07-07-2023, 11:04 AM | #67 |
Rep 98
Car type: G82 M4 Comp Xdrive
Fuel type: E60 Tune information: Bend calibrations BM3 / Stage 3 XHP Exhaust/intake modifications: catless dp, bms drop in filters Road surface: south California closed freeway |
07-07-2023, 11:18 AM | #68 |
Rep 1,366
i dont think runs with ~ 1.5g spikes can really be considered valid despite what dragy says, you need a lot more than 700whp to actually pull 1.5g @ 60+ mph.
hellcat2m4230.00 Abacus38237.50 |
07-07-2023, 12:39 PM | #69 |
Rogue
760
Rep 243
hellcat2m4230.00 |
07-23-2023, 11:54 AM | #70 |
Rep 248
Good news new PR 10.3 @134.5mph
Bad news it was 88 degrees outside, DA was 2300 and my IAT were 110 degree’s starting lol. I just got to wait till it’s winter time here in Florida so I can see what she can do in clean air. Here’s the draggy video https://youtube.com/shorts/b3nCTCbn098?feature=share
IG Perseus_Actual Performance: DP, Intakes, BM3 Flex Fuel tune By Bend Calibrations Cosmetic: CF front lip, Diffuser, and Spoiler |
FloridaM5462.50 hellcat2m4230.00 |
08-08-2023, 12:45 PM | #71 |
Rep 1,366
Car type - G80 xdrive
Fuel type - E60 Tune information - Bend calibration BM3 flex fuel Exhaust/intake modifications - MAD catted DP, MAD resonated Mid, Valvetronic Ti Rear, Mishimoto intake Road surface - street Other modifications - none, stock fuel system full weight |
08-19-2023, 08:05 AM | #72 |
Rep 1,366
Fuel type - E60 Tune information - Bend calibration BM3 flex fuel Exhaust/intake modifications - MAD catted DP, MAD resonated Mid, Valvetronic Ti Rear, Mishimoto intake Road surface - street Other modifications - none, stock fuel system full weight let off too early and coasted through the finish but it's a 9 so i'll take it really happy with this for full-weight, no prep whatsoever on 20" ps4s. |
08-19-2023, 08:15 AM | #73 | |
Rep 524
08-19-2023, 08:17 AM | #74 |
Rep 1,366
08-19-2023, 08:26 AM | #75 |
Rep 524
08-19-2023, 04:55 PM | #76 | |
Rep 248
08-19-2023, 09:03 PM | #77 | |
salty cowboys fan
6239
Rep 3,436
she’s home! '22 M4 Comp xDrive
08-19-2023, 09:47 PM | #78 |
Rep 1,366
nothing too special really but the trick that i found that works for me is to go early, well before the system gives the launch active notice. If i hold it too long it launches with too much torque and just spins and i'll get a 2.7-2.8 0-60 (not sure on the 60ft but not good i'm sure). Looking at my logs i'm leaving at 2800-2900 rpm. i actually just went out once more to back it up, wanted to make sure it wasn't a fluke run
08-19-2023, 11:55 PM | #79 | |
salty cowboys fan
6239
Rep 3,436
08-20-2023, 07:10 AM | #80 |
Rep 248
New personal record
Car : 2022 M4 Xdrive Mods: Bend Calibration flex tune BM3 flex fuel kit BMC drop in filter Arm Motorsports catless resonated downpipes E50 XHP Stage 3 Rolling into it from 2nd gear
DieselG80XC118.00 |
08-30-2023, 02:50 PM | #81 | |
Rep 710
Drives: 23 M3 Competition
08-30-2023, 03:09 PM | #82 |
Rep 1,366
Weather is a huge factor but your DA is better than mine on these runs so i don't think it's the issue here. Slight incline vs slight decline not helping you either but you are losing a lot of time in the first 60-100 and you are flat on that part, based on the Gs you are pulling you might just not be tuned as aggressively. I'm assuming you are starting in 3rd gear you should be pulling around .9g at 60 and you seem to be a bit off from that. Drag mode in XHP is also about .2s faster (again when starting in 3rd) in my experience (compare the 60-130 i posted which is with drag mode vs the 1/4 mile i posted after is without drag mode) if you aren't already using that. Share the log from your best run if you can.
fmonteiro444321.00 |
08-30-2023, 03:27 PM | #83 | |
Rep 710
Here is the 6.39 log: https://datazap.me/u/fmonteiro444/8-...ta=2-3-9-20-21 This is a Westtuned E40 map 30-31psi. Runs super smooth and hits hard. I did a 6.5 right after this one back to back. I also have a Motiv tune that's E50 36psi, hits hard AF but 6.5 is my best time. Full mod list: Car type - 23' G80 xdrive Fuel type - E45-50 Tune information - Westtuned/Motiv MHD E tune, xHP Stage 3 w/drag mode Exhaust/intake modifications - RK catless DP, AA single midpipe, RK front mount intakes Road surface - street Other modifications - KW HAS, stock fuel system full weight |
08-30-2023, 03:49 PM | #84 | |
Rep 1,366
i think you would do better to shift a little later 3-4 and 4-5 you're only hitting 28psi in 3rd and 29psi in 4th as compared to my car you are seeing quite a bit lower torque values, up to 100nm less across the entire 60-130. i'm not sure if that is the amount being targeted as you don't have the torque target in the logs. |
08-30-2023, 04:20 PM | #85 | |
Rep 710
09-06-2023, 07:45 AM | #86 |
Rep 10
Best 1/4 Mile ET - 10.00s at 135.59mph Best 60-130mph ET - 6.34s Video proof available if requested. |
DieselG80XC118.00 |
09-14-2023, 10:23 PM | #87 | |
Rep 1,366
