| 05-31-2016, 04:37 PM | #67 | |
Rep 942
Drives: 2012 328i Modern Line
:wave:
| 10-09-2016, 09:02 AM | #69 |
Rep 3,867
SchweiZ4, good work and post mate well done
![]() I got mine out today in 5 minute , didn't know what to do with phone holder ![]() Good post and keep it up mate . |
| 04-13-2017, 01:03 PM | #71 |
Rep 942
Would this HSD cable connect to the remaing cable in the console after you remove the phone adapter and plug into the USB port available on realoem?
https://www.ebay.com/itm/381913268301 |
| 11-30-2017, 10:02 AM | #72 |
![]() ![]() ![]() ![]() 427
Rep 779
Inspired by this thread I decided to remove the phone cradle and utilise the space better.
I have an old iPod touch permanently plugged into my car so since I owed my car my arm rest has looked like this... ![]() So I decided to remove the dock... ![]() The blue connector, left in the car, is effectively a USB that needs an adaptor so I bought one of these... ![]() It's not quite the right fit so you have just trim off a little sliver of plastic on the connector in the car. Then bingo, an extra USB socket. I then routed the iPod lead up to armrest and tucked the remaining wire neatly away. ![]() I used some scrap plastic foamex I had lying around and created an inlay for my iPod then finally topped it off with the 'compartment matt' (51169227902). ![]() ![]() ![]() The graphic on the iDrive even seems to fit too... ![]() ![]() Last edited by Dyl; 12-01-2017 at 09:04 AM.. |
| 12-03-2017, 02:56 AM | #73 | |
Rep 942
What did you need to trim?
:wave:
| 12-03-2017, 10:11 AM | #74 | |
Rep 779
If you see this post earlier in the thread the connectors are slightly different dependant on colour. to make the blue connector fit in the green you just have to knife or with fine cutters take the bit of plastic off that stops you just pushing it on. It's just a little ridge of plastic. ![]() Last edited by Dyl; 12-03-2017 at 11:17 AM.. |
etinifni215.00 |
| 12-08-2017, 03:24 AM | #76 |
Rep 779
| 12-10-2017, 08:55 AM | #77 |
¯\_(ツ)_/¯
537
Rep 1,000
| 12-10-2017, 10:16 AM | #78 |
Rep 779
No, they are separate usb connections to the head unit. If you look at the last picture, on my earlier post, of the idrive screen the original usb socket in the arm rest is the top one with nothing connected when the picture was taken
| 12-19-2017, 10:11 AM | #79 | |
Rep 476
One question, does the Ipod Touch show Album Art? |
Dyl426.50 |
| 12-19-2017, 10:30 AM | #80 | |
Rep 779
Sure does. ![]() Last edited by Dyl; 12-20-2017 at 07:44 AM.. |
| 01-21-2018, 10:16 AM | #82 |
¯\_(ツ)_/¯
537
Rep 1,000
I did this today it was fairly easy, but this cable for some reason was the biggest pain in the ass to disconnect
| 01-21-2018, 02:00 PM | #83 |
I used to be conceited. Now I'm perfect.
633
Rep 1,847
Drives: 2018 M3 CS
Thanks so much for this amazing DIY. I did it today on my F87 M2 and it worked flawlessly. One difference I found is that there's only 2 wires to disconnect.
| 02-01-2018, 04:36 PM | #84 | |
Rep 476
£25 all in. £10 adaptor from China and second hand try for £15??
F25 X3 35d - F30 335i - |
Dyl426.50 |
| 02-01-2018, 06:10 PM | #85 | |
Rep 779
Underlay actually looks like it does the job okay, I'd stick with that, It might be easier to remove the iPod to add music etc. I've been too clever/neat for my own good and removing mine requires a blade of some description. Although, tbf I've not actually taken it out since I put mine in. |
Iyrix106.50 |
| 03-01-2018, 02:38 AM | #87 |
Rep 476
This was such a good modification. Don't even know the iPod is there now and I've put a usb drive in with random media and films for the kids.
| Bookmarks |
