12-21-2022, 02:27 PM | #1145 |
Rep 9
Thanks a lot , it looks now very tasty;] more than happy
12-21-2022, 04:29 PM | #1146 |
Rep 17
Drives: w e90 320d
Sorry if this is a silly question but in software 2.4.2 the dashboard as shown in previous photos, the Speedo goes to 330mph is there any way to change this to a more realistic top speed.
Uk
12-22-2022, 12:01 AM | #1148 |
Rep 16
What is an opinion on using a USB splitter cable? I want to utilise one for Fijo USB Dac and the other for Carlinkit Carplay. Considering there's only 2 USB ports available I could appreciate an extra port for thumb drives and updates.
12-22-2022, 01:57 AM | #1149 |
Rep 3
12-23-2022, 04:08 AM | #1151 |
Rep 16
12-23-2022, 12:10 PM | #1152 |
Rep 146
I have E92 so I don’t have scroll wheel on my steering wheel. All the buttons on the steering wheel function normally though.
VRSF DP, VRSF 7" Intercooler, BMS OCC, Stg 2 LPFP, Custom MHD E30 Tune, Late Model E-Series N55
12-26-2022, 02:06 AM | #1153 |
Rep 1,049
12-30-2022, 12:28 PM | #1154 |
Rep 304
This is animation A11 with logo-image.
Upload the file to the root t of the flash drive without removing it from the archive (suitable for 1280x480 and 1920x720 screens). Insert into any USB slot and wait for the inscription at the bottom of the screen. If he doesn't write anything, then import it manually through the advanced settings (where the regular pictures are). The pictures will appear in P2. https://mega.nz/file/dmIz3SiS#T7Icx2...GsE3LuhyOmhIac Program https://github.com/horsicq/XELFViewer/releases |
12-30-2022, 01:31 PM | #1155 |
Rep 277
Chiming in to say I added a FiiO K3 amplifier as suggested and music sounds worlds better. There used to be some songs I couldn't even listen to they were such a mess. This cleaned them right up. I got mine refurbished on ebay for ~$65. It came with the USB cable and I found a short 3.5mm to 3.5mm on Amazon. Pardon the dust, camera really "amplified" it (har har).
12-31-2022, 11:21 AM | #1156 | |
Rep 2
thanks and happy new year to all |
12-31-2022, 10:28 PM | #1157 | |
Rep 42
01-01-2023, 07:58 AM | #1158 |
Rep 277
My phone charger is connected to the USB port in the center console. The amp is connected to the Android headunit through a different USB connection I fed through the center console and to the car via the 3.5mm jack pictured.
01-01-2023, 08:11 AM | #1159 | |
Rep 42
Understood. Thanks |
01-01-2023, 10:20 AM | #1160 |
Rep 18
Hi guys.
Has someone had some issue with the iDrive GPS signal after installing the unit? https://f10.5post.com/forums/showthread.php?t=1981050 |
01-01-2023, 03:25 PM | #1161 |
Rep 2,445
Drives: E63 645Ci
Don't use included splitter - it's shite. Both devices are trying to power the same antenna causing various issues. Sometimes it works, sometimes it doesn't, but mostly it works for a short period of time and then it causes havoc. What you need is a GPS diplexer or at least a splitter with a built in diode to cut off phantom power from one of these devices.
01-01-2023, 05:05 PM | #1162 | |
Rep 18
After installing the second unit (BTW replaced it to KSW snapdragon one ) I've connected the OEM GPS wire to the CIC unit directly as it was before and for the Android HU I've installed the GPS antenna that came with the device on the right corner of the front windshield and connected it directly to the unit. You're right, when it was connected via a splitter while using Google maps the indicator was spinning when the car was standing during navigation (but the iDrive navigation was working fine) that's also the reason that i've decided to connect the new unit with a separate GPS antenna. It's very strange what's going on since it was working fine before the second installation, looks like everything is indicating that there is some issue with the OEM shark antenna, but when i've connected it directly to the Android HU and tested it using the GPS test APK it was showing that there was a signal. |
01-02-2023, 10:32 AM | #1163 | |
Rep 18
01-03-2023, 09:19 AM | #1165 |
Rep 42
You may want to measure the voltage at the GPS terminal of the CIC unit without the GPS antenna connected.
On my F10 NBT there was about 4.7V. One way to see if your new HU is affecting it is to remove it all and return it to its initial state. |
01-05-2023, 05:33 AM | #1166 |
Rep 46
My 10.25 Android 10 unit intermittently shows "No Signal" while all sound and apps are running, for example, play youtube, sound is playing, abruptly HU shows "No Signal" but sound continue to playing. When I press button on the car for show OEM screen, it worked. When I return to android, still "No Signal" is showed.
While "No Signal", change to reverse gear, rear camera is showing no problem. This problem only can solved by shut down unit by turn off engine, and turn on again, reboot, and unit return to normal. I changed MCU and upgrade from 2.0 to 2.3, 2.4... to latest FW, no help. So, I want put small power switch on it, that I can manually turn on and off unit, since there is no any button whatsoever that I can press to reset or reboot unit. I need to know rear panel connector description so I can get power line and put ON/OFF switch on it. Mine is Mercedes NTG 4.5, any help will be really appriciate. |
