11-10-2022, 10:50 AM | #1057 |
Rep 2,445
Drives: E63 645Ci
11-10-2022, 01:05 PM | #1061 |
Rep 2,445
Drives: E63 645Ci
Dude, calm down. I have no idea what you're saying. This is not a chat to bombard it with short, half arsed messages. This is a forum, slow down, gather your thoughts and describe what is happening and what is not happening. Maybe start with what exact unit you have, use full sentences and try present it in a way that someone can help you. We don't have crystal balls here...
e38740imd65.00 |
11-10-2022, 01:35 PM | #1062 | |
Rep 14
11-10-2022, 05:09 PM | #1063 |
Rep 24
Hi, on first page is the tool to get rid of message "phone is starting..." the KswAndroidOverlay, my question is this message is gone or replaced with something else?
11-10-2022, 07:31 PM | #1064 |
Rep 2,445
Drives: E63 645Ci
11-10-2022, 07:35 PM | #1065 | |
Rep 2,445
Drives: E63 645Ci
I don't know, maybe you've download multiple files, mixed them up and ended up with file names like bootanimation(1).zip. Regardless of that, I assure you there is nothing wrong with the download link nor the files. |
11-11-2022, 07:47 AM | #1066 | |
Rep 14
11-14-2022, 10:45 AM | #1068 |
Rep 2,445
Drives: E63 645Ci
It's a string indeed but from the Android OS framework. It has nothing to do with KSW stuff. You can try to install it manually - just open up the script in any text editor and see what commands are being used.
11-14-2022, 11:24 AM | #1069 |
Rep 24
11-15-2022, 02:20 AM | #1070 | |
Rep 2,445
Drives: E63 645Ci
11-15-2022, 05:14 AM | #1071 |
Rep 24
On first page there is a .apk installer for deleting this message , this apk did not work on mine, i opened it with decompiler and this is what it shows, you told me up to install it manually, how? What do you mean by open up the script?
Thanks |
11-15-2022, 05:35 AM | #1072 | |
Rep 2,445
Drives: E63 645Ci
If you decompile the overlay you will see nothing because this is exactly what it is meant to do - replace phone is starting text with nothing. install-windows.bat - that's the script, if you know how to ready it you can type these commands yourself instead of relying on the script. If you need a bit more help, here is my video but you will have to adjust these commands (file location on your disk and package name as per the script). |
11-15-2022, 11:27 AM | #1073 |
Rep 24
ok, i see,
i was just installing the apk manually from an sd and it gives app not installed, i tried now to install it from my laptop with the installer it worked ok, can we only delete the name phone and leave "Starting..." thanks. |
11-16-2022, 02:38 AM | #1074 | |
Rep 2,445
Drives: E63 645Ci
11-18-2022, 09:37 AM | #1076 |
Rep 5
hello i tried the px6 method ( since my unit only accepted .bmp file ) to change the boot animation but i get an error. I can connect to the unit, but when i run adb root this happens:
adb root cxj said not suport, 88 |
11-20-2022, 02:35 PM | #1077 |
Rep 5
i also tried going in adb shell and running su @#zxcvbnmasdfghjklqwertyuiop1234567890,. (which seams to be the default user for some chinese navs) but it's saying that su is not found ( under system/bin )
Any ideas on how to pus bootanimation on device? I was thinking since the adb root is not working the best is to root it, but i fear it might brick it. How can i root it? Specs : MTK8257 MCU: tsbmw 220511 |
11-21-2022, 04:41 AM | #1078 | |
Rep 2,445
Drives: E63 645Ci
Code:
setprop persist.adb.tcp.port 5555 setprop sys.rkadb.root 1 reboot |
