07-06-2020, 05:48 PM | #1145 | |
Rep 585
They're dropping the load target down from 220 at about 5800 RPM, to 205 by 6700 RPM, which is in turn reducing boost from 23 - 24 PSI in the 5000 - 6000 RPM range, then boost tapers down over 6000 RPM to 21 PSI. Have they/you considered trying to hold that load target a bit higher up top to take advantage of the Pure800?
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
07-06-2020, 06:58 PM | #1146 | |
Rep 585
It looks like they've reduce the load target especially in the mid-range, previously 206 at 4500 RPM, down to 190 - 195. Peak power is at about 5500 RPM in the modified tune. You should get a Dragy if you don't already. Based on times in the logs your 62 - 93 MPH (100 - 150 km/h) time was slightly slower with this modified map, probably due to the higher ambient temperatures. 3.217s in original and 3.38s in the modified version log data.
07-06-2020, 07:23 PM | #1147 | |
Rep 686
Drives: Your mom crazy
Garage List 2020 BMW M340i CURRENT [10.00]
2003 BMW 330i RIP [10.00] 2011 BMW 335i SOLD [10.00] 2016 BMW 340i SOLD [10.00] 2020 BMW X3M RIP [10.00] |
But yeah, feels like we've been stuck at this boost level for awhile. Probably mostly on me, I had family in town and didn't do any logs for over a week.
2020 M340i
DAW UF-X; Wagner intake manifold/port injection; ID1050xds; Precision Raceworks St2.5 LPFP ECUTEK; Wedge Performance E70 tune KW V2; BC Forged EH173 |
07-06-2020, 07:42 PM | #1148 | |
Rep 242
07-06-2020, 11:00 PM | #1149 | |
Rep 452
I can do a similar run tomorrow on the stock stage 2+ map in similar weather to compare. |
07-07-2020, 12:08 AM | #1150 |
Rep 585
Have you tried the regular Stage 2 E30 (non-HPFP) OTS map yet? Worth checking that out as well. It'll be lower boost but you may get better timing.
07-07-2020, 03:56 AM | #1151 | |
Rep 1,181
Nice boost you got there but timing is low but I am sure Paul knows what he's doing he's one of the best tuners out there.
You should add timing correction channels in your log settings. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
07-07-2020, 03:59 AM | #1152 | ||
Rep 242
07-07-2020, 04:04 AM | #1153 |
Rep 1,181
Keep it safe mate When running 0-200 your 100-200 will start in 3rd gear, try a separate 100-200 run starting in 4th sometimes it's faster.
07-07-2020, 05:08 AM | #1154 | |
Rep 242
07-07-2020, 05:34 AM | #1155 |
Rep 20
MHD st2HPFP/ xHP st3
I took a log at 4th gear from 2,500-6,500rpm.
@MHD st2HPFP 95oct/102ron *stock turbo *b58tuHPFP *HJS300cell cat. *akrapovic evolution line exhaust and link pipe *K&N air filter We can't buy 102ron fuel around city in Japan. I am using 'Shell v-power' which may be 98ron. I flash MHD last month. I feel less acceleration than previous map originally set by my tuner. I wonder if my setting is good . I am planning to replace the plugs with regapped NGK 94021, but not confident to make it better. Thans for this thread. Any comment appreciated! #1: https://datazap.me/u/fakebimmer/log-...&data=5-25 #2: https://datazap.me/u/fakebimmer/log-...&data=4-22
fake_bimmer
07-07-2020, 05:35 AM | #1156 |
Rep 1,181
Niceee, I see from the Dragy you ran 100-200 starting in 3rd gear.
Next time try a 100-200 run starting in 4th gear, you could improve your time further.
07-07-2020, 05:49 AM | #1157 | |
Rep 1,181
No way that's 98 RON fuel, your first run 8 degrees timing on 18 psi boost at 6400 RPM is really low.
And your 2nd run you were not at full throttle ??? Quote:
07-07-2020, 05:53 AM | #1158 | |
Rep 106
Change and reset octane rating after you flash. No ethanol in your country ?
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35) https://theone1973.imgbb.com/ |
07-07-2020, 06:45 AM | #1159 | ||
Rep 20
Do you buy methanol and petroleum at same gas station,and mix them by yourself?
fake_bimmer
07-07-2020, 07:12 AM | #1160 | ||
Rep 20
fake_bimmer
07-07-2020, 07:39 AM | #1161 | |
Rep 106
I have ethanol analyzer so I can see the ethanol content.
07-07-2020, 08:03 AM | #1162 | |
Rep 20
Excuse me for my another stupid question. E85means 85% ethanol ?
fake_bimmer
07-07-2020, 08:14 AM | #1163 |
Rep 106
No worries mate Yes E85 is 85% ethanol. Sweden have been using this for a while. I think Saab have use it from 2005. Sweden and Saab ..and government want to push etanol forward.
07-07-2020, 10:46 AM | #1164 | |
Rep 20
Our government prohibit to sell alcohol fuel for motors. I don't know the reason why. We can buy 3 kind of fuel, diesel,regular(approx.90ron),premium (approx.100ron) Shell v-power petrol is said to be better than other's in our country, so I choose the Shell. MHD suggest plugs may be old and worn. I'll try regapped NGK plug.
fake_bimmer
07-07-2020, 05:14 PM | #1165 | |
Rep 452
outside temp is about 93 according to the car..not the best run, phone disconnected from mhd right before I started so I fumbled with all of it to get back up to 2000+rpm and get the logging going...plus the previously mentioned AC https://datazap.me/u/aleksandersuave...og=0&data=3-22 |
OzBMR574.50 |
07-07-2020, 05:29 PM | #1166 |
Rep 57
Hi guys, here is my stage 1 BM3 log for 6MT. Ran through 2nd gear short of redline and a bit of 3rd.
A few questions - (1) Under full load, timing degrees seem to drop around slightly above TDC around 3,800 but seems to be fairly tame all the way to redline. Is this ok? (2) I seem to be getting boost deviations with a few spikes, sometimes 22 PSI over a 17 target. Any cause for concern? Link to log -> https://www.bootmod3.net/log?id=5f01...90c607ae580c24 |
