| 04-22-2018, 09:18 PM | #67 | |
![]() ![]() 112
Rep 316
Drives: 2014 335i MSport, 2001 X5
The BT audio didn't work right away. I gave up on it for the night and to my surprise the next morning it worked. I coded the mirrors yesterday and didn't drive today so we'll see what happens once the weather gets better.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT green/black, well-optioned |
| 04-22-2018, 09:20 PM | #68 | |
Rep 8,407
If using Cheat Codes for mirrors, make sure to "Review" as functions move around. |
soncar0.00 |
| 04-27-2018, 09:20 PM | #69 |
![]() ![]() 112
Rep 316
As I didn't alter the folding delay, I didn't know that holding the lock/roundel button down for 2-3 seconds would fold the mirrors after this coding. It woiks! Unfolds on pressing the unlock button as well.
| 05-15-2018, 02:53 PM | #70 | |
Rep 4
![]() Last edited by Steph71; 05-15-2018 at 03:20 PM.. |
| 05-15-2018, 05:06 PM | #71 |
Rep 8,407
Dealerships will not do it. Are you sure you have correct hardware for function? Based on your region, no coding would be necessary.
| 05-15-2018, 05:14 PM | #72 | |
Rep 4
I'm using Bimmercodes app with a Vgate 2 wifi OBD and have made the in app purchase to unlock the features. I'm a complete novice coding but had some success coding other things in the car (mirror lights on with reverse, video in motion...etc) so I'm fairly confident in expert mode. I got them to fold once with the fob after coding, but the code I used ended up deactivating the folding roof function on the switch inside the car (the fob doesn't fold the roof) so rolled back to the back-up in Bimmercodes. |
| 05-15-2018, 05:18 PM | #73 |
![]() 12
Rep 178
From all of the posts gathered so far, there is no way to code on an F33 to have the mirrors fold via keyfob correct? They only way is to deactivate the folding roof (which we obviously wouldn't want). Has ANYONE been successful in coding the folding mirrors on a convertible? I have a 428i and have had no luck, using all of the knowledge in this and many other threads.
| 05-15-2018, 07:55 PM | #74 | ||
Rep 8,407
I assume you tried this: Quote:
| 05-16-2018, 03:16 AM | #75 | |
Rep 4
There must be a further link between the two codes but I don't know waht else to try. |
| 03-07-2019, 12:00 PM | #76 | |
Rep 7
I have an F33 from the end of 2016, December and without access control I coded so that the mirrors could be folded with the control and also the windows could be opened and closed with it. It suits me very well, because you can fold the mirrors when you leave the car parked and is less exposed to unexpected encounters, to open the windows on hot days and a little air before entering, facilitates the entrance because if the window is up with that superportion that has almost got you in the throat especially if you're parked in battery and you can not open it at all. To raise the windows if you have closed the car and you have left one or several windows open and that if you do not have this option you have to return to open the car give the contanto and close them. In order that I see this coding very useful. But look where, after having made this coding, a great day arrives and I start to open the roof and I give the command that is located in the armrest and the roof does not open. Well, I tell myself, I know what happens, I have not lowered the tray of the trunk. I lower myself, I check that the tray is lowered and anchored and I give it back to the command to open the roof and it does not work either. Well, I'll have to reverse all this decoding that until I got the roof so many joys had given me. I was leaving, I guess because of laziness. One day, I do not know why, I lowered the windows with the button that lowers the four windows at the same time and I do not know why, I give the button to open the roof and it starts to open. So right now I have the coding of the folding mirrors with the knob, open and close the windows with the knob having it pressed until they open or close completely and I can open the roof. The roof opening is not automatic as it was before coding, but it can be opened To open or close it, you have to lower the windows at least halfway through, the four windows and you can already hit the roof opening or closing button to act. If you go to close the roof and it does not work and you see that your window is down, do not panic, look to see if the other three are down at least halfway. It has happened to me and scared, until I realized. Well, go bricklaying. If somebody has served him phenomenally |
| 03-15-2019, 06:03 PM | #77 |
Rep 1
I definitely have done the coding method from Almmareto, and it’s works very well on my F33 convertible from 2015 with electrical side mirrors and no access comfort,. You really have the switch of the FEM BODY 3053 FH CABRIO VERDECK MODULE for have the electrical mirrors side mirrors up and down with your car keys, and for the rest see just this post explaining from Ulbacha everything you need to know, amazing thanks.
My configura: thanks Ammareto, FEM_BODY 3053 KOMFORTOEFFNUNG_FB aktiv FEM_BODY 3053 KOMFORTSCHLIESSUNG_FB aktiv FEM_BODY 3053 KOMFORTSCHLIESSUNG_PA aktiv FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN aktiv FEM_BODY 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN aktiv + If you want to decrease initiation delay FEM_BODY 3053 KOMFORT_SCHLIESSEN werte = 00 FEM BODY 3053 FH CABRIO VERDECK MODULE ................................. |
| 03-30-2019, 01:17 PM | #78 |
Rep 34
Does anyone know if you can set the distance the mirrors fold? My passenger mirror folds in too much and actually rubs against the plastic on the outside of the car resulting in an annoying creaking/rubbing sound whenever I fold my mirrors.
| 04-27-2019, 11:46 AM | #79 | |
Rep 102
F33 key fob coding
Thanks for all the great info in this thread, it has helped me get 90% of the way there. The only thing left is to find a way to code so the key fob folds the mirrors without disabling my roof switch in the centre console. Any thoughts welcomed Last edited by contracts34; 04-27-2019 at 12:35 PM.. Reason: Spelling |
| 04-29-2019, 04:32 PM | #80 | |
Weekend Driver
Rep 113
Any solutions or settings to delay the roof?
"I paid too much for it, but it's worth it."
| 05-04-2019, 12:48 AM | #81 |
Rep 8,407
No, sorry, I do not have a solution for cabrios.
| 05-20-2019, 02:22 PM | #83 |
![]() 28
Rep 165
| 05-21-2019, 10:50 AM | #84 |
Rep 102
Another frustrating thing I've discovered is that with the 3053 FH CABRIO VERDECK MODULE to nicht_aktiv,coded to inaktiv (which disables the cabrio roof switch but allows mirrors to fold/unfold on key fob lock/unlock) if I open all the windows, the roof can be opened/closed from the switch!!!
There must be some connection with the window switch/roof switch/mirror fold, but I'm damned if I can find what it is. Any techies out there looking for a challenge ![]() Last edited by contracts34; 05-21-2019 at 10:53 AM.. Reason: update |
| 08-28-2019, 08:00 AM | #85 |
Rep 47
Folding mirrors VO coding
Anyone knows which ECUs should be VO coded when adding 430 to the FA?
I prefer VO coding versus fiddling with the FDL editor. |
| 08-31-2019, 04:32 AM | #86 |
Rep 183
| 05-02-2020, 12:34 PM | #87 |
Rep 15
Hi all.
Just done power folding mirrors on my car , after connect all cables and coding , still not working , was messing around couple of hours and find out it work from the fob but not from the switch in drivers door . I added 430 to Fa also coded FEM_BODY 3053 KOMFORTOEFFNUNG_FB aktiv FEM_BODY 3053 KOMFORTSCHLIESSUNG_FB aktiv FEM_BODY 3053 KOMFORTSCHLIESSUNG_PA aktiv FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN aktiv FEM_BODY 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN aktiv I have to code last 3 , as first two was already aktiv After scan it with ISTA , it shows a fault : switch block on driver door wrong type installed Exterior mirror Left/Right (LIN) unexpected Lin -slave Is there a few types of switches , or just two, with or without button to fold mirrors .... i change it for one with switch , not sure if that has to be coded now ??? Any ideas ??? Thanks |
| 06-09-2020, 11:45 AM | #88 |
Rep 1
435d convertible 2017
I don’t have CA, but electric folding mirrors, trying to setup to fold automatically by keyfob, when opening closing the car. I tried BimmerCode and all settings, but it doesn’t fold, any suggestions?
| Bookmarks |
