded FCL and decided to take the car for a spin.
Now, whenever I go into camera mode, I get a yellow warning that says "camera malfunction" and it only goes away when the cameras are turned off. Also, I've noticed an odd behavior about the timeout. The cameras will time out much more quickly when i'm at speed. The top view camera will time out at a lower speed that the rear view. i.e. It's still tied to the speed somehow. Any idea how to fix this? Should I maybe try recoding the REM_01 module since that's where the settings reside? Do I need to go back to the previous code and start over? I have saved a copy of CAF, FA, and SVT for each version of coding. Is there a thread or are there instructions to show how to revert if it's necessary? Thanks in advance. |
12-17-2014, 10:10 AM | #7752 |
Rep 1
Hi Shawn! I have a F11 2013 not LCI I want to enable some goodies on, like the high beam assistant. I have the Speed limit info option, so this should work? Could you hook me up with a PM to get the software I need and tokens?
Thanks |
12-17-2014, 10:15 AM | #7753 |
Rep 42,932
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 12-17-2014 at 11:19 AM.. |
12-17-2014, 10:28 AM | #7754 |
Rep 16
Hello!
I have a problem with oil inspection reminder. My car (f30 11/13) has 6WA and 609 (NBT) retrofitted. 6WA is flashed with my VIN, NBT has FSC codes for my VIN. Then I-Step of the whole car was updated to the latest 54.2. So 6WA and NBT are coded by my FA. Dealer has changed oil in my car and has reset CBS oil reminder. But after my car went sleep and awoke again the indicator showed the old digits - 9000km 05/2015. I tried to reset it again through cluster. I did it but after car went sleep everything got back. Then I tried to reset it in Rheingold. I did it successfully but guess what was next So there is no way for me to reset it. What is wrong? Should I try to install my basic kombi back? Where CBS is stored in the car? Or is it a newest i-step problem? Thanks in advance! |
12-19-2014, 11:53 AM | #7755 |
Rep 208
Hy,
First of all: top forum here! I have spent several hours with reading through all the interesting threads. Now I finally have my new GT and I would like to code the advanced bluetooth function inclusive office if possible... My car is equiped with following: 6NH 6AE 6AC Am I right, that I only have to add 6NS? Will 6AL also be possible? Can someone send me the links for the latest esys version and the needed tokens? Thanks in advance! |
12-19-2014, 03:27 PM | #7757 |
Rep 42,932
PM sent.
12-19-2014, 03:28 PM | #7758 | |
Rep 42,932
So what is it you need?
12-19-2014, 03:58 PM | #7759 |
Rep 65
Well I just meant that I want to figure out the possible coding I can do but I didn't want to read that many threads to figure out what was available.
12-20-2014, 12:25 AM | #7760 |
Rep 208
12-20-2014, 06:36 AM | #7761 |
Rep 42,932
6NS should be possible if car has navigation option. 6AL is hit or miss. All I can say is code it and see what you get.
12-20-2014, 01:02 PM | #7763 |
Rep 42,932
PM sent.
12-20-2014, 07:13 PM | #7764 |
Rep 10
As I mentioned in a previous post, I coded my car to allow the cameras to be used at any speed but now get a "camera malfunction warning" that appears just about any time the cameras are used. I have reverted back to the original versions of code for the related modules, but still get the warning. I know this could be a coincidence, so I'm thinking that taking the car into the dealer may be my only option before the warranty runs out.
Any thoughts? Also, was anyone able to actually change the setting to prevent the camera from timing out after a given distance? I've seen a setting under PMA on the cheet sheet, but that module doesn't show up on my 2012 F30. |
12-20-2014, 07:16 PM | #7765 |
Rep 10
And in an unrelated question....
I activated Launch Control in my 2012 F30 328i, but it doesn't seem to be working. In most videos "Launch Control" displays on the dash when it is used. When I try, I can feel load being put on the transmission before releasing the brake, which is another sign that it's not actually working. Is is something that just not be available since mine is the first year of the F30? |
12-21-2014, 05:30 AM | #7766 |
Rep 26
blindspot warning
hi, i have f30 2014 316 that has blindspot warnings (light on side mirrors) mine only works if you doing 50km or greater, 328 i had as a loan car warnings worked at low speeds... can my 316 be coded to work at low speed too?
thanks |
