06-15-2018, 05:21 AM | #67 |
Rep 69
06-15-2018, 07:12 AM | #68 | |
Rep 69
iBrightstar Newest 9-30V Super Bright Low Power 7507 PY21W BAU15S 2641A LED Bulbs with Projector replacement for Turn Signal Lights,Amber Yellow https://www.amazon.com/dp/B075Q9RGZW..._XZ6iBb0X1EH1T No issues to date. |
06-19-2018, 01:36 PM | #70 |
Rep 57
Looks like a great inexpensive mod. I hate the factory halogens. One question though; the link you provide for the low beam replacement LEDs leads to H1 bulbs. I don't see an option for H7...? Are they different?
06-19-2018, 01:50 PM | #71 | |
Rep 68
Not sure why the option is gone from the original link |
06-19-2018, 03:41 PM | #72 | |
Rep 57
Thanks man. |
06-24-2018, 03:54 PM | #73 |
Rep 4,554
Drives: 2015 328d xDrive
I bought the same LED's that were linked for the low beams for the highs as well, but unfortunately they didn't fit. There's a piece of plastic in the headlight that prevents them from sitting in the housing correctly.
Is anyone running LED's in their highbeams? If so could you show me which bulb you're using? Thanks. |
06-24-2018, 04:34 PM | #74 | |
Rep 16,199
http://f30.bimmerpost.com/forums/sho....php?t=1377259 |
06-24-2018, 04:40 PM | #75 | |
Rep 4,554
https://www.amazon.com/dp/B074YH3X6G..._t3_B01IAC8QSC |
06-24-2018, 04:48 PM | #77 |
Rep 4,554
Right, sorry what I meant is it's not a solid metal chunk type of heatsink. Since they're flexible ribbons I think they'd be a perfect solution to the highbeam fitment problem. I just wonder if they're safe to leave strewn about the inside of the headlight amongst other wires.
06-27-2018, 11:46 AM | #78 |
Rep 57
I completed this procedure on my car last night, for the DRLs and low beams only for now.
Couple of thoughts: First, this is totally worth it, looks awesome and visibility is greatly improved. Second, this has to be the worst headlight setup I have ever seen. Most cars these days use big plastic retainer rings or just fixtures that are designed for the lamp assembly to twist into place. These stupid metal tabs are sharp as hell, and with no room to maneuver or the ability to see what the hell I was doing I cut my hands all to hell doing it. And I’m not a mechanical newbie by any stretch. That said I’m glad I did it, thank you for the write up. |
06-30-2018, 06:38 PM | #79 |
Rep 69
Do you get flickering when starting up the car on the turn signals? I coded out the warm and cold checks and there’s no flickering when using it but it flickers at start up. Wondering which code I didn’t code out for the cold and warm checks. If you can screenshot your Bimmercode set up for the turn signals I’d appreciate it.
07-01-2018, 12:20 PM | #80 | |
Rep 68
07-01-2018, 12:22 PM | #81 | |
Rep 68
07-09-2018, 09:00 AM | #82 |
Rep 10
LED H7 Bulb install problem
Hello,
I received today LED light from HIKARI, but I have problem with installation. I Have BMW 318i 2017. And in Light lamp is H7 mounted with some special holder and holder is screwed into the light. Here is photo: Looks that I need some adapter... Any help? |
07-09-2018, 12:01 PM | #83 |
Rep 21
I just did all my fronts except High Beams this weekend. I coded them to LED bulb type plus turned off all warm/cold checks. No errors or flickers so far and everything seems to work.
I bought the same DRL and Parking bulbs as the one in the OP. For the rest: Low Beams, Turn Signals, Fogs |
07-31-2018, 11:54 PM | #84 | |
Rep 4,554
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 They fit great and are bright as hell. No fans either so less moving parts/noise/chances for things to fail/break. They also solve the highbeam fitment issue that you get with LED bulbs that have conventional fans/heatsinks. |
08-02-2018, 07:43 PM | #85 | |
Rep 2,036
Or did they fit the Oem headlamps?
08-10-2018, 02:52 PM | #87 | |
Rep 57
08-21-2018, 06:50 PM | #88 | ||
Rep 4,554
https://www.amazon.com/dp/B077D8KZLV..._fxkFBb3QC67WW
