BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > People who coded 6NH to 6NK Bluetooth Audio
Closed Thread
      10-16-2013, 01:23 PM   #67
Vitoco
Infidel
Vitoco's Avatar
399
Drives: G61 530e RWD O.G M Sport Pro
Originally Posted by shawnsheridan View Post
No. You can check your trunk to see if physically you have one, as shown above in Post # 45.
I did that before I posted, lifted the hatch/floor to the trunk compartment. There was nothing there, but I dont believe a combox would be placed there in an F31 either, cause its a really vulnerable spot considering you lift this hatch whenever you wanna put or take stuff out of there. Ill try and take a pic later so you can see what I mean..
Oct. 2024: G61 530e RWD M Sport Pro Oxide Grey w. Shazam-Bronze Accent
Former:
Dec. 2022: G08 iX3 LCI M Sport Pro Fully loaded Carbon Black, sold Sept. 2024.
Oct. 2012: F31 328iA RWD M Sport Glacier Silver, sold Jul. 2022
      10-16-2013, 01:38 PM   #68
Vitoco
Infidel
Vitoco's Avatar
399
Ok I found a pic here that shows exactly how it looks when lifting the cover. Impossible to lift that cover to see whats hiding in the upper right corner...
Former:
      10-16-2013, 05:53 PM   #69
unter
Drives: 2014 F30 335i basic black
US basic 2014 335i + parking pkg
Ordered US basic 2014 335i + parking pkg (rear view camera). I didn't think I need to pay for anything else to my taste. However I would like to know if it is going to have combox everybody talking about to code Enhanced Bluetooth.
In threads was noted the difference between 2013 and 2014. What I will get? Anybody knows?
      10-16-2013, 06:51 PM   #70
Stokkes
Grand Pumba
Stokkes's Avatar
230
Drives: On Order: i5 M60 IOMG/SWV
Nothing to worry about, Enhanced BT is all built into the MY2014 NBT head unit.
      10-17-2013, 01:50 AM   #71
Vitoco
Infidel
Vitoco's Avatar
399
I actually did manage to look what was underneath and sure enough that is the fuse box to the right and to the left is where the combox WOULD have been..
But he said he ordered a basic F30, I take that as with NO nav meaning no NBT? The european F31:s are like your MY14 F3x´s, they came with the NBT (had you opted for it..)
Former:
      10-17-2013, 01:38 PM   #72
unter
That is exactly what I said. NO nav. Navigation is an option and I didn't need it. So, to worry or not to worry?
      10-17-2013, 07:33 PM   #73
Stokkes
Grand Pumba
Stokkes's Avatar
230
Check the 2nd page of this thread. It looks like if you have a US MY2014 without Nav then you may be out of luck as even a combox cannot be retrofitted on these models.
Ordered: i5 M60 Isle of Man Green (Apr 6, 2024)
Status: Production # received (Apr 11, 2024)
      10-18-2013, 05:56 AM   #74
Vitoco
Infidel
Vitoco's Avatar
399
Well no one on page 2 said it cant be retrofitted, it was stated that a standalone combox wont be available for US MY2014. As Ive said earlier my F31 is NBT-based, but I didnt get the nav, yet I was still able to choose the enhanced BT separately had I wanted. Meaning I would most likely have a separate combox if I opted for the enh. BT ; in other words a combox retrofit should work...? Another "proof" is that when I managed to check what was next to the fuse box (see above post with pic) I found the holders and even a cable with a plug connector, on the place where the combox would sit.
So if I get a combox, how many plugs do I have to connect for it to be correctly installed? Is it that single plug or would I have to draw more wires from the dash? What does the installl require?
Former:
      10-18-2013, 07:39 AM   #75
shawnsheridan
Supreme Allied Commander
shawnsheridan's Avatar
We need to examine a 2014 that has Enhanced Bluetooth and no Navigation. I suspect it may not have a standalone Combox, and that the enhanced Bluetooth is built into the Head Unit (HU_CHAMP),same as it is built into NBT. Then the question is will there be only one non-Nav Head Unit (HU_CHAMP) that anyone can code Enhanced Bluetooth on, or will there also be a non-Enhanced Bluetooth Version (HU_BASIC) that cannot be coded. And if the latter is the case, then we need to determine if one has HU_BASIC, can a Combox be retrofitted for use with it.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      10-18-2013, 08:49 AM   #76
Vitoco
Infidel
Vitoco's Avatar
399
That´s exactly right.
I will get my coding cable soon, don´t know how to code but if I have the correct software (e-sys plus some other program, right?) I can start looking at what mine says if that will be of any help...
Former:
      10-18-2013, 11:55 AM   #77
shawnsheridan
You need E-Sys and PSdZData files.
Yes, it will help. We can at least see what ECU's are listed in SVT, and if it has HU_BASIC or HU_CHAMP, and CMB_MEDIA.
      10-19-2013, 12:54 AM   #78
chiefy
chiefy's Avatar
Drives: BMW 330d M Sport
Could any one please give me clear instructions on how to change 6NH to 6NK. I've just recently setup the software and I'm new to the whole coding thing.
      10-19-2013, 10:01 PM   #79
shawnsheridan
1) Read this Guide:
How to change FA in F-series car:
http://www.f30post.com/forums/attach...4&d=1338274757
Afterward, you should understand how to replace 6NH with 6NK in your VO.
2) VO Code HU_CIC and CM_MEDIA ECU's:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
      10-21-2013, 05:27 PM   #80
ipp
Sweden
22
Drives: 2016 M135i
I have a non-nav F31 with enhanced Bluetooth, I can check if I have the combox in the trunk or not, if that's for any help.
      10-22-2013, 02:45 AM   #81
Vitoco
Infidel
Vitoco's Avatar
399
Former:
      10-22-2013, 06:29 AM   #82
ipp
Sweden
22
Drives: 2016 M135i
Ok, with "have" I mean that I'll pick it up this Friday... I will revert ASAP...
You don't happened to live in Malmö, if so we could have a coding session.
      10-22-2013, 08:56 AM   #83
Vitoco
Infidel
Vitoco's Avatar
399
Haha no problem, I´ll wait patientely!
That would be great but I´m afraid I live to far north, in Norrköping
Former:
      11-04-2013, 03:54 PM   #84
ipp
Sweden
22
Drives: 2016 M135i
Here is a pic from my F31 with no nav but with BT Pro.
      11-05-2013, 05:51 AM   #85
Vitoco
Infidel
Vitoco's Avatar
399
Ah, cool. Congratz on the new car
Former:
      11-07-2013, 07:29 AM   #86
NitramA
Drives: BMW 320D modern
1) Read this Guide:
So I followed the instructions and changed 6NH to 6NK.
I verified that the changes have been saved, but I can't get Bluetooth Audio to work from my phone.
I've a fy14 F30 with Prof media sat nav, but I only see the phone under the bluetooth settings, nothing about audio.
Am I missing something here?
Thanks.
      11-07-2013, 08:36 AM   #87
NitramA
Thanks.
I've been thinking about this and wondered if its something to do with the statement "2) VO Code HU_CIC and CM_MEDIA ECU's:"
I haven't patched or bought a token yet as looking around the forum it seemed that EBT could be enabled without a token.
Do I need to get the token to be able to set the HU_CIC / CM_MEDIA ecu's?
A little knowledge is a dangerous thing!
      11-07-2013, 09:24 AM   #88
Frogman
Drives: 2012 F30 328i
Thanks.
If you have a NBT based HU, then try changing 6NH to 6NS (instead of 6NK) and re-VO code the NBT.
Do you have a CMB_MEDIA ECU? The combox is built into the NBT HU, so you should not see a separate CMB_MEDIA ECU in your SVT list.
Closed Thread
