08-13-2020, 05:01 AM | #1101 | |
Rep 118
Reason I want to upgrade is that the unit he received does not contain the Dutch (NL) language. I can also not enable the KSWOverlay (unit refuses to connect) and I also tried to put the latest PX6 A9 update from the first page, but the unit does not say "update found..." Probably because his unit has a newer A9 version than which is available on this forum. [he has version: 2020042701T_1280x480_970] |
08-13-2020, 05:07 AM | #1102 | |
Rep 1,049
Anyways would be cool if he could share that update for other PX6 users if he got a file from his seller. Kri |
08-13-2020, 05:10 AM | #1103 | ||
Rep 118
Of course if I get the file, I will share it. PS: downgrading is not possible on our units? |
08-13-2020, 05:21 AM | #1104 |
Rep 25
Drives: 2012 E92 330d
Anyone know of a newer MCU than the one I've got? Andream are refusing to give me a newer version - it seems much more difficult to get hold of MCUs on these Snapdragon units than it used to be with the px5/6 ones.
08-13-2020, 06:06 AM | #1105 |
Rep 2,450
Drives: E63 645Ci
08-13-2020, 06:09 AM | #1106 |
Rep 2,450
Drives: E63 645Ci
I'm with you in that. I've been trying to get an update from Andream for moths, finally managed to get one. The approach that worked form me (eventually) was to point out a bug in the MCU and regularly message them.
08-13-2020, 08:17 AM | #1107 |
Rep 25
Do you have a newer MCU that I've got then or is your unit different? What bug did you point out?
08-13-2020, 08:51 AM | #1108 |
Rep 2,450
Drives: E63 645Ci
It's a different unit, sorry. I have CCC iDrive, and the bug I experienced was related to controller behaviour when after switching between OEM and Android it would stop responding in Android mode. But I recently started bombarding them with PDC issue as it doesn't stay up for the same time as OEM does - if you know what I mean. PDC view turns off even when parking sensors still work and are making sound. So if you have similar issue, try this as your argument.
08-13-2020, 09:10 AM | #1109 | |
Rep 118
08-13-2020, 09:13 AM | #1110 | |
Rep 2,450
Drives: E63 645Ci
iDrive: CCC Vendor: LZH Screen: 1280x480 Date: 17/06/2020 Full MCU string: 415187dLZH-CCC-GLT-200617-B18 I think you can downgrade to the older version if this doesn't work for you. |
Kri1080.50 |
08-13-2020, 11:18 AM | #1111 | |
Rep 25
08-13-2020, 12:00 PM | #1112 |
Rep 2,450
Drives: E63 645Ci
Ah famous "friend" tag. I'm using AliExpress app to chat with them via Andream Official Store or whatever it's called. You honestly need some leverage to get any update, find something that is wrong with your MCU (I'm sure there is something) and point out this bug to them, make a video and try to explain same thing in 3 different ways. That's the best advice I can give you :/
08-13-2020, 12:17 PM | #1113 | |
Rep 25
08-13-2020, 12:20 PM | #1114 |
Rep 2,450
Drives: E63 645Ci
08-13-2020, 01:20 PM | #1115 |
Rep 15
low volume
Hi, I have modified build.prop to install DAC but I am getting low volume. Can someone indicate how the mixer_paths.xml file can be modified to increase the output volume of the DAC.
08-13-2020, 08:36 PM | #1116 |
Rep 63
One more CarPlay question, I use auto kit with my iPhone and while in the android side if I unplug my phone from the cable it switches me from android back to the oem bmw screen automatically to the aux selection, is there a way to stop it from doing that that? Is there some setting?
08-14-2020, 01:53 AM | #1117 | |
Rep 11
It's just a pain in the *** to get updates, even for the firmware. I keep telling them that a new version is here..."the engineer said there is no update" I even asked them for the current MCU, just for backup purpose...no luck Chinese support is a joke... --- Appart from that, what is the damn algorithm used by the Kswmedia app to order folder and songs?? It's completely random, so difficult to find anything....PLUS, it comes back automatically to the current folder after a while. It's becoming very dangerous to change song while driving It's not a bad app and I like it. But if there is no way to improve that, I will go away to another app (thinking about Foobar, but share you advices ) |
08-14-2020, 02:40 AM | #1118 | |
Rep 2,450
Drives: E63 645Ci
On the topic of kswmedia... myself and few others reported that countless times to our sellers, but still nothing has been implemented. Not only the order is completely random, but also if you load up too many files the kswmedia app will crash, so that's that |
08-14-2020, 04:26 AM | #1119 |
Rep 41
guys, but it is normal that in diagnostics, with Ista-D, the sd625 is seen as an error, it gives me this anomaly: headunit connection to cid (central information display) Communication inactive ...??
you can see the video I made of the diagnostics, here: https://sendvid.com/nvpexhr1 |
08-14-2020, 04:42 AM | #1120 | |
Rep 2,450
Drives: E63 645Ci
bepp6721.00 |
08-14-2020, 09:47 AM | #1122 | |
Rep 1,049
Can you copy your build.prop in here (complete file) ? __________________________________________________ ____ Other Topic, On the 1st Page of this Thread 2nd post i startet a explaination of all Headunit related GUI settings. As some settings are only for specific cars / configurations, there are still missing alot of information, so the community here is asked to update me with missing information, preferred via PM or Discord to stay clean with this thread Kri |
