BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Akebono on M Performance Brakes
      08-24-2020, 09:45 AM   #89
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [10.00]
2009 Honda Civic  [0.00]
Originally Posted by mlev View Post
Originally Posted by chhappy7 View Post
But this is about the M Perf brakes though. And your post is sort of exactly what many dealers and resellers have told me where some of them don't even realize that there IS M perf brake set, and give replies that it will fit the M sport brakes.
That's because the M Perf Brakes and M Sport Brakes are both 370mm and 340mm. The only differences being the caliper color and rotors (drilled/slotted vs blank) and weight of those rotors. Pads and caliper size are the same.
Actually, the M Performance front brakes are bigger at 370mm. The blue ones are 340mm front and 345mm rears.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      08-24-2020, 12:18 PM   #90
Logicoeur
Logicoeur's Avatar
998
Drives: F30 335i xDrive
M sport Blue was 370/345 for 6cyl F3x, while 4 bangers got the 340/345 setup. Both got blank rotors. 6cyl F3x Grey Brembos are just 4cyl msport without paint.
Mperf brake packages got slotted and dimpled rotors.
      08-24-2020, 01:24 PM   #91
mlev
mlev's Avatar
Drives: 2022 Tesla Model Y Performance
So you're trying to tell me that my 335i blue M sport brakes don't currently have 370mm pads even though that's what I purchased and installed. Lol.
Check your facts before spreading misinformation.
      08-24-2020, 02:19 PM   #92
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Anyway same akebono pad fit whatever m-performance brakes you have
Amen
      08-24-2020, 06:12 PM   #93
Logicoeur
Logicoeur's Avatar
998
Amen
Correct, all the same caliper/pad if it's a 4piston brembo on the F30. Just the length of the integrated bracket changes.
      10-12-2020, 11:19 AM   #94
pauli18c
pauli18c's Avatar
Drives: 2017 340i RWD M Sport
Well I purchased these and swapped them out with my OEM pads (370mm rotors).
My positive thoughts are, less initial bite which was welcomed. The OEM ones are kind of annoying for daily street use and how much grab they have right away. The dust is definitely way less.
The bad, they don't have anything near the stopping power as the OEM pads. Wondering if they even have enough bite to lock up the wheels. Did a test run "panic" stop from about 100 and definitely dont stop all that quickly.
Overall probably fine for daily driving, but definitely not a spirited driving pad IMO
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup
      10-12-2020, 01:30 PM   #95
eleven11
eleven11's Avatar
Drives: -F85 X5M-
I'm not a brake expert, but I believe you should always be able to lock the brakes in this vehicle/platform. If not, I'd assume something is wrong (e.g. air in the lines). I can lock the brakes with these pads easily, even after 1+ hour spirited runs.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      10-12-2020, 01:41 PM   #96
pauli18c
pauli18c's Avatar
I guess I should mention that I'm on 245/40 and 275/30 PS4S tires. So there's a lot of grip before that actually happens.
Just giving my impressions after a couple hundred miles. The OEMs have more stopping power is all
      10-12-2020, 07:35 PM   #97
eleven11
eleven11's Avatar
Drives: -F85 X5M-
All good, man. More feedback is always welcomed. I'm on PS4S also - 235/35-20 and 275/30-20. Again, I'm not an expert, but consider that the caliper should be able to grab/lock the rotor without too much effort on the pedal. Once it's locked, it's all on the tires-to-road friction. (excluding ABS, etc.).
2017 X5M - Current
