05-06-2022, 03:17 AM | #111 | ||
Rep 1,454
2022 CT4-V Blackwing 6-speed
05-06-2022, 03:18 AM | #112 | |
Rep 1,181
On initial acceleration you are correct but on steady cruising I think they should be closer.
Anyway was linking it to the weird wastegate parameters, the logs also shows DME not requesting those boost fluctuations from FPFP actual and required. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
05-06-2022, 03:20 AM | #113 |
Rep 1,181
No don't buy the OTS maps unless you find them useful, you can try the stock tune.
05-07-2022, 08:01 AM | #115 | |
Rep 1,181
You really made me doubt it my tune with MPPSK throttle mapping.
https://datazap.me/u/ims/throttle?log=0&data=2-20-24 Quote:
G.Newt821.00 |
05-09-2022, 02:01 PM | #116 |
Rep 2,112
Well, i should be reading the manual little more closely...
Found this writing. This does put me at some what of ease from paranoid of using Ethanol >E10, due to what i've been reading about (possible) corrosions... E25'ish it is (for additional help with timing as already discussed)! |
ocdx30.00 |
05-09-2022, 02:46 PM | #117 | |
Rep 1,454
dinan5m34488.00 |
05-09-2022, 02:52 PM | #118 |
Rep 3,996
"Modern" has little to do with it. There are very few countries in the world still using Ethanol fuels (>10% that is) as pump gas. E85 is gone in most.
dinan5m34488.00 |
05-09-2022, 03:40 PM | #119 |
Rep 1,454
In the US, it's been a federal law since 1994 for cars to be ethanol compatible. There could be manufacturing differences for the different markets, but I doubt BMW is doing that. And the law was put in place so long ago, I suspect most (major) manufacturers have E85 compatible engines now. My "modern" still stands.
05-09-2022, 05:29 PM | #120 |
Rep 3,996
Please provide definition of "ethanol compatible"? There is quite a difference between E10 compatible and E25+ compatible.
I suspect such requirements exist everywhere, but again - down to definition of "ethanol compatible". Besides that - you said it yourself - a requirement from 1994 doesn't exactly represent „modern" in today's world of electrically driven toys For info - although in iDrive my BMW's user guide also states 25% as above, my (VIN specific) mobile app user guide still refers to compatibility with fuels "with maximum 10% Ethanol, i.e. E10" Maximum Ethanol content which can be found in pump gas in my country is 5%. In other European countries - 10%. That's just to put everything into context. But I am also glad our cars seem to tolerate at least 25%, officially. Although I have no easy access to it.
05-09-2022, 08:46 PM | #121 |
Rep 684
Here are 2 logs for the stock tune with pi disabled. I don’t see much fluctuations in boost. Please let me know what you think.
Stock tune Log 1 https://datazap.me/u/alanle/stock-tune-e13?log=0&data=3-24 Stock tune log 2 https://datazap.me/u/alanle/stock-tune-2-e13?log=0&data=3-24 Pi tune (boost fluctuating) https://datazap.me/u/alanle/david-reflex-v24-mhd-flexfuel-rev11-e13-auto-pull-boost-spike?log=0&data=3-24 |
05-10-2022, 02:48 AM | #122 | |
Rep 1,181
That's why I wanted you to test a higher boost tune to confirm.
From your WOT log it doesn't look like you have any boost leak. I think throttle/compressor power mapping should be improved, do you feel the boost fluctuations ? Quote:
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 Last edited by IMS-340C; 05-10-2022 at 10:51 AM.. |
05-10-2022, 05:49 AM | #123 | |
Rep 1,181
It's not just corrosion, Ethanol has totally different AFR than gasoline.
It also means OEM tunes can trim AFR up to E25. Quote:
dinan5m34488.00 |
05-10-2022, 12:06 PM | #124 |
Rep 684
Car runs smooth on stock tune. This problem started when I lowered ethanol level down to E10. I’ll mix e50 again to confirm.
05-10-2022, 02:03 PM | #125 |
Rep 1,181
One of the worst sounds to hear, stock HPFP crashing on E20 and 19 psi boost
https://datazap.me/u/ims/hpfp?log=1&...-20&zoom=49-84
05-12-2022, 02:04 PM | #126 |
Rep 1,181
My tune progress increased Ethanol to E20 mixed with 87 oct and increased boost to 18.5 psi.
Wanted to increase boost further but fuel pressure very low don't know why ? https://datazap.me/u/ims/ims-ms-new?log=0&data=4-20
05-15-2022, 02:55 PM | #127 |
Rep 1,181
My tune X3 M40i gen1 vs stock X3 M40i gen2
05-28-2022, 11:32 PM | #128 |
Rep 971
Car keeps getting 120308 low boost pressure code. Here is a log where it goes into limp mode and throws the code.
https://www.bootmod3.net/log?id=6292...729b449f9b2d29 There is a decent boost pressure deviation right before it happens could that be tune related? Right around .040 time stamp. |
05-29-2022, 02:36 AM | #129 | |
Rep 1,181
Whenever you're having a problem always take the tune out of the equation, run an OTS or stock tune and see if the problem still exist.
05-29-2022, 11:14 AM | #130 |
Rep 971
05-29-2022, 12:34 PM | #131 |
Rep 1,181
No worries about the turbo but try reducing Ethanol to E25 and test an OTS or stock, take a log then fill it again to E45.
WrxToBeamerGuy517.50 |
05-29-2022, 12:45 PM | #132 |
Rep 971
