05-18-2020, 07:14 PM | #903 | |
Rep 585
I use 1525 kg for the car with 1/2 tank fuel and then whatever the weight of the driver separately.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
05-19-2020, 07:47 AM | #904 | ||
Cheapskate
4522
Rep 5,003
Your IATs get up to over 140F. It also shows that your charge air temp dropped after the boost dip. The car begins running extremely rich, in the down to 11afr. Potentially the DME is protecting itself from high temps/detonation? Quote:
I have gotten mixed reviews from others but there are plenty that produce results. Cary Jordan, HCPerformance, Pureboost, Twisted Tuning...just depends on your platform and goals. Message the tuners to get a feel for what they offer and what they recommend for their goals. Then pick the one that has the best fit for you. |
IMS-340C454.50 |
05-19-2020, 09:19 AM | #905 | |
Rep 1,181
Thanks, so basically the ECU is trying to achieve the required targets while dealing with the low octane fuel and heat at the same time.
A friend of mine is running BM3 stage 2 in the same conditions I'll try to post his logs. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
05-19-2020, 05:53 PM | #906 |
Rep 35
Right so did another couple logs today on MHD 98RON stage 2, on exactly same fuel as before (Shell Vpower 99Ron), noticed that timing correction were a lot less and overall looked better. Looks like the ecu did need to adapt
Thing I'm slightly worried about is the 'timing delta for knock adapt'. Is this an actual indication of knock? reached -1.1 on one of the logs, which was a lot worse than my logs before. But timing seems to be okay. Would appreciate some help Both logs on this link: https://datazap.me/u/eldotbe/mhd-st2...37-38-39-40-44 Also looks like its pushing more power compared to before too on virtual dyno (Orange is the lastest) https://gyazo.com/26a3623d5e7ecc58bb9caa9e700c4d53 Cheers Last edited by Eldotbe; 05-19-2020 at 06:05 PM.. |
05-19-2020, 06:31 PM | #907 | |
Rep 585
05-19-2020, 06:48 PM | #908 |
Rep 46
05-19-2020, 07:03 PM | #910 |
Rep 242
05-19-2020, 07:47 PM | #911 | |
Rep 585
The timing delta for knock adaption is early in run 1 and decays quickly by 4500RPM. May be VANOS related as sometimes there can be knock like events between 2000 - 3000 RPM Run 2 delta for knock adaption is minor and timing is good. Timing progresses well to 14 - 15 degrees across all cylinders in both runs and area under the curve for power and torque are improved compared to other maps you've tested. I'd run that map for a while with that fuel and see how it settles in.
kern4174522.00 |
05-19-2020, 07:52 PM | #912 | |
Rep 585
As a minimum all you need is a couple of 4th gear runs from 2500 - 6800 RPM from a flat section of road with time stamp and RPM. That'll give you a pretty accurate WHP and lbft reading without giving away any tuning secrets. You can PM me if you prefer.
05-19-2020, 08:16 PM | #913 |
Rep 420
https://datazap.me/sites/default/fil...uns%281%29.csv
Yesterday I made a mixture of 15% E85 with 98Ron. Map Mhd 2 + hpfp 102 Ron. JB4 Map 6 with WMI. Time 100-200 7.3s easy. Watch the log with JB4. In my opinion, everything is fine.
M140IX. Turbo Pure 800 Cast.
OzBMR574.50 |
05-19-2020, 08:53 PM | #914 | |
Rep 585
Fuel pressure has a dip between 3700 - 4200 RPM?
05-19-2020, 10:09 PM | #916 |
Rep 420
Chris answered me in a letter that there would be an update from mhd about the sound of the pump, maybe this drop will be corrected.
05-20-2020, 02:18 AM | #917 | |
Rep 35
05-20-2020, 07:37 PM | #918 |
Rep 35
With regards to the ‘timing delta for knock adapt’ on the mhd logger, is that actually an indication of knock? What does it actually mean if not?? And what’s classed as a high value for this?
05-20-2020, 11:42 PM | #919 |
Rep 12
Hello guys! this is my log :
bootmod3 v2.0 stage 2 on 91 octane , looks in order? http://bootmod3.net/log?id=5e3eef3dd10b43292c8a4f7f |
05-21-2020, 07:43 AM | #920 | ||
Cheapskate
4522
Rep 5,003
OzBMR574.50 |
05-22-2020, 03:35 AM | #921 | |
Rep 585
The DME reduces timing target in case of pre-knock detection - that's timing delta for knock adaption. And corrects timing on the fly on top. If timing delta for knock adaption is close to 0, and if your timing is positive it is considered OK I think it's also important to have timing close to the same across cylinders, timing in line with typical map targets for octane, minimal timing corrections and good measured torque curve.
05-22-2020, 05:08 AM | #922 | |
Rep 35
Okay I get ya. On my latest log looks like knock is 0 for whole thing, tiny spike but on 0.1. Thing I noticed this time is that cylinder 1 corrects a lot more than the rest and is slightly behind by 2-3 degrees throughout. Is this something that will improve as the dme adapts? https://datazap.me/u/eldotbe/mhd?log=0&data=3-19 Couple weeks ago I knew nothing about this, am starting to understand it all now, crazy how much you can learn from some random people on a forum Last edited by Eldotbe; 05-22-2020 at 05:18 AM.. |
05-22-2020, 06:32 AM | #923 | |
Cheapskate
4522
Rep 5,003
OzBMR574.50 |
05-22-2020, 07:00 AM | #924 | |
Rep 585
The log data looks really good Big step up in power, must feel nice. It looks like 430 WHP and 450 lbft, very high for 99RON The power and torque curves for that run look identical to when my car had MHD 95_102 Stage 2 OTS, stock downpipe and E30 fuel Your HPFP rail pressure curve looks like one for E30 fuel too.
