09-16-2020, 04:41 PM | #8889 | |
Rep 2,352
https://f30.bimmerpost.com/forums/fo...play.php?f=373 https://f30.bimmerpost.com/forums/fo...play.php?f=412
09-17-2020, 02:15 AM | #8890 |
Rep 356
09-18-2020, 08:28 AM | #8891 |
Rep 833
Drives: BMW F36, E36, E93
Got my Ceramic I-Drive mod installed matching the Ceramic shifter
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
09-19-2020, 04:55 AM | #8893 |
¯\_(ツ)_/¯
958
Rep 1,766
Have a nail in the right rear tire so it's leaking around 10psi overnight. Will get it patched today/tomorrow
09-20-2020, 12:13 PM | #8895 |
Rep 611
Installed the M3 leather steering wheel trim, including the rear piece. Beautifully crafted, perfect match to my dark grey wheel and surprised the added weight improves the steering feel.
09-20-2020, 02:19 PM | #8896 |
Rep 4,031
Cleaned it up!
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
J555571.50 thatBimmerBloke887.00 |
09-20-2020, 06:49 PM | #8897 |
Rep 113
installed the B14 bilsteins today.
car is filthy, drove to Utah this weekend prior to install. took it for a spirited drive....and they aren't as harsh as people claim. hoppy at times, low speed road imperfections are more pronounced but not totally uncomfortable, speed bumps are definitely harsher. on the freeway and even rough road....overall satisfactory! handling however is great. taking turns at 25 to 30mph is solid! |
haagm58820.00 thatBimmerBloke887.00 |
09-20-2020, 06:53 PM | #8898 |
Rep 60
It looks good, I’m thinking about doing the same thing to mine... may I ask how hard was it to install and did you have to reprogram or do some coding after the install? Not sure if when I install mine I will loose the vibration warning. Any input will be greatly appreciated.
09-20-2020, 07:08 PM | #8899 |
Rep 60
09-20-2020, 10:06 PM | #8901 |
Rep 1,288
Installed MHD E20 map today... from 4100 to 6400 I was a fat 4.1+time on the 95tune... this E20 tune I'm solid 3.8time... I'm very very Happy...
Next is fuel pump upgrade... https://datazap.me/u/fastf30/log-160...=4-10-19-20-21 |
haagm58820.00 |
09-21-2020, 07:48 AM | #8903 | |
Rep 611
- disconnect the battery - remove the airbag - disconnect and remove the steering wheel - remove the front trim, remove the paddles, remove the rear trim - install the new trims, install the steering wheel, put the airbag back and connect the battery You can find loads of good instruction videos on youtube. No big deal, no coding, just a few comments: - pay attention to use the same screws in the same original locations, - before adding the front trim, make sure the holes for releasing the airbag are clear and not obstructed by any connectors or cables (can be a bit tricky if your wheel is loaded with all features as mine), - the vibration unit does not need to be touched. However, within M Sport wheel, it is covered by foam, that does not fit the M3 trim. You can either cut a piece from it or remove it entirely (I did the latter and the vibrations are a bit more apparent, which I consider good) |
09-21-2020, 11:42 AM | #8904 | ||
Rep 919
Drives: F30 328d Sport Line
09-21-2020, 09:45 PM | #8906 |
Rep 913
Drives: G20 M340ix; F30 330i Msport
Washed it on Sunday, after all these years the F30 is still one of the best looking cars on the road today IMO
09-22-2020, 07:54 AM | #8907 |
Rep 424
Got a set of wheels for winter
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
09-23-2020, 06:27 AM | #8908 |
Rep 1,046
Wife's been driving the F30 (which is badly needed since covid) while her car is at the shop. Here's the loaner they gave us. 2020 E350 with the AMG package.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
09-23-2020, 01:15 PM | #8910 |
Rep 611
Another week another wash... the white car curse
MSCD3178.50 thatBimmerBloke887.00 |
