BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 OEM Alarm Retrofit (320i/328i)
      05-28-2018, 06:36 PM   #111
david51
david51's Avatar
France
540
Drives: bmw M3 F80
do you have a picture of your connections?
      05-28-2018, 09:05 PM   #112
Gabrielisimous
Gabrielisimous's Avatar
Drives: F30 328i 2013, E46 325i 2005
In my case that's all I have wired; the one to pin #11 and other to #3 following the tutorial
Gabo
      05-29-2018, 08:00 AM   #113
david51
david51's Avatar
France
540
Drives: bmw M3 F80
you still have to connect the power supply (slot 2) and the negative one (slot 1)
      05-29-2018, 08:43 AM   #114
Gabrielisimous
Ok Thank you!
Gabo
      05-29-2018, 09:29 AM   #115
the_mpd
Drives: 2015 F30 328i
Thanks David. A couple of questions:
1. Does the wire HAVE to go from the engine compartment fuse box? There is definitely 12v power in one of the wires already present in the roof module wiring - couldt’t one of those be spliced?
2. What is causing the FZD module to not appear in esys? The computer can’t “see” the module since, as of now, it isn’t powered?
Thanks again,
Marcus
Originally Posted by david51 View Post
Yes exactly
      05-29-2018, 10:22 AM   #116
david51
david51's Avatar
France
540
Drives: bmw M3 F80
Thanks again,
Marcus
you can connect to the jack to test side but the problem is that the fuse is 5A while the F62 is 30A.
yes E-sys does not detect the FZD module because it is not powered
      05-31-2018, 12:02 PM   #117
jalami
Drives: f30
Is any 30A fuse worth?
https://ibb.co/njGONd
      05-31-2018, 01:59 PM   #118
jalami
Drives: f30
I can not extract the fuse box z7. ??
https://ibb.co/f2Oevy
      05-31-2018, 02:54 PM   #119
david51
david51's Avatar
France
540
Drives: bmw M3 F80
Detach the electrical distribution box (1) with the special tool 00 9 325 from the lower part (2) and pull the electrical distribution box (1) upwards.
      06-01-2018, 02:44 PM   #120
jalami
Drives: f30
Upppssss
Today I installed. F62 (2) and negative (1).
esys is still not located.
https://ibb.co/dWyqLy
      06-01-2018, 02:56 PM   #121
Jhnblckwood
Drives: F30 2014 320i xdrive
U read ecu n not svt?
      06-01-2018, 04:41 PM   #122
jalami
Drives: f30
Yes .read ecu and svt.nothing
      06-01-2018, 05:06 PM   #123
Jhnblckwood
It’s gotta be power/ground or k-can wires.
      06-01-2018, 05:10 PM   #124
jalami
Drives: f30
Power box z7 . Pin 62 (pin 2 FZD).
Ground (pin 1 FZD).��
      06-01-2018, 05:29 PM   #125
Jhnblckwood
Do u have a multimeter so u can b sure ur getting power?
      06-01-2018, 05:42 PM   #126
jalami
Drives: f30
if I have. I will check
      06-01-2018, 07:30 PM   #127
Jhnblckwood
If not u should get. U can find one cheap.
      06-02-2018, 07:43 AM   #128
david51
david51's Avatar
France
540
Drives: bmw M3 F80
Hello
you must also add to the socket A21 * 1B
the 2 wires K_can2_H (location 14) and K_can2_L (location 15)
you can hook up just above
now it should work without any problem
      06-02-2018, 08:51 AM   #129
jalami
Drives: f30
I am going to try
      06-02-2018, 09:13 AM   #130
jalami
Drives: f30
https://ibb.co/ke1Mvy
I do not have kcan cables. I think I have to go from the fem
      06-02-2018, 09:21 AM   #131
david51
david51's Avatar
France
540
Drives: bmw M3 F80
watch here
      06-02-2018, 12:27 PM   #132
jalami
Drives: f30
I have looked and nothing. kafas cables.
