BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 High Beam Assist Retrofit (Xenon Only)
      09-10-2020, 03:46 AM   #67
Daggers
Daggers's Avatar
Drives: '17 F82 M4 Competition
Originally Posted by kd8 View Post
Big thanks to Denmark CELSDK
on more question, maybe you know the answer:
Is it possible to retrofit LDW (lane departure warning) if you have FLA (high beam assist) camera (the one bulit in rear view mirror) and not KAFAS camera (the one behind windshield)?
I already have steering wheel with vibro motor inside.
I heard it can be done with KAFAS camera and module, but that is not an option as I am not willing to change my windshiled just for this retrofit.
So I am asking if it can be done with FLA camera.
Thank you!
I can confirm 100% it is not possible with FLA camera. KAFAS is needed. 👍
      09-10-2020, 07:49 AM   #68
kd8
Slovenia
Drives: F11 520d
Thanks for speedy answer I was afraid of that answer
      11-07-2020, 06:30 PM   #69
XuLeTZ
XuLeTZ's Avatar
Drives: BMW 320d F31 M Sport
Hi everyone, after some help if possible.
I have a F31 320d European.
the car came with standard halogen lights and KAFAS2 camera for road signs detection.
Some time ago I retrofit xenon headlights and high beam assist.
Now I got a new pair of adaptive xenons 524.
Basically I didn't change any wires, just out with the old and in with the new. I coded out FEM with the new FA (524).
The headlights are now bending on the road, they move when steering left and right, the only issue is with high beam assist, is working as the regular xenons, they are not making the tunneling to avoid other drivers.
Do I need to code anything else beside ICM, KAFAS2 and FEM?
Road clear, somebody coming from the front, both headlights are switching high beam off. Any reason? Tested it in so many circumstances, everytime both headlights are turning themselves off of high beam. I have the option 5AC, and not 5AP nor 8S4.
Please please help.
Thanks in advance.
      10-08-2021, 05:47 PM   #70
wheeljack
Drives: F36
Hello
I retrofited mirror in my f36 from F10 LCI - 51169345381
Its Homelink + FLA + auto dimming for europe with this same handle like F3x
Like everyone know auto dimming mirror from f3x its this same like in f10 LCI, but with FLA and homelink its have different oem numbers (F3x europe didnt have homelink mirrors - only this retrofited like Gxx one)
Everything work perfect - dimming, fla, homelink, but i have one problem. When i lock the car my cluster is lighting - its normal, but after some second its going to sleep, and back lighting again. After 5-6 times of it it go sleep normal. Ofc i coded kombi, fla, fem with all options, but its someting wrong.
any idea?
ps. sorry for my bad english
      10-09-2021, 03:09 AM   #71
SK223
Drives: F20
Hi there everyone, just wanted to share my knowledge as I've now done a few retrofits to my F20, which is the same platform essentially as the F30.
Just wanted to also thank the creator of the retrofit guide as that made things easier for me
High Beam Assist (HBA), DOES WORK with halogens, not just xenon's.
Lemme elaborate
HBA only comes with xenons as we know in a package. My car came equipped with halogen headlights, but I found a F20 that was being broken that had Xenon's and HBA (the FLA camera). I ended up getting both of those, and waited to fit the Xenons as I wanted a to take my time with doing so as that retrofit is longer to do. So I decided to retrofit the FLA camera as it was a quick retrofit and VO code it and see if it would work with halogens. Went on a night drive on a quiet country road and low and behold, the high beams came on. I'll be honest I was surprised as everything I read online was that HBA only works with Xenons as they come together.
So if anyone has halogen headlights and wants to retrofit HBA, it can be done
However now that I have also retrofitted the xenon headlights, I can tell you that halogen headlights are dogsh*t. Xenons are miles better and the difference is night and day. Car looks nicer, and Xenons are simply a game changer at night. I also have the adaptive Xenons so watching the lights move left and right is nice to see.
(This next part is only for people who retrofit the auto dimming mirror if their car did not come with it, as mine came with the manual dimming mirror)
Powering the mirror from KL15 from the rain sensor causes issues, as the mirror/FLA camera requires KL30, which is a constant supply whereas KL15 is only activated by the ignition. This causes the car to not go to sleep once it's turned off, causing some issues. I posted about this on another post on this forum.
TL;DR, HBA assist works with halogen headlights, but is worth it more if you have Xenons
The mirror/FLA camera wired to the rain sensor for power causes some issues if your car doesn't come with the auto dimming mirror as standard
Hope this helps anyone
      10-09-2021, 03:44 PM   #72
wheeljack
Drives: F36
i think it will be mine solution - i make the power from rain sensor, then i need change it and check after
THX !
      12-18-2021, 05:55 AM   #73
aaron84
Drives: BMW M4 F83 Silverstone Metalli
Hi everyone. I know this is an old post but I came across this and decided to get hba too. I have the xenon headlights and bought fla camera and hba stalk. I've got it all wired up and then got into the coding (which I'm not very good at) but have found myself stuck. I added 5ac to the FA. When I go to create cafd file, I checked my car's I step level and confirmed it to be F020-17-07-504. My issue is when I open the caf selection list, my i-step level doesn't come up on the list. The last one on the list is F020-17-03-509. Any ideas would be greatly appreciated guys. Thanks 😊
      12-18-2021, 06:27 AM   #74
aaron84
Forgot to add I'm using psdzdata version 4.32.33 lite and e-sys 3.30.1-49938
      01-29-2022, 10:27 AM   #75
Jarda_V
Drives: BMW F31 320XD
Hi, do you have any solution on how to automatically activate HBA on BMW F36 MY 2015?
I have FLA only. It is retrofitted. I would also appreciate any recommendation regarding HBA timeout. Can be somehow coded? It seems that switching ON/OFF takes 1,5 seconds.
Subjectively it was faster on the previous car where HBA was from the factory. Thank you
      11-01-2022, 06:39 AM   #76
aluzjunior
Drives: BMW 320i GT
Hello. Can someone hlep me? My 2017 320i GT (LCI) only has auto wipers, consulting RealOEM the correct steering column switch for auto Hi Beam is code 61319351145.
I can´t find, even on Ebay.
There's a similar model that I can use?
      11-01-2022, 07:16 AM   #77
Siki78
Siki78's Avatar
168
Drives: F30,G30
04 Switch unit steering column 03/2017 05/2018 61316996596 ENDED
04 Switch unit steering column 03/2017 03/2019 61319490792 ENDED
04 Switch unit steering column 03/2017 61319474855
https://www.ebay.ch/itm/204128921857...Bk9SR7StpbKGYQ
https://www.ebay.ch/itm/165681149692...Bk9SR7StpbKGYQ
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      12-13-2022, 02:32 AM   #78
jonnybthegoalie
Drives: 2014 335i xDrive 6MT
Hi, sorry if this is a kinda a dead thread but I have been looking into retrofitting HBA into my car and have some questions that I cannot find the answers to. My car is a ‘14 F30 and came from factory with steering heating and driving assist, so I have the KAFAS camera. Do I need to get my switchgear from a car that came with steering wheel heating.. or?
      12-13-2022, 02:46 AM   #79
Siki78
Siki78's Avatar
168
Drives: F30,G30
You will need change steering column. Write your full VIN I can check for you
      12-13-2022, 05:12 PM   #80
jonnybthegoalie
The vin for my car is WBA3B9C5XEJ466116
      12-14-2022, 01:17 AM   #81
Siki78
Siki78's Avatar
168
Drives: F30,G30
You will need this steering column 5AC in VO and VO coding KOMBI,KAFAS,NBT,FEM_BODY.
Maybe you will need to change headlight housings but not sure because your car are from US or add 5AP in VO
      12-23-2022, 04:54 PM   #82
ford1234
Drives: f30 328xi
there is video on youtube! its via fla. Youtube video:
Anyone know, how to coding via kafas camera? My car have OEM Kafas. Also I am looking for coding Front Collision Warning. OEM set to early still too late and didnt feel auto brake. And also looking for how to change Lane Assist set lower than 70km/h.
      12-29-2022, 09:50 PM   #83
m4forum
Drives: M3
Need some help.
I retrofit and code per instructions. For some reason the car doesnt like the steering column switch I installed ....146. Both stalks left or right not working.
I-Step : F020-18-03-532
Can I code SZL?
      12-29-2022, 10:42 PM   #84
Siki78
Siki78's Avatar
168
Drives: F30,G30
You can code FEM
      12-30-2022, 05:49 AM   #85
m4forum
Drives: M3
I did. code FEM, KOMBI, Head unit and FLA.
actually check on FEM the SZL type and was correct : SZL_aic_4band_fla (heated wheels, high beam assist and rain sensor).
On F30 SZL is not a separate ECU so it wont show on Esys meaning there is not specific coding for SZL.
      12-30-2022, 02:39 PM   #86
m4forum
Drives: M3
I end up replacing the steering column I got and fixed the issue. Was a bad SZL I got for the retrofit. Just need to wait to test it during the night.
      12-31-2022, 08:58 AM   #87
m4forum
Drives: M3
Tested it ... works perfectly. Just follow the instructions and will get there. Thank you for sharing the guide.
      01-04-2023, 07:03 AM   #88
TheoneLT83
Drives: F30 328i and e92 330d
Hello, can I change only camera and leave my old mirror?
