09-30-2018, 02:16 PM | #111 |
Rep 398
its 62 plate,one of the early tourings
f31 330d mineral grey/black interior with extra stuff fitted
10-01-2018, 06:53 AM | #112 |
Rep 112
Well my 2013 330d (124k miles) was in at Cooper BMW Sunderland on Friday for it's EGR inspection.
According to them, my EGR Cooler has a crack in it letting exhaust gasses escape, BUT this is not part of the recall campaign. They told me they are specifically looking for traces of coolant and coking up of the EGR cooler module itself, and when they inspected mine it was perfectly clear, so they can't replace it as part of the recall. So although the part in question is faulty, they can't cover it's replacement FOC. Just my luck!! They are going to speak with BMW UK over the next day or two and find out if they can offer some sort of goodwill, but personally I doubt that will happen, will keep you updated.... Cheers Joe |
10-01-2018, 07:30 AM | #114 | |
Rep 7,030
If that's correct, you may have to wait a bit, but you should not have to pay anything. |
Jim Bob1.50 |
10-01-2018, 08:01 AM | #115 | |
Rep 777
10-01-2018, 10:14 AM | #116 |
Rep 3,265
Above seems to be the case. Mine is in Thursday and talking to them today I was advised that...
"Its the cooler we will be looking at to check that it has no leaks / fluid in it - If it is of the most up to date part number and is OK on inspection we will not change it" - If it is an older part No. and OK we will order a new one and let you know when to come and have it changed. - If it is faulty or with a leak or evidence of coolant (any part number) -we get a replacement as priority but keep your car with us (if we haven't got one to fit) and BMW give you a replacement car until it's repaired. So lets see what happens. |
10-02-2018, 06:23 AM | #117 |
Rep 11
When the egr cooler is replaced is a software update required?
I ask as my car has a remap. I have seen one post in this thread from an owner who is also mapped and his seemed to have not been updated but further confirmation would be great. |
10-02-2018, 06:53 AM | #118 |
Rep 3,967
Not if it's just the cooler replaced.
10-02-2018, 03:16 PM | #119 |
Rep 8,641
I get the impression that BMW is winging it with this ("it's not a recall") recall.
Had another conversation with the supplying dealer today to try and get a still better understanding of the works, parts to be replaced, etc. It was still fuzzy in parts. Cooler, and perhaps the EGR, will be removed for inspection. Will be cleaned if required (soot/sludge build-up). They are specifically looking for signs of cracking and/or leaks. BMW has supplied a photo reference pack to aid the evaluation. If there's no sign of cracking and/or leaks, the cooler will be refitted. If the cooler needed to be cleaned, the EGR (and potentially other components) will also be removed for visual inspection and/or cleaning. These may also be refitted. The next bit was less precise. Q : Why would BMW advise the refitting of parts to a vehicle where there has been a higher risk of failure and/or fire regarding vehicles within a specific manufacturing date range, and where the design and manufacture of those parts subsequently changed ? A : It will all depend upon the results of the inspection, plus a consideration of the vehicle mileage. Q : Does BMW accept that refitting inspected parts does not necessarily reduce the risk of failure and/or fire ? These old design parts could fail at any time. A : Cooler failure would normally be preceded by indicative symptoms : loss of coolant; warning lights; odour. Cars do not suddenly burst into flames. The answers also partly alluded to higher mileage cars potentially being more likely to have new design EGR and cooler fitted, but also no guarantee of that happening. Basically, a lot of of if but and maybe.
10-02-2018, 03:21 PM | #120 |
Rep 8,641
Had another conversation with the supplying dealer today to try and get a still better understanding of the works, parts to be replaced, etc. It was still fuzzy in parts. Cooler, and perhaps the EGR, will be removed for inspection. Will be cleaned if required (soot/sludge build-up). They are specifically looking for signs of cracking and/or leaks. BMW has supplied a photo reference pack to aid the evaluation. If there's no sign of cracking and/or leaks, the cooler will be refitted. If the cooler needed to be cleaned, the EGR (and potentially other components) will also be removed for visual inspection and/or cleaning. These may also be refitted. The next bit was less precise. Q : Why would BMW advise the refitting of parts to a vehicle where there has been a higher risk of failure and/or fire regarding vehicles within a specific manufacturing date range, and where the design and manufacture of those parts subsequently changed ? A : It will all depend upon the results of the inspection, plus a consideration of the vehicle mileage. Q : Does BMW accept that refitting inspected parts does not necessarily reduce the risk of failure and/or fire ? These old design parts could fail at any time. A : Cooler failure would normally be preceded by indicative symptoms : loss of coolant; warning lights; odour. Cars do not suddenly burst into flames. Q : Will the car potentially be required at a later date to eventually fit new parts if this doesn't take place at the first visit ? A : No real answer. The answers also partly alluded to higher mileage cars potentially being more likely to have new design EGR and cooler fitted, but also no guarantee of that happening. Basically, a lot of of if but and maybe.
10-04-2018, 06:00 AM | #122 | |
Rep 12
It is messy I wont lie. |
10-04-2018, 06:00 AM | #123 |
Rep 3,265
Mine is in today to be 'done' I'll let you know the result when I get it back, which I hope is quickly...... as the X2 118d is not particularly inspiring
10-04-2018, 06:24 AM | #124 |
Rep 3,967
I bet the Korean recall is less messy and there are no if's or but's when it comes to changing the parts!
10-05-2018, 02:57 AM | #125 |
Rep 3,265
Well the call from the garage yesterday was pleasing ' All good sir, no issues'
The EGR cooler was clear no cracks or signs of coolant, they cleaned it out anyway together with the pipe, replaced the gaskets and ready to go. I asked if it was one to be changed irrespective of condition and was told no as it is exactly the same as the replacement ones. So my 330d is now on 60k miles and 2014, so good news in my book. |
10-05-2018, 03:34 AM | #126 | |
Rep 3,967
10-05-2018, 04:34 AM | #128 |
Rep 3,265
10-05-2018, 04:51 AM | #129 |
Rep 8,641
There is a chance that our cars have a full software update as part of the EGR/cooler works, so I emailed Bimmercode to see whether backups could be loaded to restore coding.
Here's the reply : "if the software is updated at the dealership it is not possible to restore the coding you did, since the backups will not be compatible with the updated software. You would have to redo all the coding you did before one by one." So make a note of all the coding that you've done, and be prepared to do it again.
10-05-2018, 05:01 AM | #130 |
Rep 2,445
Drives: 2018 630iGT sport
Our 2104 530dGT (53k miles) is in at Coopers Cobham today for the EGR.
A fortnight ago it suddenly drank the contents of the reservoir, and since then the cabin has been getting wafts of diesel fumes. My missus noticed it before i did (my nose is pretty fucked from years of hayfever), but even I could smell it recently. Did less than 100 miles and the reservoir was on minimum again. BMW have advised me they have to inspect it first (concurs with others on here) and that due to the enormity of the problem and number of cars affected, the parts are on worldwide backorder and limited stock is available, so BMW are prioritising the worst cases first - and each car/case has to be submitted to BMW for approval before parts are released. I left the kids seats in the back, so hopefully that will also emphasise we don't really want the kids breathing in diesel fumes in a confined space either. Will report back later once I've heard from them. |
10-05-2018, 05:39 PM | #132 |
Rep 7,030
I caught a bit of a BBC Inside Out programme on Fords catching fire. Apparently their Ecoboost engines leak coolant, overheat and then catch fire. Ford’s solution is not to solve the leak, but to add an alarm to remind you to keep topping up the leaking coolant! Perhaps I won’t complain so much about BMW’s approach...
