10-20-2019, 06:27 PM | #111 |
Rep 787
I know, the kc is like the weichers, Megan, etc in that it appears to attach to the frontmost 3 of 5 bolts. I don't see a problem with that design, but Jahjaman was hinting at something. The Megan bar is considerably cheaper than the others though, so I'm trying to find out if there's any truth to this claim that the 'ecu cover' needs to be trimmed or removed. It seems odd given the fact that the ecu is lower down on the side of the engine
10-20-2019, 09:16 PM | #112 |
Rep 128
10-25-2019, 09:58 PM | #113 |
Rep 787
Megan Racing brace
Today I installed the megan racing bar.
https://www.ebay.com/itm/Megan-Front...53.m2763.l2649 To answer my own question above, it does not require removal or trimming of the 'ecu cover' panel which is just to the side of the driver's side strut tower. There isn't much clearance between the mounting bracket on that tower and the ecu cover, but it fit fine. 2nd pic shows the driver's side mount sitting atop the ecu cover. These bars are t6 aluminum and can be found on ebay for ~85$ at the moment. An outstanding deal compared to most of the others which run ~175 for steel and 275$ for aluminum. I did have to unclip the wire bundles which run along the front of the strut towers on both sides because the bar mounting plates stick out over the edges of the towers just enough that they get hung up on those wires. I relocated each wire bundle from the top side to the underside of its existing clip point and used a zip tie to secure it. Once that was done it was an easy bolt on job. I do wonder if it would be better to have longer bolts for the strut tower mounts now, because the added thickness of the bar mounting brackets means the bolts don't thread in as far. Those of you who are running strut bars- did you use longer bolts or stick with the stock? I counted about 5-6 full turns of thread in until they were tight (plus another 1/2-3/4 turn to reach the torque spec) vs about 8-9 turns without the bar brackets installed. No additional hardware is supplied with the bar so I assume they expect you to reuse the stock. I tried removing the washers from the stock bolts to replace them with slimmer ones, but they don't seem to want to come off easily and I didn't want to risk damaging those bolts without any replacements on hand. It almost looks as if they are fixed on the section of the bolt which is unthreaded and aren't meant to slide off over the threaded section without causing damage. |
10-27-2019, 08:58 PM | #114 | |
Rep 1,934
10-28-2019, 09:57 AM | #116 |
Rep 787
Yes. As others in the thread say, I agree it stiffens the front end in a good way. I find it more unified and composed, not flexing as much over uneven roads or corners where there is an elevation change like a road crest or sloped driveway. The steering is also less vague. This is no magic bullet, but For 85 bucks and a few minutes of wrenching, I am very satisfied with the mod. My car has m-sport adaptive suspension package, Rwd for reference. I can't comment on other trim levels but at this price it's basically an impulse buy.
floridaorange10369.00 |
11-13-2019, 08:59 AM | #117 |
Rep 373
hi does anyone know what the torque setting is for the strut bolts i have a ultra racing strut bar that id like to install. Is 25nm correct?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
11-13-2019, 10:23 AM | #118 |
Rep 928
I'm gonna run a Megan racing too 😎
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
11-13-2019, 12:00 PM | #119 | |
Rep 3,549
ChristosD97.00 |
11-13-2019, 12:19 PM | #120 | |
Rep 787
11-13-2019, 01:06 PM | #121 | |
Rep 3,549
11-13-2019, 04:42 PM | #122 |
Rep 787
Thanks, I thought so too but what do I know. In my case it only uses 3 of the 5 bolts on the top mount, so the other 2 are still threaded all the way in. Really enjoying how the added stiffness up front improves the driving feel for anyone who is still on the fence about this mod.
F87source7368.50 |
11-15-2019, 12:59 AM | #123 | |
Rep 373
11-15-2019, 01:00 AM | #124 | |
Rep 373
11-15-2019, 07:56 AM | #125 | |
Rep 1,597
11-15-2019, 08:23 AM | #126 | ||
Rep 787
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
F87source7368.50 |
11-15-2019, 11:04 AM | #127 |
Rep 3,549
56nm is the spec for the M10 screws (only seen on 3 bolt top mounts). The M8's are 30nm. You should only use the 90deg extra rotation if using new bolts since that's what stretches them. Just do the torque spec if not using new bolts.
11-19-2019, 10:11 PM | #128 |
Rep 928
Have the Megan stress bar coming too, can't beat the price.
12-10-2019, 03:37 PM | #132 |
Rep 787
The one I bought lists only f30 as compatible . It's possible they make a bar for your car too. Check their website and see if you can find a part number, then search that on eBay for a deal.
F87source7368.50 |
