BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Folding Mirrors Coding - HELP!!
      09-09-2020, 01:38 PM   #89
bobster2020
Drives: F13, F20
My Experience was this
only works for my f13 if the setting KMFRT_SCHLIESSEN is set to 00
this ensures that when you press lock there is ZERO delay in that very split second you press the lock button.
Hope this helps.
Thanks to those who contributed previously.
      12-01-2022, 04:08 AM   #90
cmbaksa
Lord C.M.Baksa
cmbaksa's Avatar
Drives: BMW 420i Convertable
Hi, as a novice I wish to know how to operate the electric mirrors from the Fob.
I have a BMW 420i convertible F33 and would like to know how to setup to operate the mirrors from the remote.
      12-03-2022, 08:25 AM   #91
TheNine90
Drives: bmw
Just hold the lock button to fold in and hold the unlock button to fold out the mirror
      07-02-2023, 12:31 PM   #92
alexm@
Drives: BMW M240i
Automatic tilt passenger mirror problem
Hey All! Newbie here!
I am hoping I can get some help for my F22 240i.
From the factory it has a dimming interior mirror, but the exterior mirrors are folding manually and heated.
Thanks to the instuctions i found on this forum i undestood that i could swap the mirrors. I bought 2 new powerfolding exterior mirrors and interior switch with extra button, i changed the 3 wires as mentioned and i started the coding. I have not the E sys and the experience to use it, so i coded as i write below via bimer code(expert mode).
FEM_BODY 3053 KOMFORTSCHLIESSUNG_FB aktiv
FEM_BODY 3053 KOMFORTSCHLIESSUNG_PA aktiv
FEM_BODY / 3053 / KOMFORTOEFFNUNG_FB aktiv
FEM_BODY / 3053 /KOMFORT_SCHLIESSEN werte 00.
FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN aktiv
FEM_BODY 3110 ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN 14 (20km/h)
FEM_BODY 3110 ASP_MAX_GESCHWINDIGKEIT_BEIKLAPPEN 14 (20km/h)
FEM_BODY / 3110 / ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN aktiv
All worked perfectly and thank you a lot for the information i got from you. I have only one problem so i would apreciate your help. The automatic mirror tilt of the passenger mirror isn't working. I know that so it could work the button must control the driver's mirror, but when i put the reverse, the mirror's glass does not move at all. Except the normal mode settings i changed, i also used the expert mode and activaded the codings i write below:
ASP_BORDSTEINAUTOMATIK aktiv
ASP_BORDSTEINAUTOMATIK_DELTA 5A
ASP_ELEKTROCHROM_SPIEGELGLAS aktiv
Is there anything else that i should do? Have i made any mistake? Is something missing?
If that helps, some information regarding the car:
M240i LCI 2018 model - Left hand drive(Greece) - 6MT - Android 10 Head unit - Aftermarket back camera
Thank you a lot in advance.
      07-04-2023, 07:54 AM   #93
alexm@
Drives: BMW M240i
problem solved!
ASP_MEMORY_BERBAUT: aktiv (0x01)
      07-24-2023, 05:11 AM   #94
RobotDoctor
Professional Nomad
RobotDoctor's Avatar
687
Drives: 2019 440i F36 Sportline
I tried coding the mirrors to fold on my 2019 F36 with Carly and could never get it to work. I was left to use the folding mirror button on my door arm rest to fold them. Frustrated, I ended up getting a license for BimmerCode and a OBDLink CX Bimmercode Bluetooth 5.1 BLE OBD2 Adapter and was able to code this with my initial attempt in a matter of minutes. I wish I got BimmerCode in the first place.
      07-25-2023, 06:16 AM   #95
Wibbles
Coding ECU's remotely
Wibbles's Avatar
547
Drives: M3LR & E70 40d
Or you could have done it in 5 mins with esys and an ENET cable for $20
Author of Car Connector - remote ICOM, ENET & DCAN tool - Built in VPN for easy coding and remote diagnostics:
visit our website
Car Connector on YouTube
      07-25-2023, 11:07 AM   #96
omarnyc
Drives: BMW 530xi
Wibbles your inbox is full again
      07-25-2023, 11:23 AM   #97
RobotDoctor
Professional Nomad
687
BimmerCode and the OBDLink CX adapter worked just fine. Love the Bluetooth connectivity to my phone with no cable to have to connect.
      07-25-2023, 11:31 AM   #98
Wibbles
Wibbles's Avatar
547
cleared
visit our website
      08-05-2024, 03:57 PM   #99
SteveHF33
Drives: BMW F33 420D
Anyone come up with a fix for the F33 other than making the Canbrio change and then using the open all windows and then the roof button is enabled.
I have added codes to my 2014 F33 and nothing - not done the
FEM BODY 3053 FH CABRIO VERDECK MODULE. Change aktiv to NICHT AKTIV
Basically it translated to : convertible top modules
Which might explain that the Covertiable roof has problems
I alway use the fold mirrors option to know I have locked the car when I have one of those "Did I lock the car moments!"
Bimmercode Question:
Does any one know if you can download all setting into a file? iOS version
      04-05-2026, 08:29 AM   #100
CrackedatBMW
Drives: BMW 90\91\92\93
Hello hope everyone is doing great i havr a bmw x3 2011 f25 and it has folding mirrors only i need to long press it please how can i chNge it to have no delay
      04-05-2026, 09:49 AM   #101
BeamerAR15
Drives: F23, 2.20i M-sport
Bimmercode
      04-22-2026, 02:03 PM   #102
fer1200
Drives: 2015 428i
Originally Posted by BeamerAR15 View Post
Bimmercode
Thank you!
