05-04-2017, 11:20 AM | #67 |
Rep 123
05-04-2017, 11:22 AM | #68 |
Rep 123
05-04-2017, 11:08 PM | #69 |
Rep 117
05-05-2017, 05:38 PM | #70 | |
IG @bmwF9xG80
3817
Rep 7,595
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
05-05-2017, 06:52 PM | #71 |
Rep 117
I just asked the question and they replied "we are not sure, we cannot answer your question, please check the product description.".... not very helpful.
05-05-2017, 07:09 PM | #72 | |
Rep 123
06-15-2017, 11:25 AM | #74 |
Rep 123
06-15-2017, 12:52 PM | #75 |
Rep 1,801
Im a diy guy, but I'm prob gonna let my shop do this, and assist with the install. The last thing I want is boost leak from not installing it properly. Any noticeable improvement? I'm currently running Jb4 map5, dp, filter, mpe.
06-15-2017, 08:06 PM | #76 |
Rep 123
a little more noise and better throttle response. peace of mind is key here. you don't have to worry about blowing anything. I have atak exhaust cts intercooler and charge pipe and TIC. deciding on jb4 or BM3 and trying to find the best catted downpipe.
06-16-2017, 10:06 AM | #78 | |
Rep 95
This is covered in the first page of the thread:
FSociety3816.50 |
06-30-2017, 12:43 PM | #80 | |
Rep 710
I have no idea what size t-bolt clamps, sorry. I believe it came with one new o-ring for the top near the throttle plate, and you reuse on old o-ring for the connection to the intercooler. Just make sure to lube both with a little oil so you don't crack one and cause a boost leak!
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
06-12-2018, 08:35 AM | #81 |
TH320i
23
Rep 41
Just ordered the FTP Charge Pipe for N20 motor from the official site.
https://www.ftpmotorsport.com.tw/pro...ation-packages should arrive in a couple days will update when it arrives...
2012 BMW 320i - Catless DP - Full 3" exhaust system - Cold Air Intake - S55plugs - GFB DV+ - ProjectA Stage 2 Remap (270 hp on E20).
06-13-2018, 08:37 AM | #82 |
TH320i
23
Rep 41
Package arrived ordered 8am on the 12th arrived 1pm 13th Taiwan to Thailand.. Fastest i have ever received anything from overseas.
Will update with pics of product and pics of after installation.
terryd5150507.00 |
06-15-2018, 03:26 AM | #83 |
TH320i
23
Rep 41
Sorry if this has been answered already, but that Black clip that we have to take off the OEM Charge-pipe do we need it for the aftermarket FTP Charge pipe ? or can i just snap that b*strd off...
thanks guys! about to do the install on mine tomorrow morning. just wanted a heads up.
06-15-2018, 08:11 AM | #84 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
06-19-2018, 03:26 AM | #85 |
TH320i
23
Rep 41
Update:
So i got the charge pipe installed went out for a drive and no boost at all not one bit... funny because before the charge pipe install it was boosting 3-4, psi now max i can get is 0.1psi which is nothing ... When driving i hear a whistle sound but cant seem to determine what side of the bay it is coming from... Ive doubled checked all the o rings and fitment of the parts... I originally just changed the Cold side, thinking about doing the Hot side to rule out that. Getting a bit worried about my Turbo i hope it hasn't crapped itself and given up ... Any Help would be greatly appreciated! Cheers guys.
06-21-2018, 07:33 PM | #87 |
TH320i
23
Rep 41
Sorted it out guys.. the vacuum connector on the FTP charge pipe isn't 100%, on my one it seems to pop off quiet often...
Right now running stock charge pipe again until i can find a solution to the loose vacuum connector.. Everything is running fine again doing pulls and holding 22psi no problem.
06-22-2018, 12:29 AM | #88 | |
Rep 509
22psi on 320i with 1:11 compression ratio? you're brave
charge pipe, cheap, ebay, ftp, xdrive |
