03-14-2017, 02:05 PM | #11705 | |
Rep 6
Do you know what the reason could be? Could incomplete PsdZdata be the reason? |
03-14-2017, 02:09 PM | #11706 |
Rep 42,998
No idea, but PSdZData has nothing to do with it. Maybe you pick wrong E-Sys Launcher Car Series or E-Sys Connection Target though.
03-14-2017, 02:10 PM | #11707 |
Rep 42,998
PM sent.
03-14-2017, 08:31 PM | #11708 |
Rep 123
Service Due 2000
Shawn,
I have my PC set up (with your previous help, thanks). I have the service due flash, that came back after resetting the dash cluster (at the speedometer). I have read an updated software upload is required. Can you share what you know or point me to a thread? Thanks Sean |
03-15-2017, 06:56 AM | #11710 | |
Rep 42,998
03-15-2017, 09:21 AM | #11711 |
Rep 20
Thanks to Shawn Sheridan
and the whole bmw coding community I have installed and used esys without any issues (so far) I want to send my warmest regards to those who figured it out and then shared it with the rest of us |
03-15-2017, 09:28 AM | #11712 |
Rep 42,998
03-16-2017, 06:40 AM | #11714 |
Rep 42,998
Use ISTA/D (Rheingold).
03-16-2017, 11:37 AM | #11716 |
Rep 42,998
Here is the steps:
-Hook-up the car to a good charger -After Rheingold boots up choose: -Operations -Vehicle ID -Make sure your VIN is there. -When done at the top select Vehicle Management and then Service Function right below it. -Select Body -Select voltage supply at bottom of list -Select battery -Select register battery change -Select search at bottom right -highlight ABL register battery -Select:
03-16-2017, 02:13 PM | #11717 |
Rep 272
shawnsheridan
I am looking to get started on coding my 2014 F31. Can you PM me the necessary files I need? I have all the cheat sheets and such printed out and have been reading the info. Thanks in advance
2014 F31 328i xDrive - Alpine White - KW V2 - 19" MORR VS8.2 - BSW Stage 1 - BSW Under Seat Woofer - BimmerTech Amp - Infinity Kappa 100.9w/500W Mono Amp - M-Sport Rear Bumper - M-Performance Diffuser - M3 F80 Style Front Bumper
03-16-2017, 02:28 PM | #11718 |
Rep 42,998
PM sent.
03-16-2017, 05:03 PM | #11719 |
Rep 68
Hey guys,
I have a quick question about a few codes if anyone knows. I have the basic/small non-Navi iDrive system and I also don't have the HUD. Was wondering if the following codes will work for me (I checked the super cheat sheet but it didn't specify): KOMBI 3000 BMW_LOGO mpm ag Changes KOMBI/HUD startup to M/// Performance. (Shows M550d on updated cars.) CMB_MEDIA 3000 SYS_EIN_AUS aktiv nicht_aktiv Enables Basic Voice Recognition HU_NBT 3003 CE_DEVICE_SPEECH_RECONGNITION aktiv nicht_aktiv Activates Siri Eyes-Free Button (Hold down voice recognition button) HU_NBT 3001 STARTUP_EMBLEM variant_01 variant_0 Change iDrive Startup Animation. Every picture of the changed startup animation I saw online was on the big navi screen. And I have the button for voice recognition but it doesn't function, so if I use the code above to enable it(if it's compatible for my HU), then I suppose I could also use the Siri-Activation code? Also, I don't have the HUD, but was wondering if that code would work to change the startup animation on my KOMBI. I also don't have a combox, therefore don't have Enhanced bluetooth. Just wanted to put that out there incase it matters. |
03-16-2017, 05:17 PM | #11720 | |
Rep 8,376
You want 6WA for logo display. You need NBT for animation. Voice commands will not work either. |
03-16-2017, 08:27 PM | #11721 | |
Rep 68
I did the code to enable Sports Displays and it worked, except that they don't actually operate. Is that normal? Is it just for looks? And I don't have a diesel. EDIT: Forgot to include that I did do research on this and it seemed to work on some people's F30's but not all. I'm not sure if it'll work for my engine so I was asking if anybody would happen to know. Thanks! Last edited by KushPatel; 03-16-2017 at 08:33 PM.. |
03-16-2017, 09:15 PM | #11722 | |
Rep 8,376
03-18-2017, 12:08 PM | #11723 |
Rep 353
Hi,
Can I use E-sys to identify the part numbers of the modules installed (e.g. ICM, DSC, etc.) in my car (F06). I am thinking to do a retrofit but what to know what do I have currently I also have ISTA if that might be the tool to identify the part numbers Thanks RB
15 F06 640i xDrive Gran Coupe/Grey
03-18-2017, 12:13 PM | #11724 | |
Rep 42,998
03-18-2017, 02:03 PM | #11725 |
Rep 353
Shawn, can I use E-sys to know what part numbers modules I have. I am trying to do a retrofit but it will depend on how costly it is based on what modules I have
Thanks RB |
03-18-2017, 02:08 PM | #11726 |
Rep 42,998
Didn't I just answer this question in my last post right above yours?
