04-13-2022, 12:27 PM | #1277 |
Rep 97
One item that I felt was worth replacing even though it's not on the TSB list is the VANOS bolts that hold the camshaft sprockets to the camshafts. They're complicated little assemblies, and I seem to recall reading they might be "torque-to-yield" or close to it (though I didn't try to verify myself). Felt like "cheap insurance" to do them too.
Spyder366.00 |
04-13-2022, 12:30 PM | #1278 |
Rep 97
also even if you're not going to DIY, watching the FCPEuro video on it is very educational, and of course they sell a parts kit so you have a price reference.
04-13-2022, 04:02 PM | #1279 |
Rep 97
thought of one more - if it's an x-drive, consider a front diff fluid change. It's kinda low miles to really need it, but my indie suggested it as a "while I'm in there" sort of thing. Perhaps something to do with the driveshaft passing through the oil pan.
If you believe BMW's "lifetime fluid" approach, you shouldn't ever have to touch it. Opinions on that vary of course, but personally I would like to see at least another trouble-free 100k mi on my odometer so I opted to change it. |
05-13-2022, 03:34 PM | #1280 | |
Rep 79
An experienced independent shop replaced the guides and chain. After replacement, it turns out the original parts looked fairly good. The mechanic showed me there was not unusual wear on the guides or chain. Cost was about $2500 USD. The shop indicated they've done about 100 of these repairs, so they've seen a fair number of cars out there with timing chain noise and failure issue. FYI I've changed the oil and filter every 5K mi (8K km). Auto-stop-start was active most of the time. Before the change, there was no high-pitched whine noise, the car was not throwing any codes. All up I'm glad this is behind me. It stings a bit to spend money that maybe didn't need to be spent. But I feel we gained peace of mind for not worrying about timing chain failures. Better safe than sorry. And curse you, BMW, for the poor engineering of early N20 engines. But life goes on.
2018 G30 540i xDrive M Sport | 2013 F30 328i xDrive
05-15-2022, 09:39 PM | #1284 | |
Rep 97
05-15-2022, 10:44 PM | #1285 | |
Rep 5,197
Did your dealer get BMWNA approval prior to your repair? If not BMWNA likely won't pay up per settlement terms, as BMWNA wants to see evidence of failure presented by dealer, who effectively files a on your behalf. BMW can then approve(evidence good enough) or deny(evidence not good enough) the claim, and then BMWNA and owner can pay their respective % of cost. One option is to nicely talk to service foreman who may go to bat for you, but this can hard too since the repair was done without BMWNA approval. |
05-15-2022, 10:50 PM | #1286 | |
Rep 5,197
My friend plans to keep doing 6k-7k miles of OCI with LL17FE 0w20 to reduce drag on TC. This may work ok since DD in our locale typically does not go above 3k rpm. |
05-16-2022, 08:24 AM | #1287 | |
Rep 79
05-16-2022, 09:56 AM | #1288 | |
Rep 5,197
Also nicely talk to the dealer GM and service director, this repair should have been submitted to BMWNA for approval per settlement terms, so the dealer needs to fix this. My guess is if dealer submits the evidence dated back to day of diagnosis, BMWNA should be OK to accept a lately filed claim and approve it for reimbursement. Last edited by bavarianride; 05-16-2022 at 10:01 AM.. |
05-24-2022, 07:41 AM | #1289 | |
Rep 10
05-24-2022, 01:08 PM | #1292 | |
Rep 5,197
Did you authorize diagnosis (e.g. one hour $200+), or did you voluntarily request for TC fix without diagnosis? |
06-08-2022, 12:03 PM | #1293 |
Rep 2
New owner of a used well maintained 328xi 2014, and just popping the oil cap off i have at least 1 solid inch of play with the timing chain if i pull it away from the guides. I assume this is a dead giveaway for future failure.
I don't hear any unusual noise/whine though. Should i have this diagnosed? I do have a powertrain warranty that came with the car 3y/36k so it should be covered but I have only had the car 50 days now. Basically if its got 1inch of play is that enough of a sign of failure to warrant the replacement job? |
06-08-2022, 02:38 PM | #1294 | |
Rep 518
06-08-2022, 04:20 PM | #1295 | |
Rep 5,197
06-08-2022, 04:26 PM | #1296 |
I can haz cheezburger?
6796
Rep 3,678
Drives: 14 Jeep/18 1500/08 e90/15 f36
Garage List 2018 Chevrolet Silv ... [0.00]
2015 BMW 428i Gran ... [0.00] 2008 BMW 335xi [10.00] 2014 Jeep Wrangler ... [4.50] |
218k on replacement N20
208k on body 01/15 built date, had TC/guides replaced by dealer for free when car had 69k miles on original N20. Month later after job, engine hydro locked (damn flash flood in NMB). Driven over at least 140k miles on replacement N20 but no record of VIN it was pulled from, though I was told it was from a 2015 model. Maybe I got lucky and my replacement N20 is 03/15 built or newer. As soon as I get it back from the body shop, I’m going to get the VCG replaced so I’ll have the mechanic inspect the chain/guides. No whine or symptoms. |
floridaorange11592.50 |
06-09-2022, 08:04 AM | #1297 |
Rep 2
I have a 3 year powertrain warranty from zurrich insurance so it should be covered but my issue is i dont' have any faults on the computer yet. I would think 1 inch of play would pop something but it doesn't.
Indie shop yesterday after work said drive it under the 3 year Zurrich and wait for faults then it will be easy to get the work done. They said its gonna be hard to get anything going when its not showing up in the computer. I'd happily find a 2015+ but its an xI wagon which is not the easiest to find. Its also a very good deal price wise with full service records despite the issues with TC. I'm trying to make this work. the 2016 wagon i saw recently listed for 2.5x the price i paid lol. |
06-09-2022, 09:49 AM | #1298 | |
6796
Rep 3,678
