02-24-2014, 08:34 PM | #1123 | |
Rep 82
335i M Sport to M4
02-24-2014, 08:42 PM | #1124 |
Rep 1
Like a wet noodle...
Long story short, experienced my first limp mode after 4 months of ownership and 5K miles. No CELs, warning lights or messages - Only a sudden and complete loss of engine power. No acceleration, RPMs wouldn't budge. Kept mashing the throttle and the silly thing sprang to life, lurched and bucked and was fine.
Trip to dealer revealed several codes including one for cooling fan. Aux cooling fan replaced and software update applied. Filed a complaint on the NHTSA-ODI website for this issue and phoned BMW NA. Officially complained to them and put them on notice that if it occurs again, I will lemon the car under state and federal consumer protection laws. BMW was NOT happy to hear about the ODI complaint and that's when there tune changed. My dealer was surprised to find error codes for the limp mode without visual indication of a problem (CELs etc...). PUMA case opened, complaint filed with ODI and BMW and now we wait for the next limp mode. This is a safety issue first and foremost and I am terribly disappointed more people aren't filing complaints. Otherwise, the 335 is an awesome car and everything my 7 Audis, 3 Minis, 370Z should have been. If we band together and file complaints with the NHTSA-ODI, maybe we can put pressure on BMW to rectify this. It's a shame such a great car has this black mark. Just my .02... |
03-03-2014, 01:42 PM | #1125 | |
Rep 2,266
I was a block from work so I didn't pull over. When I got into the garage, when I had enough room I punched it in 1st and it did go a bit over 3k before I had to brake. When you're in Limp, you can tell well before you hit the wall of 3k RPM. And in the parking garage, she felt responsive. Oil temp was just below 250 and no fan noise at all.
F30 Sapphire Black M-Sport 335i 6MT
03-03-2014, 05:55 PM | #1126 |
Rep 343
Here I am eagerly awaiting my 335i in transit and stumble up on this thread.............ouch.
If I get this BS I will attempt to lemon it as well. Unacceptable. |
03-03-2014, 06:12 PM | #1127 | ||
Rep 1,831
Drives: 335i MSport + MPS/MPPK
It actually didn't register at BMW as the "limp mode" with the fan noise did. Whether right or wrong, I chalked it up to a software "bug." |
03-03-2014, 08:31 PM | #1128 |
Rep 2,266
Yes for now I'll just hope there's a TSB or recall for it. Taking it in is pointless. Although if the frequency increases, I might have to rethink that strategy.
03-03-2014, 08:47 PM | #1129 |
Rep 219
BMW has an updated auxiliary fan now for the MSport 335. Just had mine replaced with the new version after the first replacement went bad. Seems to be working fine. If you're still having limp w/ no code and the fan blasting, make sure you ask the service rep to get the new part.
03-03-2014, 10:25 PM | #1130 | |
Rep 2,266
Yeah just imagine a Spitfire on the tail of a Fw190 (BMW engine) the 190 pushes in the throttle and.....voila Limp Mode.
03-03-2014, 10:57 PM | #1131 |
Rep 13
Thank you all for posting about our F30 LIMP mode. I was able to use this information with my service manager to outline the issue and hope it's been taken care of today. Below are what BMW tech outlined. I picked up the car today. It happened to me twice. First time on the highway and second time few days ago in city driving condition. Normal driving condition prior to LIMP Mode (My car - 2013 - M335i w/MT)
"PERFORMED SHORT TEST, CONNECTED BATTERY CHARGER, FOUND FAULT CODE 1A2108 ELECTRIC FAN MINOR FAN FAULT. PERFORMED TEST PLAN, INSTRUCTED TO CHECK ELECTRIC FAN INDEX NUMBER, FOUND AT 01, INSTRUCTED TO REPLACE ELECTRIC FAN AND PROGRAM. REPLACED ELECTRIC FAN, PROGRAMMED VEHICLE. TEST DROVE. CHECK OK. DEFECT CODE 17 11 11 99 00 VEHICLE TEST- 00 00 006 CHARGER- 61 21 528 TEST MODULE- 61 00 006 WT REPLACING FAN- 17 11 535 PROGRAMMING- 61 00 730" |
03-05-2014, 07:21 PM | #1132 |
Rep 32
Just found this thread today after my first experience with what could only be limp mode. I found others' descriptions helpful---as well as details of their car/conditions for the general information bank...
My list of symptoms: -Sluggish performance, under 3000rpms and on occasion 4500rpms (read below) -No check engine light or visual indication of a problem, on board diagnostic check returned "OK" -When stopped, idle was higher than normal, around 1k rpms, car would accelerate a little the moment my foot was removed from the brake pedal, BEFORE touching the accelerator. -did not notice any excessive fan noise--(did not know to listen for it, excessive fan noise could have been present and I could have been too distracted to realize) The Details: I have a 2014 328xi Sport Line, (automatic transmission) Picked up in February, (build date of October 2013, Germany) currently have about 700 miles. Temp today was about 40 degrees, car is garage kept but temp in garage was around the same as outside. Since taking delivery I have been mindful of and following proper break in procedure. I have not used the different drive modes too much in my 700 miles, and when the incident occurred today car was in default 'comfort' mode. Started my car, began driving as usual. When the engine is cold I am extra gentle, did not notice anything until about 3 min after beginning to drive, while entering the freeway. While attempting to gently bring the car up to a safe speed to merge into traffic I noticed the normally sufficient light tap of the gas pedal didn't provide enough power. I inched further down onto the pedal, glancing at my instrument cluster it was obvious something was wrong. The car was sluggish, didn't want to go over 3k RPMs. If the accelerator was pressed all the way to the floor (past the click point) car would downshift and run (to a more sluggish than usual) 4500rpm--even that did not provide enough power to operate safely in and out of traffic. I had a hunch that if I turned the car off the problem may disappear---wanting to avoid a 'dealer not able to duplicate the event' situation I cancelled my meeting and drove directly to the dealer. Without shutting off the engine, I picked up the shop foreman, demonstrated the issue, and then traded seats so he could experience the issue firsthand. Left car at the dealer, comfortable that the foreman experienced the issue--got a call later saying when they started the car 10 min after I left the issue was gone and the car drove like normal. Their next move is to talk to some BMW regional person who may have more information, I should get an update tomorrow. Question: Since this thread obviously attracts people who pay close attention to their cars/those who have experienced this event--I want to know if there is anyone with an F30 who is sure they have NOT experienced this---could you please chime in and let us know you exist?? Would be a helpful gauge of how widespread the problem is, you know....rather than screaming "epidemic" inside of a hospital.... |
03-06-2014, 11:43 AM | #1134 |
Rep 2,802
After HPFP, injector issues etc in e90/92 I really don't understand why people continue to buy these cars when it almost certain that you will encounter limp mode etc. I don't get it.
03-06-2014, 05:28 PM | #1135 |
Rep 2,266
It's only the M-Sport model as it has different cooling than the other lines.
03-06-2014, 07:54 PM | #1136 |
Rep 32
03-06-2014, 09:16 PM | #1138 |
Rep 1,831
03-06-2014, 09:18 PM | #1139 |
Rep 1,831
03-06-2014, 09:21 PM | #1140 |
Too much is never enough
655
Rep 3,083
Can't the OP just revise the damn title of the thread? That would do the trick.
EDIT: I just went back to the first post. He HAS updated it with everything pertinent that's been learned since the problem surfaced - including the fact that it's only 335i M Sport. Maybe folks aren't actually reading it? Limp mode can literally be caused by thousands of different faults and include a multitude of different symptoms. This thread is (was) about the 335i M Sport fan issue. Last edited by BavarianFanatic; 03-06-2014 at 09:30 PM.. |
03-06-2014, 09:27 PM | #1141 |
Rep 1,831
03-06-2014, 09:32 PM | #1142 |
655
Rep 3,083
03-06-2014, 09:41 PM | #1143 |
Rep 1,831
