06-11-2019, 10:20 AM | #112 |
Rep 1,418
Drives: 13' F30 328i 6MT
Man im nervous, 97k miles... Owned car since 40k and have done 6500k OCI w/ Liqui Moly since owned. Im getting a whining oil pump sound until the oil warms up but then it goes away. I have no metal clatter and the car revs smoothly. From some threads ( ill post below ) even if you change the pump and guides you may still get this noise and also you could get this noise and never loose the motor or anything.
Threads - https://f30.bimmerpost.com/forums/sh....php?t=1349346 ( See post from David ) https://f30.bimmerpost.com/forums/sh....php?t=1449980 So much conflicting info, Dealer says they are not aware of the issue but probably cause they deal with mostly cars under 50k miles.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
06-11-2019, 10:46 AM | #113 | |
Rep 4,452
If they are a BMW dealer I guarantee they have heard and even dealt with this before. I was told the same thing and they looked at my car and told me nothing was wrong but they did say as I was leaving that they have dealt with it before after I said I don’t drive my car hard. They said that doesn’t seem to matter because they replaced one that an old lady had been driving since new. |
06-11-2019, 11:02 AM | #114 |
High Miler
29
Rep 44
If the chain is truly stretched and on its way out, I imagine a whining sound will be present if the engine is warm or cold. Is this true?
CTK
06-11-2019, 11:58 AM | #115 |
Rep 943
Drives: F30 328i Msport
06-11-2019, 12:19 PM | #116 |
Rep 1,418
My noise is pretty much non existent when the cars warm, Car revs out smooth and through the oil cap the chain feels tight ( Not that its a technical test ) but if i push on it hard its tight.
So im not really sure if its cause for concern, Its definitely not normal for this whine but in those posts above people are saying the whine will occur in 50% of N20s and that its a metallic sound that means ( FIX ASAP or PAY ).
09-18-2019, 01:50 AM | #118 | |
Rep 1,343
09-21-2019, 02:01 AM | #119 |
Rep 34
I had an issue with my fuel system and had to replace the high pressure pump and control module at 90k. When my car was in the shop (not BMW dealer) they let me know there was some slack in my timing chain and recommended replacement to prevent further damage, blah, blah,blah.....quoted me just under 2k. I have since installed an injen intake at 95k and my car runs extremely smooth.
Do you all think this is a real issue or are mechanics trying to capitalize on risk. I get my car checked every 5k miles and no mechanic has mentioned anything about the TC until now. What are some thoughts? |
09-21-2019, 11:02 PM | #120 | |
Rep 1,418
11-15-2019, 08:34 AM | #121 |
I can haz cheezburger?
6796
Rep 3,678
Drives: 14 Jeep/18 1500/08 e90/15 f36
Garage List 2018 Chevrolet Silv ... [0.00]
2015 BMW 428i Gran ... [0.00] 2008 BMW 335xi [10.00] 2014 Jeep Wrangler ... [4.50] |
Just had an oil service on my 428 (01/15 built date) at my local dealer. Currently at 66k miles and they mentioned that the chain isn’t giving any symptoms. However, the assistant service manager told me to bring the car back in before I hit 70k miles and that they’ll change out the chain/guides/etc...
Not bad. |
MacklinUSOB519.00 |
11-15-2019, 09:23 AM | #122 | |
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
F30lolz6796.00 |
11-21-2019, 05:15 AM | #123 |
Rep 10
Decided to bite the bullet and get my Timing chain assembly replaced for peace of mind. Wasn't having any issues at all - just that my motor usually sounded like a tractor (which I think is normal ?) - no whines etc. There is some play in the timing chain but I think people have indicated that under certain situations there could be some slack etc. Anyways - I have attached some pics of the process as well as the parts I bought
11317592850 - rail and guide assembly 11118618864 - front crank shaft seal 11317502048 - engine timing cover plug 11318648732 - timing chain 11317592877 - tensioner guide 11318685091 - timing chain tensioner 11417605366 - oil pump chain kit 11137627512 - oil pan gasket 11127588418 - valve cover gasket set 11117558632 x 2 - engine timing cover plug 11217614270 - vibration damper bolt 11137603830 x 2 11137603833 x 20 11427953125 - oil filter My car is a 328 - 2012 model with 75,000 miles currently. |
11-21-2019, 05:50 AM | #124 | |
Rep 159
11-21-2019, 08:08 AM | #125 |
Rep 384
My local BMW dealer recommended to change the TC on 32k miles or 50k km.
The reason, they had experience that on arround 36k miles, the TC start to break or loosen, and causing the piston to crack, and overhaul is needed. I don't know is this applicable to other places, but in my country, average road temperature is around 38C or 100F, and could even worse when there's traffic jam. As my piston cracked due to over power and torque, and now undergo engine overhaul, they will change the TC as well. Currently my car clocked around 36k miles. |
11-21-2019, 09:39 AM | #126 |
Rep 1,418
Out of curiosity what is your oil change frequency? That looks worse inside then my 25 year old E36 and my N20 looked brand new inside when I did a valvecover gasket at 100k miles ( 6k mile oil changes w/synth ). Either way please let us know if you notice a diff.
That is insanity, A timing chain change at 35k miles? Chains are not "Maintenance Item" and in past cars ive owned have gone 200k miles on stock chains including BMWs. My N20 has oil pump whine but the chains appear to be fine at 102k miles.
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 11-21-2019 at 05:58 PM.. |
rjd_F302010.50 |
11-21-2019, 12:09 PM | #127 |
Rep 230
Those pictures are alarming. Notice how internals are covered in dark red and sludge is present. There is/was serious problem with oil, not sure if coolant leak can do that.
Good news - even that lubrication does not cause chain failure, which again makes me think that oil changes have very little to do with chain problem. Last edited by F30ed; 11-21-2019 at 02:07 PM.. |
11-21-2019, 05:39 PM | #128 | |
Rep 2,709
Well what in the actual f*$#? If a BMW dealer is recommending it to all their F30 clients, then why isn't BMW covering it? |
11-21-2019, 06:12 PM | #129 | |
Rep 10
I bought this car used at 95000 kms. I'm at 125000 km now and do my changes every 8000 to 10000 kms. The service by first owner was a little spotty to be honest and was told it was done based on whatever BMW recommended. * shrugs *. Car ran well when I tested it prior to buying and still runs smoothly.
11-21-2019, 07:17 PM | #130 | ||
Rep 384
I had E60 in the past and drove until 120k miles, and all is fine. But now my N20 engine is undergo an overhaul, on 36k miles, so i asked them to change the TC. Quote:
Previously, my brakepad still can cover around 8k km (i-drive shows the same), when i brought to BMW for periodic maintenance, the said it need to be change and insist on it. |
11-21-2019, 07:31 PM | #131 | |
Rep 1,418
Flush - https://www.fcpeuro.com/products/pro...ui-moly-lm2037 Ceratec - https://www.fcpeuro.com/products/cer...ro-moly-lm3721
F30BimmerChris26.50 |
11-22-2019, 06:29 AM | #132 | |
Rep 191
Ceratec is not a good idea. I don't have the links currently but feel free to crawl the oil guy forums. It's been proven to cause damage to seals and cylinder walls among other things. It has a specific use and our application is not one of them.
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
