06-09-2020, 11:57 AM | #111 |
Rep 77
Bummer you had to go through all that trouble 328dX, but it's good to hear H&R helped make things right! I just saw this discussion and was about to call FCM to confirm I have the correct front struts, but it looks like Farkle already has the part numbers (thanks!).
To add a little info, the part number for the full package that I got was 28895-8, so it may differ slightly from what 328dX has. Main spring rates are approximately 340 lb/in front and 640 lb/in rear, so it's certainly a pretty stiff/high frequency ride in front. |
FaRKle!4195.50 |
06-09-2020, 12:01 PM | #112 | |
David
793
Rep 2,008
The kit I got was 28895-4 off ECS
06-09-2020, 12:20 PM | #113 |
Rep 3,644
When I read this last night you came to mind and I spoke with Shaikh to confirm you had the correct parts and we already made sure you did! Good to go!
06-09-2020, 12:50 PM | #114 |
Rep 17
328dx, FaRKle and KTW,
Thank you for your input and clarification. 328dx, I look forward to your evaluation of this H&R kit after you have had an opportunity to put some miles on your car. |
06-09-2020, 01:46 PM | #115 |
Rep 77
I owe you a beer! I know AWD and RWD front struts are different but didn't even think to confirm it's the right one when I received it.
06-09-2020, 10:32 PM | #116 |
Rep 1,759
Hi any follow up on this kit? Still satisfied?
06-09-2020, 10:36 PM | #117 |
David
793
Rep 2,008
Follow up on the kit was just from yesterday and today. I installed it on 05/22 but the car sat until 06/05 due to receiving incorrect parts. I've only been driving it essentially for 3 days. So far it's great. I will post updates here as time goes on.
06-09-2020, 10:41 PM | #118 |
Rep 1,759
Apologies for that. But yes, please provide more feedback as it comes. Most setups will drive well on nice, even pavement. Let us know how it handles on the not so smooth roads. Thanks!
06-09-2020, 10:46 PM | #119 | |
David
793
Rep 2,008
Based off what Farkle said it being produced by Bilstein, I do see the similarities. The strut does feel like a B8 damper, and probably is a stainless version. I'll see if there's any break-in period or if it softens over time. It does handle my ride height very well though, no rubbing. There is a slight "bounce" when coming to a complete stop, you can feel the weight shift, but it settles immediately. |
06-15-2020, 10:32 AM | #120 |
Rep 175
So glad I found this thread. I'm trying to pick springs for my F31 and this is a great rollup of the latest options.
ACS - I'm looking at part # 3130231310. OP says they're discontinued, is that true? They seem to be available from the ACS US distributor, but I'm being quoted $670, which seems very high. Haven't yet found anyone selling them cheaper. Too much for simple springs, would rather put that toward a full setup. Eibach - see that there are two different kits available that all cost the same and both have the same 15mm front/30mm rear drop. Is the -15 really lower than the -14, given that the specs are the same? The load on the 15 is higher (1010kg vs 965kg) - wouldn't that mean it's actually the higher of the two? E10-20-031-14-22 E10-20-031-15-22 |
06-15-2020, 10:36 AM | #121 | |
David
793
Rep 2,008
And $670 is double what I paid for them, I really cannot recommend them due to the rake issue.
06-15-2020, 10:38 AM | #122 |
Rep 175
I've read enough posts about the rake issue that I think I will steer clear! I actually almost bought a car with them installed and didn't notice the rake myself, but I'd rather not risk it. Eibach seems like it will clearly lower the front more.
06-15-2020, 10:48 AM | #123 | |
David
793
Rep 2,008
A good combo I ran which you could see posts on the 3rd page is the Koni special active + the Eibach springs. Extremely good ride.
06-15-2020, 06:49 PM | #125 |
David
793
Rep 2,008
Love both honestly but probably the coilovers due to the adjustability which I already used many times.
redEYEjedi785.00 |
06-15-2020, 06:51 PM | #126 |
Rep 1,759
So height adjustability aside, both were comparable in ride quality and dampening of bumps and road imperfections?
06-15-2020, 06:54 PM | #127 | |
David
793
Rep 2,008
Koni/Eibach felt very smooth and handling improved a lot as well like I previously mentioned. Nose-dive/ launching, etc those struts are amazing technology.
redEYEjedi785.00 |
06-27-2020, 11:45 AM | #128 |
Rep 1
ACS spring kit
I am a total noob here, but the ACS Sport Springs did not present any reverse rake for my 2016 328ix. The kit came thru Turner Motorsport a couple years ago (Part#394987) at a much lower price than I am seeing in this thread. You may check to see if they are still an option, unless you've got your heart set on the Eibach. Very satisfied with the overall ride, even with OE struts.
06-27-2020, 11:52 PM | #129 | |
Rep 175
08-08-2020, 12:23 AM | #130 |
David
793
Rep 2,008
Thought I'd post an update on the H&R coilovers. Still think they're firm but it's honestly not bad, Can easily do 100+ miles without sweat. Most pavement types you cannot even tell unless there's a dip or pothole.
I lowered the car some more since I initially installed them, this made the ride softer. Less pretension on the coils so it makes sense. Overall I can still highly recommend as it's essentially bilstein, really love the ride. |
08-10-2020, 09:19 PM | #131 | |
Rep 17
Thank you for the update of the H&R coilover suspension system. I think this is what I will be installing on my 17 F31. Price point is reasonable and hight adjust is a must for me. |
328iX792.50 |
09-04-2020, 12:36 PM | #132 |
Rep 175
328iX and anyone else, how are you liking the H&R coilovers these days?
Still figuring out the best option for my wagon.
328iX I saw you had part number 28895-4, but the website lists 28895-8 for the F31, I wonder if it's been updated? |
