06-23-2019, 12:48 AM | #881 |
Rep 387
I tried the laptop to phone and it did not work. Bm3 app on phone could not detect obd agent. I had the laptop connected to obd. Ran the laptop agent to ready. Signed on bm3 app on android. Then it doesn't detect the obd agent.
06-23-2019, 10:22 AM | #882 |
Rep 121
Drives: 2017 340i M-Sport
Was the phone set to hotspot with the laptop on its wifi?
06-27-2019, 02:36 AM | #884 |
Rep 145
Anyone hear any updates on fixing the rev hang on the manual cars? I have a xdrive 340 manual and always find the revs to jump up when taken to higher rpms and upshifting. (Foot completely of throttle when upshifting)
2018 MR 340i xDrive 6MT
06-27-2019, 05:34 AM | #885 |
Cheapskate
4464
Rep 4,995
Have you noticed that if you upshift and coast, the car still holds the rpm at the perfect rpm for the next gear? Honestly I'm starting to believe the rev hang is linked to rev matching to a degree. They might need to disable all of it in order for the rev hang to go away.
06-27-2019, 08:45 AM | #886 | |
Rep 521
Personally, I don't mind the 'hang'... the only time I even notice is if I'm at the drag strip or otherwise doing a true launch, that second gear engagement can nearly chirp the tires despite AWD. You really feel it. |
06-27-2019, 09:13 AM | #887 |
Rep 806
I have the rev match coded off and I use DSC OFF mode exclusively. I have intermittent rev hang most commonly on 1-2 shift sometimes 2-3 3-4 with the bm3 flash but not with my 2016-11 stock flash (I think .. I have to rollback and verify).
One comment was that if it wants to rev match .. it hangs until it knows if you're going up or down. But there's no 1-0 downshift so I don't buy that unless the brilliant engineer missed the most obvious edge case. I just can't figure out what makes it hang. Precise timing of gas/clutch/shifter may be it. |
06-27-2019, 09:45 PM | #888 | |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
kern4174464.00 |
06-28-2019, 05:05 AM | #889 |
Cheapskate
4464
Rep 4,995
Welp, there goes that idea. Thanks for the confirmation.
07-06-2019, 10:04 PM | #890 |
Rep 387
bm3 data log
anyone would be able to give me some input on my data log? was told i had retarding timing so i should get better fuel? Last edited by Mkswoosh; 07-06-2019 at 10:29 PM.. |
07-07-2019, 12:14 AM | #891 | |
Rep 132
Drives: OG M2
Is this the stock tune? The log file shows "Stock". What octane fuel and what mods are you running? I had similar issues on the stage 1 91 octane tune on our crappy CA 91 octane and have had fantastic results running the new ACN 91 tune.
M2 - TC Kline DA Coilovers - Apex SM-10s - 265 RS-4s - Dinan Intake - BM3 - CSF Intercooler - VRSF CP
Previous: 6th Gen Camaro SS 1LE | 2020 JLUR Wrangler | F30 340i | B7 Audi A4 APR Tuned | E46 330ci Instagram @track.n.trail |
07-07-2019, 10:45 AM | #892 |
Rep 96
Does anyone know which burble setting came with our cars from the factory? Oem or Original?
Also, whats the order starting with least aggressive for ranking Oem, Original and OTS. I've tried them all and can't really tell the difference. Last thing, I've messed with the custom setting and lowered aggression and duration all the way in sport mode to give the exhaust three different settings, one for each driving mode. TBH, can't tell the difference between sport and sport+ when I do this. Does the custom adjustment even work? |
07-07-2019, 06:17 PM | #893 |
Rep 387
ACN 91 stage 2 DATALOG
So this is my recent log after going down to ACN 91 Stage 2 from regular stage 2 91oct. even though quality gas shouldnt be that bad in Washington/Oregon State i have knock showing. any inputs on my datalog in the above link |
07-07-2019, 07:07 PM | #894 | |
Rep 1,449
07-07-2019, 07:35 PM | #896 | |
Rep 132
Drives: OG M2
Is this the v1.6 or v2.0 map? For me the v2.0 map greatly improved low rpm throttle closures like the one recorded here and may reduce knock as well. Are you running a stock downpipe or high flow/catless? I would try the Stage 1 map ACN map.
07-07-2019, 08:06 PM | #897 | |
Rep 387
This is 2.0 since I never thought i needed acn map till now. Im on catless downpipe. |
07-07-2019, 11:10 PM | #898 |
Rep 132
Drives: OG M2
Try logging a few more runs on the same gas and also on some different gas to see if the knocking is consistent. If so you may need to see if PTF will let you try the ACN91 stage 1 map.
Mkswoosh101.50 |
07-07-2019, 11:18 PM | #899 | |
Rep 387
Once I get some free time I'll run more logs in acn91 stage 2 and stage 1 wednesday night. Thanks for taking a look at my logs, I appreciate that |
07-08-2019, 10:21 AM | #900 | |
Cheapskate
4464
Rep 4,995
Original = Tuner's preferred burble recipe (same as OTS for OTS tunes, but different for custom tunes) OTS = PTF's burble recipe for the OTS tune that your tune is based on In my experience all will sound similar for typical OTS tunes. OTS is slightly more aggressive than OEM but not night and day difference. If you get a flame tune or something then you'll want to run "original" with the custom tune you choose. The custom burble stuff is confusing and I finally saw someone explain it properly. Sport and Sport + are under the same category. Pressing DSC Off is separate. I can't remember which one coordinates to which, but stay in comfort and turn of DSC to experience your other aggression setting. I'm pretty sure the exhaust burble settings are like this: Sport = Sport/Sport + Mode Sport + = DSC Off |
07-08-2019, 02:48 PM | #901 | ||
Rep 96
kern4174464.00 |
07-09-2019, 06:50 AM | #902 |
Cheapskate
4464
Rep 4,995
It would make more sense is sport = sport mode and sport+ = sport+ mode, but i don't make the rules lol
Shortgamer61.50 |
bm3, bootmod3 |
